Old 02-23-2015, 12:56 AM   #1
zman
zman's Avatar
Drives: scion frs
What should i do?
I have 2 10" JL audio subwoofers with a 450watt Kenwood amp that i took off from my old scion tc. The problem i have it does not fit in the FRS trunk. Should i cut a inch of the box from the bottom or just buy a single 10" box from amazon and only use one speaker?
zman is offline   Reply With Quote
Old 02-23-2015, 01:25 AM   #2
grass138
Drives: Man
Send a message via ICQ to grass138 Send a message via AIM to grass138 Send a message via Yahoo to grass138
Since you already have two subs, might as well cut off the excess inch. Or, you can sell one of the subs which you can use to purchase the single 10 box. Good luck!
grass138 is offline   Reply With Quote
Old 02-23-2015, 08:52 AM   #3
Chimera
Drives: FRS
You Could check out integrity concepts. They make corner load enclosures that should hold the 10s
The Following User Says Thank You to Chimera For This Useful Post:
Integrity Concepts (02-23-2015)
Old 02-23-2015, 02:26 PM   #4
zman
zman's Avatar
Drives: scion frs
It's not going to affect sound quality or anything if i cut it?
Old 02-23-2015, 03:22 PM   #5
Integrity Concepts
Integrity Concepts's Avatar
Drives: Concepts
Zman,
You should try to keep the internal volume of the enclosure within the manufacturers recommended range for best results. Making the enclosure too small could greatly affect the sound quality and the woofers long term performance. JL lists all of their woofers net enclosure specs on their website, add the sub displacement to the recommended volume and this is the gross volume each woofer chamber should have, measure the inside length, width, and height of your estimated cut size and multiply them then divide that number by 1728, stay within a close percentage of that number.
If you find that it works out and decide to proceed with a cut, peel the carpet back and see if you can pull off the lid or floor by prying in the seam. Make a clean level cut around the perimeter of the walls (not through the carpet, carpet should be peeled back) and then reglue (with wood glue) the piece back on and nail or screw it. Caulk the inside seam, clean up the sawdust from the inside of the carpet and reglue it down with spray glue, or recarpet the box all together. This is the best way to make a clean modification that will not have leaks.
Dan - Integrity Concepts
Integrity Concepts is offline   Reply With Quote
Old 02-23-2015, 04:24 PM   #6
mid_life_crisis
Drives: FR-S 10 #103 AT
JL is usually pretty good about answering questions. In your situation I would ask them for the ideal size box for a pair of the speakers you have. It isn't always as simple as double the size of a box for one speaker. Make sure you include the exact model number.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 02-23-2015, 06:29 PM   #7
zman
zman's Avatar
Drives: scion frs
Ok i looked up the specs.
http://www.jlaudio.com/10w1v2-8-car-...-drivers-92073
This the speakers that i own. Is it okay if i buy a box that is larger then recommended? I think i just want to use one speaker and it says there that it supports jl audio speakers. Thanks
Old 02-23-2015, 06:45 PM   #8
Integrity Concepts
Drives: Concepts
This is true, I guess I shouldn't assume the box is individually chambered.
That all depends, what is the internal volume of the enclosure that you are looking at? As a rule of thumb a larger sealed enclosure will typically allow the woofer to play lower tones but at the cost of power handling.
Old 02-23-2015, 07:17 PM   #9
zman
zman's Avatar
Drives: scion frs
The outside dimensions are 14.5x15x13.5 and its .75MDF
Old 02-23-2015, 07:22 PM   #10
Integrity Concepts
Drives: Concepts
That enclosure is 1.22 cu ft and is almost twice as big as the amount recommended for 1 of your woofers. You should be looking for an enclosure half that depth for running only 1 of your 10's.
Old 02-23-2015, 07:29 PM   #11
zman
zman's Avatar
Drives: scion frs
How did you calculate that since it's not the interior dimensions? Last question i promise lol.
Old 02-23-2015, 09:33 PM   #12
Integrity Concepts
Drives: Concepts
As long as there are no inset sides or end caps the interior width of the single chambered enclosure is the overall width minus the sides at .75" a piece, so 15-1.5 = 13.5". Then do the same with the other 2 dimensions and we end up with 13 x 13.5 x 12 which is 2,106 cu in divided by 1728 (1 sq ft in inches) and we get 1.21875 cu ft.
The Following User Says Thank You to Integrity Concepts For This Useful Post:
zman (02-24-2015)
