Old 02-23-2015, 06:45 AM   #71
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Without emissions regulations the greater Los Angeles area would be an uninhabitable wasteland right now.
Isn't it already?
The Following 5 Users Say Thank You to themadscientist For This Useful Post:
Hyper4mance2k (04-26-2015), PWBRZ (02-23-2015), Shit Luck (02-23-2015), Sideways&Smiling (02-23-2015), strat61caster (02-23-2015)
Old 02-23-2015, 10:21 AM   #72
fika84
fika84's Avatar
This is a great swap option for the people looking for more power with more reliability! @Speedhead, one thing that still worries me is the stock transmission and the amount of people that have had issues with adding more power. You mentioned there were ways of strengthening it, could you elaborate a bit on this?
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
anthros (02-23-2015)
Old 02-23-2015, 10:35 AM   #73
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I know what I will be doing when the stock engine blows. Sub'd
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 02-23-2015, 10:58 AM   #74
Speedhead
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
On the german board I already started a "wishlist" topic for a potential full gearkit.
Will do so here, as I am sure to get more info (already just because of more users total and sure also more guys from teh "got boost" fraction)
We are taking a deep look on that topic with our specialist gearbox partner, which also supplies us with the 600 Nm + capability rally gearboxes.
Speedhead is offline   Reply With Quote
The Following User Says Thank You to Speedhead For This Useful Post:
fika84 (02-23-2015)
Old 02-23-2015, 11:10 AM   #75
Tim Radley
Drives: None
Samsonas?
What ecu is this running? Did Michael use a Motec for the build?
Tim Radley is offline   Reply With Quote
Old 02-23-2015, 11:40 AM   #76
Speedhead
Hi Tim
shhh, canīt tell everything not yet, but no, itīs not a samsonas!
and yes, itīs a M142 inside.
Plug n Play!!, which by the way also suits 15 WRX
Old 02-23-2015, 12:11 PM   #77
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Sub'd. This looks great, and can't wait to see more
Old 02-23-2015, 04:02 PM   #78
Poodles
Drives: 2015 Series.Blue
You have obviously never had them side by side did you? (FA20D and DIT)
And you apparently think the engine uses forged pistons (it doesn't)
There's more power to be had in the D4S injection system than DIT and the DIT has shown it's not as knock resistant as our motor.
But believe what you want.
Old 02-23-2015, 06:12 PM   #79
Speedhead
With regards to engineering, I prefer facts over belief
1)
Never said anything about forged internals.
The forged internals statement was done by another user.
2)
Knock resistance is not only about how much ignition advance you can apply.
The question at which BMEP levels, you can do so.
3) what hp can you get from the UNmodified D4S system?
I guess below 350 hp which is what you can get from the DIT stock system.
So I guess you should revise your statement.
+ I donīt care about the port injection system. can be retrofitted with ease to DIT.
The bigger dimesnioned DI system is what makes the sex.
=> better mixture, higher combustion chamber cooling due to more vaporation enthalpy inside the chamber.
4)
and finally... here the proof re block FA20D against DIT. With a few examples (there is more)
while it might be the same family, itīs not the same block
additionally the gearbox flange is different.
The Following 4 Users Say Thank You to Speedhead For This Useful Post:
B T (06-11-2015), chaoskaze (02-24-2015), Gords_zenith (05-25-2015), Guillaume (02-24-2015)
Old 02-23-2015, 06:58 PM   #80
Tim Radley
Drives: None
Ok well the M142 is a proper DI ecu so that means you don't need to run the original DI injector controller that comes with the GT86. Also this ecu can run port injection should someone wish to add port injection. Not really sure why they would want to as i've run DI only engines to 860bhp so far.
Gearbox mount different? Ok tell me more
Old 02-23-2015, 09:09 PM   #81
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Sub'd
Can't wait for some more details
GotBRZ1691 is offline   Reply With Quote
Old 02-24-2015, 09:35 AM   #82
FT911
Drives: 2014 BRZ Limited CBS
So many people told me it couldn't be done or it was not worth doing. This is awesome! I can't wait to see more progress.
FT911 is offline   Reply With Quote
Old 02-24-2015, 11:09 AM   #83
Koa
who told you it couldn't be done? This is one of the easier swaps to do given you had the time and resources.....
Old 02-24-2015, 11:45 AM   #84
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Anything can be done if you have $$$$. Most people say it shouldn't be done, just because of the R.O.I. For the amount of $$ you spent on the swap, you could have had a higher HP car (if #s is your thing).
-Jack Burton
FA20DIT vs FA20 D4-s? hmong337 Forced Induction 31 07-26-2020 03:11 AM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 03:15 PM
Convert NA FA20 to FA20DIT in the WRX SunkenFRS Forced Induction 21 03-15-2015 09:59 PM
FA20DIT parts glorydays Forced Induction 8 03-14-2014 06:03 PM
FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested kbye Other Vehicles & General Automotive Discussions 7 02-27-2014 10:40 AM
