Old 02-22-2015, 10:11 PM   #3039
captain_jack
captain_jack's Avatar
There are common problems with the car not seeing the key and having that issue.
Old 02-23-2015, 07:13 PM   #3040
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by nlowell View Post
I have two spare belts if anyone is interested - one is brand new and one has ~5,000 miles on it. These are the original belt size for the C30 kit. I removed it when I upgraded to the newer/larger pulleys.
Spare/new belt was $75 (now $71) - Amazon.com: Gates K060815RB V-Belt: Automotive
How about both for $50 shipped - 67% cheaper than new!
I apologize in advance if it's not appropriate to post this here but figured it's only relevant to this group
these are for the C30-94 (first version) kit correct, if so can you PM me your information with the pictures?
Thanks in advance
glamcem is offline   Reply With Quote
Old 02-24-2015, 10:03 AM   #3041
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by FRS-cotty View Post
Just got done with my install yesterday and so far LOVING the changes. The install went smooth until we got to priming the SC. The install took a while because we were getting confused as we were cranking because the oil wasn't feeding, it doesn't help that the battery started to die. We ended up putting everything on just enough to start the car until we saw fluid at the oil in side of the SC. After that everything went good! The instructions kind of suck in some spots though. Overall I'm very happy with the outcome.
I have the C30 blower tuned by @DeliciousTuning. No dyno numbers yet but that will come soon.
AND I LOVE THE WAY IT LOOKS AND SOUNDS. I smile whenever I drive it now haha.
Did you respray your core black and then re-stencil it?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-24-2015, 12:37 PM   #3042
FRS-cotty
FRS-cotty's Avatar
Drives: 2014 Scion FR-S Asphalt
Nope! It came that way. I got the black edition.
FRS-cotty is offline   Reply With Quote
Old 02-25-2015, 12:08 AM   #3043
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
According the the guys at Kraftwerks, all the new kits will have black intercoolers.. The kit that came in yesterday had a black one also.. The customer loves it black, as do a couple others.. I personally like the polished version better..
Gixxersixxerman is offline   Reply With Quote
Old 02-25-2015, 10:18 AM   #3044
Model Citizen
Lacking brains
Drives: frz
i spayed mine black with grill paint, halfass job, but enough to hide the shine
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 02-25-2015, 10:18 AM   #3045
BRZZZZZZZZZZ
Car Nut
Dammit I wanted a black core with no logo for that...sleeper effect
Old 02-25-2015, 10:26 AM   #3046
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I going to paint mine with radiator paint for the sleeper effect too. And to help with heat soak, not that it is a problem from what I've heard.
industrial is offline   Reply With Quote
Old 02-25-2015, 10:44 AM   #3047
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
So what tools are needed to tighten the belt using a method other than guessing?
That really annoying vibration NVH sound is directly related to my belt tension. I loosened my belt a little bit last night to see if it was too tight and the sound got worse. I was able to feel the vibration and alter it by pushing on the back of the pulley slider thing. Tightened it to about 20.5mm and the NVH went down but isn't completely gone.
It's like a lugging sound at 1k under throttle, basically the slip point from trying to start from 0mph. If you slowly let out the clutch and have it fully out it still makes the noise from 1mph.
So what do I need to tighten the belt using harmonics or whatever kraftwerks suggests?
post_break is offline   Reply With Quote
Old 02-25-2015, 01:57 PM   #3048
CSG David
CSG David's Avatar
Discuss about the optimal settings with Kraftwerks.
Old 02-25-2015, 02:06 PM   #3049
post_break
post_break's Avatar
This is the kraftwerks supercharger thread right? I mean the information and answer to my question might help others.
"NOTE: You can also use a frequency measuring tool to gauge the correct amount of tension.
Set to 60.70 Hz."
According to the manual, has any one used a frequency measuring tool, and if so how did you acquire it?
The Following 2 Users Say Thank You to post_break For This Useful Post:
Freeman (02-25-2015), SPCorBUST (02-25-2015)
Old 02-25-2015, 02:20 PM   #3050
CSG David
CSG David's Avatar
Set to 60.70 Hz."
Yes it is. Sounds like every kit's setting will be different if it is based on the frequency.
Old 02-25-2015, 02:46 PM   #3051
post_break
post_break's Avatar
Still working on finding a legitimate tool since they are $600-$3000 but in the mean time...
https://play.google.com/store/apps/d...lculator&hl=en
This app is spitting out a frequency, at least I can ball park it.
The Following User Says Thank You to post_break For This Useful Post:
industrial (02-25-2015)
Old 02-25-2015, 03:02 PM   #3052
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
The 20.5mm adjustment i thought was with the older small pulley setup... mine is so close running the smaller 85mm compressor pulley that i had to remove the lock nut, how much flex do you have in your belt?? when i install these i have about a 1/2" maybe of belt movement. if your running the new bigger pulleys and have 20mm of space in the adjustment bolt, you may be way to loose.. its a cogged belt it doesnt have to be as tight as a serpentine belt, but it needs to be a little snug..
-Thomas
my first setup my belt was on the lose side.. it was slapping the lower mount, once i figured it out and tightened it, i had no problems from there on out
86SPEED is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
