Old 12-22-2014, 08:50 PM   #1
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Key ignition barrel problem
So I've had my FR-S about two months. I've had it half a dozen times where I can't turn the key in the ignition barrel. Tonight was the worst, took a minute of trial and error for it to go, and I didn't want it to snap off in the barrel.
I already know to try pulling the steering wheel from side to side, but usually does nothing. For now I've put the other key I have on my keychain, thinking perhaps it's a bad key, but could there be another issues at play that others have had experience with?
V_86 is offline   Reply With Quote
Old 12-23-2014, 12:47 AM   #2
Not really, but I'd go with the bad cut key theory.
You might try a little WD-40 or silicone spray on the key and run it in and out a few times.
Back in the day, we used to squirt a little 3-n-1 oil in the cylinder, then heat up the key with a Zippo lighter and run it in and out a few times.
But today, it’s hard to find a Zippo lighter …..
Tcoat (02-23-2015)
Old 12-23-2014, 04:37 PM   #3
steve99
Drives: FT86
+1 on above post.
also carefully check you key, if you have dropped keys especially if they are in a big bunch you can get small burrs or damage on key. you might need to carefully remove any burs on key with fine sandpaper.
Try your spare key and see if it has same problem.
Old 12-25-2014, 09:23 PM   #4
V_86
V_86's Avatar
Thanks, so far after 3 days, no issues with using the spare key. I'm going to give it a week (it happened more than that) and see if I have conclusive evidence.
Old 02-23-2015, 12:07 PM   #5
V_86
V_86's Avatar
So it seems this problem has returned with my other key. Not nearly as bad as before, and I seem to fix it for a week or so by spraying some WD-40 on my key and running it in a few times, as suggested. I'm looking for a more permanent solution? An OEM oil? Silicone spray?
Old 02-23-2015, 04:03 PM   #6
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Powdered graphite
billwot is offline   Reply With Quote
Old 02-25-2015, 11:48 AM   #7
V_86
V_86's Avatar
Uh just a tip, I read that WD-40 is actually bad for locks, can jam things up. I had actually used silicone spray a few days ago and works like a charm.
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 09:23 PM
Ignition for Cat warm up Toyota John Software Tuning 8 04-16-2014 12:14 PM
Daredevil Achieves First Barrel Roll In A Four Wheel Vehicle #944_10_Series_FRS Off-Topic Lounge [WARNING: NO POLITICS] 3 11-22-2013 09:43 AM
Ignition vs Argento? Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2013 04:24 PM
Keyless ignition for my FRS Gixxersixxerman Electronics | Audio | NAV | Infotainment 1 11-30-2012 11:09 PM
