Old 02-24-2015, 09:45 PM   #15
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Well I must be Lucky, I've got a v3 and tracked the shit out of it all summer, plus a 2 day lapping school where we have 6x30min each day and I was in the advance group, so beating on it hard. And no problem.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
The Following User Says Thank You to WatchmaN For This Useful Post:
misooscar (02-25-2015)
Old 02-25-2015, 01:33 AM   #16
misooscar
misooscar's Avatar
Drives:
Vented hood and oil cooler? One of the board members APMG? out from Puerto Rico mentioned a cheap fix is to install a recirculating pump on the v3, plus a small oil cooler
misooscar is offline   Reply With Quote
Old 02-25-2015, 02:24 AM   #17
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Me too - I must also be lucky.
I track my car about once a month and seriously give it horns. I've run about 650 hot laps on various racetracks with my V3 and no problems other than a chirping belt sometimes (which I sort out with a dash of Johnson's Baby Powder every two weeks or so).
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
Old 02-25-2015, 02:28 AM   #18
misooscar
misooscar's Avatar
Drives:
Conspiracy
Old 02-25-2015, 05:59 AM   #19
AJPG
Drives: 22RE, FA20, 4G63
Hi
AJPG from PR, the front bumper was finally removed and have photo of the set up.
Compared with the V2 is cheaper, it use the same pristine oil (monolec) and you can adjust at witch temp the oil pump start circulating (mine setup start at 165f) but you could adjust that in less that one minute (the time to open the hood).
DIDNT like the idea of using the contaminated engine oil to feed the SC, why? Normal engine wear...
Send a email and would share photos
Max temp ever recorded on SC was 181f.
AJPG is offline   Reply With Quote
The Following 2 Users Say Thank You to AJPG For This Useful Post:
2much (02-25-2015), misooscar (02-25-2015)
Old 02-25-2015, 06:11 AM   #20
puma
crew chief
puma's Avatar
Drives: Race car FR-S
send me the pictures please
pumalex at hotmail.com
puma is offline   Reply With Quote
Old 02-25-2015, 01:16 PM   #21
WatchmaN
WatchmaN's Avatar
Yes well...since i'm a cheap bastard i've got the forester oïl cooler and my Hood is vented by putting washers and removing the weather stip.
Originally Posted by AJPG View Post
Hi
It would be interesting for everyone to see it, can you post it here too. thanks
misooscar (02-26-2015)
Old 02-25-2015, 05:17 PM   #22
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Is the tune the same for the V2 and V3; all other bits being the same (pulley, fueling, etc)??
I ask because I have the OFT and OFH and was hoping to get the OFT300 tune, but for the V2 setup.
@Shiv@Openflash
Sleepless is offline   Reply With Quote
Old 02-27-2015, 06:32 AM   #23
AJPG
The difference between V3 and V2 have been discuss before in this forum...
It keeps the SAME compressor (impeller and housing) change the gear side to be more robust, but at the same F... time start to use the contaminated and hooter engine oil... Can you believe that??!!
As oil the monolec, used on the vortech unit is the best we could get and is what I use in my setup. I DONT recommend the use of the engine oil due to normal engine wear and higher temps.
The SC oil cooler with inline filter and oil pump
The SC oil pump controller with the max temp ever recorded
Off topic, speed with the 4.88 final drive
Photos of the oil lines in and out the SC as soon as I take them.
Jetbill (03-07-2015), misooscar (02-27-2015)
Old 02-27-2015, 10:12 AM   #24
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Why are people so against using the engine oil to lube the SC? Many high performance turbo cars (Porsche as an example) use the engine oil to lube/cool the turbos. Plus, Vortech clearly thinks this V2 is the better way to go for track use.
My 1997 Porsche Turbo has had a lot of hard track miles on it and the turbos have never had an issue. And, it has 65K miles on it.
Just sayin'
Old 02-27-2015, 11:02 AM   #25
AJPG
Contamination and vortech agree with me!
Read the warranty and there are some things that Vortech would considered to void warranty, including dirty or contaminated engine oil.
So after clearing that I could say that my setup is way better and I'm confident that could hold the 2.87" at the track without overheating. (Currently the max temp ever was 181f) that's frigid cold compared with engine oil at the track without turbo or SC.
As side note turbos and SC are kind of different internally.
Just saying
Old 02-27-2015, 11:05 AM   #26
AJPG
[ATTACH]103444
[ATTACH]103445
Old 02-27-2015, 11:13 AM   #27
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
@AJPG, could you show pics of the supercharger unit? I want to see how you tapped the oil lines on it. Thanks!
Tye300 is offline   Reply With Quote
Old 02-27-2015, 11:20 AM   #28
AJPG
Sure [ATTACH]103451
Guess witch is in
High performance Vortech at track Sonolin Forced Induction 41 03-18-2016 07:19 PM
Vortech SC - Leak & Loud Whine after Track (<6k) SonnyBRZ Forced Induction 37 05-14-2015 04:42 PM
DVSIDBOY - NWMotiv Project BRZ Track Build (Vortech / 2500lbs) dvsidboy Member's Car Journals 26 03-05-2015 01:55 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
