Old 02-25-2015, 09:31 AM   #1
blown
Drives: ft86
quiet 3" exhaust
any out there?
looking for the quietest 3" headerback system.
blown is offline   Reply With Quote
Old 02-25-2015, 09:41 AM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
3" and quiet don't always go hand in hand. To my knowledge, there isn't a one stop shop header back, you'll have to buy them in pieces.
Perrin makes a 3" resonated cat-back, and Nameless has a 3" pipe that replaces the front and over pipes. When configuring the Nameless pipe, add the cat and resonator to keep it all quiet. Combine those and you'll have a full 3" exhaust.
All that aside, why do you need a 3" exhaust? Unless you're going for big forced induction power, you don't really need it.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
RobertPaulson (02-25-2015)
Old 02-25-2015, 09:48 AM   #3
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
JDL's 3" full exhaust with ultra quiet front pipe is one of the quietest ones I have seen.
2016 Camaro SS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2016 Camaro SS For This Useful Post:
Chad86 (10-15-2015), Koa (02-25-2015)
Old 02-25-2015, 10:06 AM   #4
Koa
3" helps little 2 litres sound a bit beefier.. with resonators to tame the added bass/baritone freqs, imo, 3" sounds better. I've had 2.5" and now 3" turbo-back on my wrx and good lord, what a step up in quality of sound in my op. Throaty without rasp; deep and has substance but doesn't drown out the other freqs in the sonic spectrum (thanks to some resonators).
2.5" headerback on my asphalt.. is alright on this rig but these FA20's don't sound too great to begin with (and neither did the EJs until people added some nice catbacks+ to 'em).
Of course everyone is different, and some prefer the sonic profiles of 2.5"- setups
just food for thought.. on N/A some argue 3" may be adverse to powerband, but doubtful the loss/change is significant to warrant going 2.5" then 3" later, if higher HP FI is in one's future
The Following User Says Thank You to Koa For This Useful Post:
Chad86 (10-21-2015)
Old 02-25-2015, 10:11 AM   #5
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Retaining both cats will help the most in keeping noise down. "Suitcase" style mufflers (eg Perrin) are typically quieter than cannon style exhausts (eg Tomei Type80).
Though to be honest, if noise is a concern, I wouldn't suggest a 3" exhaust.
campy is offline   Reply With Quote
The Following User Says Thank You to campy For This Useful Post:
Old 02-25-2015, 10:43 AM   #6
fika84
fika84's Avatar
From the research that I have done (most of what you want can be found by searching..) Perrin and JDL will result in quietest setup (keeping resonated and catted). After those 2 I would consider Nameless.
fika84 is offline   Reply With Quote
Old 02-25-2015, 10:51 AM   #7
2016 Camaro SS
Drives: Fast
I wouldn't consider Nameless. It sounds like shit N/A and fitment is questionable on their 3" OP/FP combo.
The Following 3 Users Say Thank You to 2016 Camaro SS For This Useful Post:
fika84 (02-25-2015), flippy (02-25-2015), Koa (02-25-2015)
Old 02-25-2015, 10:57 AM   #8
Koa
oo shit shots fired
that being said I want your jdl, SS
2016 Camaro SS (02-25-2015)
Old 02-25-2015, 11:03 AM   #9
2016 Camaro SS
Drives: Fast
Reasoned I mentioned it is because I had one of the first Nameless 3" full exhaust systems. Raspy nightmare, even with the resonated catted FP. Waited several months for them to finally make it and put it into production and I added the JDL UEL to it and oh my god..... I thought I was driving a Civic like a 16 year old with a fartcan.
Like what was mentioned above, avoid any canister style muffler, and go with the crossflow style like Perrin has, or JDL uses a Magaflow muffler in their setup. You will want it.
Chad86 (10-21-2015), M23 (02-25-2015)
Old 02-25-2015, 11:10 AM   #10
blown
Drives: ft86
got nameless header+2.5 op/fp, and FI.. tuner said needs to keep all 3" exhaust from header back.. since I'm stock after the op/fp..
considering the xforce 3" headerback.. but I have not seen much information about this..
Old 02-25-2015, 11:19 AM   #11
Koa
You're SC FI?
sell the OP/FP and get a custom 3" headerback. Put a helmholtz in and choose a magnaflow muffler appropriate for the job and go at it. should cost the same or less than a pieced together solution and it'll be fit to your vehicle.
Old 02-25-2015, 11:20 AM   #12
Yurgle
Drives: 2015 Toyota GT86 (EU Spec)
how about MXP 3" catback?
Yurgle is offline   Reply With Quote
Old 02-25-2015, 11:54 AM   #13
fika84
fika84's Avatar
Good to know! Thanks for the heads up.
Old 02-25-2015, 12:31 PM   #14
M23
Drives: 86
This!
Perhaps the better question for the Op may be:
Which companies make a nice, or the best, 3" catback exhaust utilizing Crossflow Style Mufflers (for reduced sound output).
M23 is offline   Reply With Quote
quiet and loud exhaust both in 1 JonMotoring Engine, Exhaust, Transmission 28 04-24-2020 02:22 PM
Searching for a Quiet Catback Exhaust tonystewart Engine, Exhaust, Transmission 70 02-21-2014 03:33 PM
Not enough exhaust Back Pressure? Quiet car? mtimney Engine, Exhaust, Transmission 11 08-05-2013 11:10 PM
Need a quiet exhaust setup for California Pneub Engine, Exhaust, Transmission 17 05-29-2013 03:34 AM
Quiet exhaust s2kdrew Engine, Exhaust, Transmission 21 06-25-2012 11:22 PM
