Old 02-25-2015, 09:52 PM   #1
COLGATE
Drives: FRS
ROUGH AROUND 2K RPM
2015 FRS WITH ABOUT 1750 MILES. I WAS WARMING UP MY CAR THE OTHER DAY AND NOTICE THAT AROUND 2K RPM THE CAR WILL FEEL LIKE ITS MISFIRING. WHILE IDLING THE MOTOR AT AROUND THE RPM IT RUN ROUGH, MAKES ME CONCERN. WILL BE BRINGING IT IN SOON TO DEALER, JUST WANT TO HEAR FROM OTHERS.
COLGATE is offline   Reply With Quote
Old 02-25-2015, 10:14 PM   #2
connorlug
Drives: #1553 10 Series FRS
DID YOU START IT COLD? THESE CARS WILL RUN A LITTLE ROUGH WHEN THEY'RE COLD
connorlug is offline   Reply With Quote
The Following User Says Thank You to connorlug For This Useful Post:
CrispyCheddar (02-27-2015)
Old 02-25-2015, 10:24 PM   #3
De-bounce
Drives: 1
IF ITS A COLD START, ITS NORMAL. I WOULDN'T WORRY ABOUT IT AS LONG AS YOU DIDN'T GET ANY CHECK ENGINE LIGHT.
De-bounce is offline   Reply With Quote
The Following User Says Thank You to De-bounce For This Useful Post:
Old 02-25-2015, 11:32 PM   #4
BRZnut
Drives: BRZ DGM Limited
Why are we yelling? Are you guys outside?? Mine does the same since new. On cold starts in sub-freezing weather, the engine will make a pop sound during the first 45 seconds and idle very rough.
Old 02-25-2015, 11:50 PM   #5
Koa
troll level 12+
Old 02-26-2015, 12:22 AM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
IT IS FINE. NORMAL COLD START.
N1rve
Old 02-26-2015, 01:54 PM   #7
COLGATE
Drives: FRS
NEXT TIME WHILE IN YOUR CAR, REV THE RPM UP TO 2K AND SEE IF THERE A FLUTTER OR BREAK UP IN RPM. SLOWLY RUN THE RPM UP, SHOULD BE SMOOTH THROUGH ALL RPM. WHERE TO MINES AROUND 2K IT STARTS BREAKING UP AND CLEARS BACK UP AT HIGHER RPM. SOFTWARE UPDATE OR MISFIRE... BUT THERE NO CODES
Old 02-26-2015, 02:04 PM   #8
De-bounce
Drives: 1
HMMM... I WILL HAVE TO TRY THIS NEXT TIME AND SEE IF I EXPERIENCE THIS ISSUE YOU SPEAK OF.
Old 02-26-2015, 02:05 PM   #9
YELLING TO GET OVER THE NOISE OF ROUGH IDLE FROM THE COLD START. (IF THAT IS WHAT IT IS SINCE I CAN NOT POSSIBLY DIAGNOSE AN ISSUE FROM A COUPLE OF SENTENCES ON A FORUM)
marky (02-26-2015)
Old 02-26-2015, 02:10 PM   #10
marky
marky's Avatar
Drives: 2020 BRZ tS #54
I should of saw this post coming by the look of the title all in CAPS
The Following User Says Thank You to marky For This Useful Post:
Tcoat (02-26-2015)
Old 02-26-2015, 02:17 PM   #11
COLGATE
Drives: FRS
LOL IM NOT YELLING THIS IS JUST DEFAULT. DIDNT KNOW THAT USING CAP LETTERS, CAN HURT FEELINGS. AND THIS IS NOT A COLD START ISSUE. YOU MANUALY NEED TO REV THE UP THE RPM AND CHECK FOR BREAK UP THROUGHT THE RPM. JUST NOT KNOWING THE REASON ITS DOING THIS JUST BUGS ME BECAUSE MAY NOT KNOW WHAT IS TO COME OVER TIME.
Old 02-26-2015, 02:24 PM   #12
Caps is generally reserved for yelling and it perturbs some people (personally I could care less except that is slightly harder to read).Like you said in you first post it needs to go in and be checked. Anybody that tries to diagnose over the internet is guessing at best and could get you all worked up with horrid scenarios when it is really a 5 minute fix (or not broke in the first place).
marky (02-26-2015)
Old 02-26-2015, 02:29 PM   #13
De-bounce
Drives: 1
I COMPLETELY DISAGREE. THE INTERNET IS A MORE RELIABLE SOURCE FOR DIAGNOSING YOUR FR-S PROBLEMS THAN USING THE WARRANTY WHICH COMES WHEN YOU BUY THE CAR AND HAVING PROFESSIONAL TRAINED TECHNICIANS LOOK OVER YOU CAR.
Tcoat (02-26-2015)
Old 02-26-2015, 02:33 PM   #14
COLGATE
Drives: FRS
im just a owner wanting to share my encounters, may help some. just trying to do my part to help the community as i will figure the problem to make this a better experince owning this car.
The Following User Says Thank You to COLGATE For This Useful Post:
Tcoat (02-26-2015)
Rough day for my 86 KiddCoast Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 33 03-23-2015 04:30 AM
'14 BRZ Ltd. - Rough Idle leicaboss BRZ First-Gen (2012+) — General Topics 20 05-22-2014 07:40 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 01:01 PM
sema rough nixeighty6 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 11-01-2012 05:30 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 11:28 PM
