Old 02-20-2015, 05:03 AM   #351
dave-
Drives: 86 GT
Was posted in another thread but more relevant here, does anyone know the RAM address for the second 02 sensor on an A01G rom?
dave- is offline   Reply With Quote
Old 02-22-2015, 10:26 AM   #352
burdickjp
Drives: 2013 ultramarine Scion FR-S
I noticed the 'load' value for B01C Roms is in g/s whereas the ECU tables are in g/rev. I've made a script to produce a new load value based on MAF and RPM, but am curious if the ECU has an address for load in g/rev.
burdickjp is offline   Reply With Quote
Old 02-22-2015, 02:33 PM   #353
Kodename47
Kodename47's Avatar
Drives: UK GT86
All load is g/rev. It's probably just a type error.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-22-2015, 04:32 PM   #354
ztan
Drives: Toyota 86
I've had a quick look at the OBD call table disassembly but have not tested:
Can you try FFF8D274 and FFF8D278 and report back?
ztan is offline   Reply With Quote
The Following 2 Users Say Thank You to ztan For This Useful Post:
dave- (02-22-2015), steve99 (02-23-2015)
Old 02-22-2015, 07:41 PM   #355
dave-
Drives: 86 GT
Will try these later today and report back:
paramname = AFR2
paramid = 0xFFF8D274
isfloat = 1
scalingrpn = x,14.7,*
paramname = AFR3
paramid = 0xFFF8D278
isfloat = 1
Old 02-22-2015, 08:13 PM   #356
ztan
Drives: Toyota 86
paramname = AFR2
isfloat = 1
paramname = AFR3
isfloat = 1
Off OBD Mode 01, PID 15, I'd expect D274 to be sensor volts reading between 0-1V (scaling rpn=x); 1V is rich, 0V is lean. Expect D278 to be AF3 trim (scalingrpn=x).
dave- (02-23-2015), steve99 (02-23-2015)
Old 02-22-2015, 09:35 PM   #357
burdickjp
From the logs it looks to be similar in magnitude and value as the MAF logging, so I assumed the issue was related to that.
I'd much rather have a log of load than be calculating it. I guess doing the math with someone else's log could help me determine if my math is right.
Where would I start looking to fix this?
Old 02-23-2015, 03:15 AM   #358
Kodename47
Kodename47's Avatar
Drives: UK GT86
So you haven't got a parameter for load? Calculating it isn't ideal due to the compensations that are made, there will be slight variances.
What file are you using for logging? Plenty of info on here to check the correct load parameter.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-23-2015, 12:36 PM   #359
burdickjp
I got addresses from the 'b01c' addresses file. I can't remember which of the other files I started with, but there were a few things which needed to come over from the addresses file.
Old 02-23-2015, 05:51 PM   #360
dave-
Drives: 86 GT
Did some logs driving to work today using your values:
paramname = AFR2
isfloat = 1
scalingrpn = x
paramname = AFR3
isfloat = 1
scalingrpn = x
http://www.datazap.me/u/dave/rear-o2...g=0&data=29-30
Old 02-23-2015, 06:58 PM   #361
burdickjp
Here's my current log config: http://pastebin.com/tNTbKqzK
Old 02-23-2015, 07:12 PM   #362
steve99
Drives: FT86
paramname = Load
paramid = 0xFFF8DB84
isfloat = 1
assuming that ram address is correct for your rom type your reading the "load" from the ECU it calculated by the ECU and not scaled by the tactrix ie no scaling is applied to value read from ECU.
The values you should range from almost 0 at idle to about 1.3 full throttle under load
Old 02-24-2015, 10:37 PM   #363
burdickjp
None of the configs from the OP scale load, so I'm guessing the address isn't right, or something similar.
Old 02-25-2015, 12:16 AM   #364
steve99
Drives: FT86
try @phrosty he is on b01c or d rom sure he has a working logcfg.txt for that rom. strange load does not work as most guys would want that for maf scaling.
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
