Old 02-21-2015, 07:03 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
LTFT increased over 10% after oil change (new E85 user)
I was driving to Chick Fil A today and peered over at my OFT and noticed that LTFT was around 8%. Later noticed it over 10% on idle. I had normal fuel trims on my first full tank of E85 two weeks ago. I filled in my second full tank of E85 yesterday (and took it easy, under 3k, for first two miles) and performed an oil change this morning. So those two have been the only varying factors.
Here is my log: http://datazap.me/u/tracerit/new-ene...og=0&data=8-10
tracerit is offline   Reply With Quote
Old 02-21-2015, 07:30 PM   #2
steve99
Drives: FT86
No exhaust leaks ??
Stock intake ??
If stock intake and no leaks, you may have just got some high ethanol content E85, that tune will have low trims with about E70-E75.
Try giving it a bit more time, say another 10 minutes or so driving, if still high positive trims see below
since the trims are mainly positive, ie ecu is adding fuel to correct lean condition it appears you have E85 that probably close to E85, if you add 3 or 4 litres (is that about a gallon ??) of petrol to a full tank of E85, will dilute the E level and will cause it to run richer and positive fuel trims will come down a bit.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
mmmcambelsoup (02-25-2015), RavioliG (10-01-2015), tracerit (02-21-2015)
Old 02-21-2015, 07:36 PM   #3
tracerit
No exhaust leaks ??
Stock intake ??
since the trims are mainly positive, ie ecu is adding fuel to correct lean condition it appears you have E85 that probably close to E85, if you add 3 or 4 litres of petrol will dilute the E level and will cause it to run richer and positive fuel trims will come down a bit.
Intake I'm using the stock airbox with aftermarket filter and a Perrin inlet hose. Is that generally considered "stock" whereas CAI are "non stock"?
I don't believe there are any exhaust leaks, I've driven with no issues the last 1.5 years without modifying my exhaust setup in anyway. That will change when my OFH comes in though :P
Ah, I do recall adding 2oz of Lucas Ethanol Fuel COnditioner after filling up my second full tank of E85 yesterday.
Will try to add a gallon of gas tomorrow and see how the trims react. Thanks!
Old 02-21-2015, 09:05 PM   #4
dave-
Drives: 86 GT
I had the same thing happen the last couple weeks. I switched back to 98 and found the same problem even with the stock tune. We found that the overpipe to frontpipe flange was poor/damaged and leaking. While addressing that, we also found that the stock header cat had completely disintegrated. I hadn't changed anything on the car in over 6 months so that isn't always a reason.
Since fixing the exhaust leak in the frontpipe, my trims have gone back to +/- 5%.
dave- is offline   Reply With Quote
Old 02-22-2015, 05:37 PM   #5
tracerit
i hope it's nothing mechanical. but i will check those parts later next week. Are these leaks easy to identify for a novice with just four jackstands?
here's an updated datalog from an hour ago. thte first four minutes are a drive to the gas station to f ill up 1 gallon of 91octane, then a few miles drive to Carls Jr and Mcdonalds.
http://datazap.me/u/tracerit/1gal-91gas?log=0&data=1
Old 02-22-2015, 07:43 PM   #6
dave-
Drives: 86 GT
If you have the car up on stands and its safe, you could have another person give the car a few rev's while you're under the car and inspecting the various joints.
The Following User Says Thank You to dave- For This Useful Post:
tracerit (02-22-2015)
Old 02-22-2015, 07:44 PM   #7
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Do you have any WOT Pulls? I think this would help in determining if there was a problem or not.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-22-2015, 10:01 PM   #8
tracerit
This may sound silly but does WOT mean pedal to the floor or just max RPM? I"m only asking because I'd rather not floor it in say 3rd gear tonight since it just rained and i'm still a little sissy after losing control a month ago on a wet on ramp :/
Old 02-22-2015, 10:08 PM   #9
brianhj
Drives: 2017 Camaro 1SS
It means the throttle valve is fully open
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
Old 02-22-2015, 10:15 PM   #10
Phantobe
Phantobe's Avatar
No worries
WOT = Wide Open Throttle. Pedal to the floor.
Basically what you want to log is a 2nd or 3rd gear pull from about 2k RPM - Redline (7450 I think). The shorter your log the easier it is to analyze, you don't want to do a WOT pull then keep logging 5 minutes afterwards.
The Following User Says Thank You to Phantobe For This Useful Post:
Old 02-23-2015, 02:28 AM   #11
tracerit
http://datazap.me/u/tracerit/wot?log=0&data=1-2-10
just two very close WOTs tonight. Road was too wet so I figured I'd try another time.
Old 02-23-2015, 02:52 AM   #12
Phantobe
Phantobe's Avatar
On your WOT pull your AFR & fuel trims look good. I'd suggest doing a better pull tomorrow at 2k RPM, then pedal to the floor. You really only need to log from 2k rpm to redline, then pretty much stop logging. It looks like you didnt go WOT until about ~4k RPM.
It also looks like your fuel trims settled a bit below 10%.
Pretty much no FLKC or Knock Corr. as expected on E85, which is good. Everything looks to be in order.
tracerit (02-23-2015)
Old 02-23-2015, 11:32 PM   #13
tracerit
http://datazap.me/u/tracerit/wot-2nd...0&data=1-2-7-8
WOT twice in 2nd gear then 3rd gear. LTFT looks better now. Is the FLKC at +7000rpm a concern? It's -0.65 which is eerily close to -0.7 which steve99 mentioned should be investigated.
Old 02-24-2015, 12:30 AM   #14
steve99
Drives: FT86
looks good now. that little bit of minor knock is not rearly a concern just pull 0.35 to 0.7 out of the timing around the load\rpm it occurrs if your rearly kean
tracerit (02-24-2015)
Temperature Swing = Large LTFT Swing? joneze93tsi Software Tuning 5 07-30-2014 11:10 PM
Increased displacement? Shadowsong6 Engine, Exhaust, Transmission 15 02-07-2013 08:00 PM
Increased FRS MSRP price mit_peid Scion FR-S / Toyota 86 GT86 General Forum 28 12-28-2012 09:23 PM
Increased PM box capacity? Hanakuso Site Announcements / Questions / Issues 4 11-08-2012 03:55 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
