Old 02-24-2015, 04:03 PM   #71
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
any one have any experience with this type of fuel fitting...it looks to be a quick disconnect type..I have pushed and tugged to no avail..is there a trick?...or perhaps it's not a QD (shrug)
♠♠♠88
Ernie L is offline   Reply With Quote
Old 02-24-2015, 04:21 PM   #72
350matt
Drives: toyota mr2/ Toyota GT86
Hello Ernie
push the yellow bit in with a screwdriver whilst pushing the hose outer forward to release its grip then you should be able to pull the hose off
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
Ernie L (02-24-2015)
Old 02-24-2015, 05:11 PM   #73
Ernie L
Ernie L's Avatar
I have crossed the rubicon....3 hours or there abouts...I'm to slow to be a professional mechanic..the kids would starve
♠♠♠88
The Following User Says Thank You to Ernie L For This Useful Post:
WORKS (02-24-2015)
Old 02-24-2015, 07:21 PM   #74
Uplink
Uplink's Avatar
Drives: anything you let me
That's not a Jeep!
Great work! 3hrs for complete disassembly isn't bad for your first go at it and taking your time to do it right. You'll have it back together in no time. Would you say (so far) this is a very do-able project for a weekend if you had to have it back on the road for work Monday morning?
Uplink is offline   Reply With Quote
Old 02-24-2015, 07:59 PM   #75
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
subbed !
SON1C is offline   Reply With Quote
Old 02-24-2015, 08:17 PM   #76
Ernie L
Ernie L's Avatar
Originally Posted by Uplink View Post
That's not a Jeep!
Yes with out any distractions that would seem quite possible....I ate up a lot of time trying to figure out how each of the many different electrical connectors came apart. The passenger side injector wiring loom must be moved to get at one of the intake bolts . Removing the driver side injector heat shield (as they call it) was a puzzle that ate up some more time. I'll post a picture later of the bracket that must be removed first. I had to take a break as my back was locked up from leaning at the waist for three hours...back at it tomorrow morning.. I have to work on thursday so...I may have to take a day off ha ha ha
♠♠♠88
Old 02-24-2015, 08:20 PM   #77
Ernie L
Ernie L's Avatar
I guess they did. (previous post) That's great! It's nice to see they are on top of customer support. Really strengthens confidence in the company.
Good luck. Please keep us updated on the progress and any 'gotchas' you run into.
Oh, side note, are you going to run a FMOC like the Perrin unit? I'm curious if it'll fit with their exchanger.
I was looking at the Perrin ..I believe it would pose no problems..I just wish I could have used the Ptuning oil to water laminova cooler that I bought...the cosworth header nixed that..
♠♠♠88
Old 02-25-2015, 07:30 AM   #78
350matt
looking the Ptuning kit on their site I'd say you could still make it work, but it would need some relocating of the cooler unit with some longer lines
there's a bunch of space behind the passenger headlamp where you could mount it
Old 02-25-2015, 09:29 AM   #79
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Go to your local auto parts store and buy the kit of plastic fuel line disconnect tools. I should be the smallest or second to smallest one in the kit. It makes disconnecting the fuel lines so much easier without damaging them.
Ernie L (02-25-2015)
Old 02-25-2015, 11:46 AM   #80
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
http://www.harborfreight.com/6-piece...ool-97576.html
[ame="https://www.youtube.com/watch?v=DvngvwOy2ns"]DIY: Removing a Push Lock Fuel Line Fitting - YouTube[/ame]
Please don't use a screwdriver... If you need to ghetto it, make a sleeve that fits over the line you can push into the connector out of plastic from a milk carton (cut, fold it over and wrap it around the line and push in) or something. You are just trying to push the tabs back on the inside of the sleeve.
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
Ernie L (03-03-2015)
Old 02-25-2015, 09:27 PM   #81
Ernie L
Ernie L's Avatar
Yeah I looked at these vids long before I asked for help here...The ones I showed a picture of are not the same as those in the video.. You cant push anything into the end of the pipe as there is already the plastic yellow thing there...these are more like those shark bite quick connect plumbing fittings...You can see that the fitting does not go up to the raised rib and grab it like the fittings in the videos... I worked around it anyway...
thank you
Ernie
♠♠♠88
Old 02-26-2015, 02:49 PM   #82
Ernie L
Ernie L's Avatar
picking up were I left off yesterday..damn thing is heavy..and grabs everything..reminds me of "wait a minute vines."
♠♠♠88
Old 02-26-2015, 06:41 PM   #83
Ernie L
Ernie L's Avatar
Change out the thermostat, hook up the coolant lines, purge cooler and I'm done....my back cannot take anymore tonight.
♠♠♠88
WORKS (02-27-2015)
Old 02-26-2015, 07:23 PM   #84
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The Following 4 Users Say Thank You to weederr33 For This Useful Post:
Ernie L (02-26-2015), kungfujerry (03-01-2015), raven1231 (02-27-2015), WORKS (02-27-2015)
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
Cosworth BRZ/GT86 Vyk Mid-Atlantic 2 05-25-2014 01:49 AM
