Old 02-23-2015, 10:23 PM   #15
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by KoolBRZ View Post
The RPM's in 1st gear at 25MPH are 4949 for the 4.10, and 5891 for the 4.875. the torque doesn't really start dropping off till after 6000 RPM. It might be off by as much as 5ft lbs plus or minus. With 4.10's in both A/T and M/T, the M/T has more Ground Torque, or Power-to-the-ground than the A/T in EVERY gear. The A/T is made for mileage and sacrifices power, while the M/T is made for power and sacrifices mileage.
Power and acceleration are not interchangeable words. Anyway, at this point I, like others, will bow out rather than be drawn further in.
@slow_frs E85 with full bolt ons will get you around 200whp depending on which headers you choose. Swapping in a lower FD will give you arguably more usable ratios, accelerate harder in many instances and feel more powerful.
1974 TA22 Celica
2013 86 GT
Old 02-23-2015, 11:02 PM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Depends on the dyno. On a friendly dyno with intake, exhaust, and tune, you're looking at maybe ~200whp. More like a ~15% power again, and most of that is just from the e85 tune. Then comes the header. Then comes the intake. Not sure if an exhaust really matters. If you really want power on this car, get a turbo or supercharger, but you should have stuck with the Z06.
Old 02-24-2015, 12:12 AM   #17
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by Wayno View Post
+1
Auto is fine, it makes the same power at wheels as MT, so just read steve's sticky.
The auto does not make the same power to the wheels as the manual. It's a fact that I just proved in the posts above. Believe what you will, but facts are facts.
Until I changed the FD to 4.875 I had to really push it to keep up with soccer moms in minivans. Now I know I can pull away from most of the traffic around me. I'm also logging runs to work on maf scaling, so today for instance, I went from 2510 RPMs to 7205 RPMs in 3rd gear in only 9.43 seconds.
@slow_frs you should get a 4.875 FD installed, then ask yourself if you really need more power after driving it. Also ask yourself if you would really rather have a manual with stripped out syncros because you let your wife drive it on a cold day. The auto has it's limitations, but with the right FD, it's a blast.
P.S. and if you're still wish you had a manual, read this http://www.ft86club.com/forums/showthread.php?t=80393 .
It made me feel so much better for buying an automatic.
KoolBRZ is offline   Reply With Quote
468 POWER FRSTORMTORONTO User/Vendor/Sponsor Reviews, Feedback, Comments 1 11-28-2013 05:45 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
More power with Agency Power vividracing Engine, Exhaust, Bolt-Ons 0 07-26-2013 04:27 PM
