Old 01-30-2014, 01:42 PM   #15
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Oh snap, everyone's gonna die moew.
TouchMyHonda is offline   Reply With Quote
The Following 2 Users Say Thank You to TouchMyHonda For This Useful Post:
continuecrushing (09-11-2014), raytrix (01-30-2014)
Old 01-30-2014, 02:54 PM   #16
raytrix
Drives: Series 10 FR-S
If I wanted a car for it's safety features I would of brought myself a Camry loaded with airbags and goes slow enough were I never exceed the speed limit just so I can have a better chance of surviving an accident.
raytrix is offline   Reply With Quote
The Following User Says Thank You to raytrix For This Useful Post:
kylefrs (08-13-2014)
Old 01-30-2014, 03:10 PM   #17
swift996
swift996's Avatar
I recommend leaving the bolt on the OEM wheel when you pull. Just slightly on so when you pull (and you will have to pull very hard) it doesn't smack you in the face.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 5 Users Say Thank You to swift996 For This Useful Post:
adamg (02-23-2015), continuecrushing (09-11-2014), kylefrs (01-30-2014), MaXimus (02-24-2015), raytrix (01-30-2014)
Old 02-27-2014, 04:00 PM   #18
alderaan34
alderaan34's Avatar
They do make steering wheel removal tools so that this doesn't happen. I used it for my 87 MR2 when I changed out the steering wheel, much nicer and I didn't hit myself in the face :P
alderaan34 is offline   Reply With Quote
Old 02-28-2014, 02:06 AM   #19
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
thanks for the writeup! I just ordered what I think is the same wheel as you Nardi Deepcorn 350mm, anyways just wondering what hub you are using because you mentioned the adapter which I could possibly need to get. This is my first aftermarket wheel. It looks like you are running the works bell hub which is the one I will be ordering, but are you running a quick release? I can't tell from your picture.
alpine is offline   Reply With Quote
Old 02-28-2014, 04:15 AM   #20
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by Anthonytpt View Post
Nice DIY contribution, but I'd caution against this for street driving unless you enjoy having your face smashed with steel.
Most good aftermarket steering wheels are aluminum... When the power steering gave out in my '98 Camaro (because stupid idiot designers put the pump right next to the exhaust header) the Sparco Ring wheel I had on it was flexing like crazy....because sticky wide DOT-R rubber.
Need to eventually install my 320mm Momo Monte-Carlo in the FR-S, the thicker wheel and smaller diameter with help with increasing responsiveness (and leg room) and the red stitching would go perfectly in the interior.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-28-2014, 04:16 AM   #21
Gaiseric
Gaiseric's Avatar
Drives: 2012 Scion TC
Just dont be this guy lol
or... this guy...
Gaiseric is offline   Reply With Quote
The Following User Says Thank You to Gaiseric For This Useful Post:
8R6 (07-04-2015)
Old 02-28-2014, 09:02 AM   #22
kylefrs
kylefrs's Avatar
Drives: Scion FRS
If you run a quick release don't worry about the adapter and the works bell hub has a momo style pattern so if you get any wheel with a nardi/sparco pattern you will need a adapter or the quick release which has an adapter built in
kylefrs is offline   Reply With Quote
The Following User Says Thank You to kylefrs For This Useful Post:
alpine (02-28-2014)
Old 09-11-2014, 03:56 PM   #23
pleasurevictim
Drives: ZN6
any problems with the horn? I installed mine and everything works perfect besides the horn.
pleasurevictim is offline   Reply With Quote
Old 01-01-2015, 04:36 PM   #24
outlaw121
outlaw121's Avatar
Drives: 2013 scion frs blue
Anyone have problems putting a grip royal wheel with a works bell hub and nrg quick release on? I can't get anything to line up right do I need a adapter? Do I rotate the hub over a few teeth? If I do that the clock spring is off and abs and traction lights stay on
outlaw121 is offline   Reply With Quote
Old 01-07-2015, 10:54 PM   #25
outlaw121
outlaw121's Avatar
I got it
Old 02-23-2015, 11:43 AM   #26
adamg
Drives: brz
Awesome write up! works bell hub on the way, and i got a 340mm leather nardi waiting to be installed
adamg is offline   Reply With Quote
Old 02-23-2015, 09:31 PM   #27
adamg
Drives: brz
Originally Posted by kylefrs View Post
Step 6:
Put the 2 OHM resistors that came with the kit on the airbag plug ins as seen in the picture below. you might want to use some electrical tape so the resistors do not come out while driving or while installing the wheel.
Hey man curious if your hub came with that black resistor or if you bought that separately. I just installed my works bell hub and it came with that blue resistor and a normal looking resistor, but not the black one that you have in the picture. thanks
Old 02-23-2015, 09:40 PM   #28
kylefrs
kylefrs's Avatar
Drives: Scion FRS
Yes both came with the kit I believe. It's been a while since I installed it lol. And for anyone trying to get up with me just find me on Instagram because I'm not on the forums anymore @kylefrs_kings_low
Aftermarket steering wheel.. _F-R-S_ Cosmetic Modification (Interior/Exterior/Lighting) 164 04-20-2018 06:29 PM
How do you keep cruise control with aftermarket steering wheel??? kylefrs Cosmetic Modification (Interior/Exterior/Lighting) 32 04-06-2016 06:58 AM
Prova Steering Wheel Install RallySport Direct DIY (Do-It-Yourself) Guides 38 08-05-2014 01:42 PM
How do you keep cruise control after installing a aftermarket hub and steering wheel? Timtamtt Cosmetic Modification (Interior/Exterior/Lighting) 1 11-30-2013 08:17 AM
Aftermarket steering wheel HELP! Juurian Cosmetic Modification (Interior/Exterior/Lighting) 0 06-04-2013 12:47 AM
