Old 02-22-2015, 03:02 AM   #1
jflogerzi
jflogerzi's Avatar
For stockish power Nitto NT01's R-Comps overkill?
I am looking getting a dedicated set of track rims and looking at NT01's because I read they are great tires, less prone to heat cycling, and are semi cheap.(700$ shipped) I figure if I can get a full season out of them, (novice driver) then it would be worth it. Looking to use these with some Kosei 17x8 K4R which are almost as light as RPF1's but I can get them for about 550$ from a buddy.
I want to save my Rota's and MPSS's for daily driving.
Old 02-22-2015, 11:11 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Overkill for the car? No way.
Overkill for for a novice driver? Absolutely.
The Following 3 Users Say Thank You to Pat For This Useful Post:
Sleepless (02-22-2015), wparsons (02-23-2015), zdr93523 (03-04-2015)
Old 02-22-2015, 05:27 PM   #3
jflogerzi
jflogerzi's Avatar
I should re-phrase this. I am looking to get better and I am staying away from FI. This season I am looking at Mainly tires, and wheels. Next season will be a AP BBK in the front. I like the idea of a fairly reliable low HP NA Track car that I can drive to and back from events. Everyone needs to start somewhere. More grip IMO can't hurt.
Old 02-22-2015, 06:52 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
My answer remains the same. If your goal is to become a better driver, more grip CAN hurt.
juliog (02-23-2015), WillRacer1jz (02-24-2015), wparsons (02-23-2015)
Old 02-22-2015, 06:55 PM   #5
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Imo, use the stock tires for a few hpde days so u get a feel for the cars limits then decide what you want first. I personally went with cooling now I'm saving for the ap bbks. From my experience stock, the cars runs hot and I mean really hot. brakes are the next Achilles heal. I iced the factory brake pads in 2 sessions. They have ways of helping that issue ie titanium shivs ect but then u run into other problems like accelerated disk wear and or boiling brake fluid. Fix those 2 then tires and suspension. Factory rides great for any novice. Anyone telling you otherwise that doesn't already have track experience is on placebo effect hard lol.
FRSfan111 is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSfan111 For This Useful Post:
CSG Mike (02-23-2015), WillRacer1jz (02-24-2015)
Old 02-22-2015, 07:03 PM   #6
dp1
driving smoother faster
Drives: Sold
They should be just fine, enjoy. I recently got NT01 in 235/40-17 with RPF1 17x9 to try after running Toyo RA1 last year. Five years tracking, one with frs. I have JRSC, AP Sprint BBK, Ohlins, LCA, oil cooler, etc. Try to get some negative camber or the outside edges will wear faster. Track pads and better brake fluid and steel brake lines will make a lot of difference. Oil cooler is also a good investment for tracking. Have fun!
dp1 is offline   Reply With Quote
The Following 2 Users Say Thank You to dp1 For This Useful Post:
Blizzard (02-23-2015), CSG Mike (02-23-2015)
Old 02-22-2015, 08:06 PM   #7
jflogerzi
jflogerzi's Avatar
Already have an oil cooler. Will be running carbotech xp10/xp8 in the rear. HQ brake fluid and ss lines. Stock radiator is fine for NA. I have white line camber bolts up front and a 1 inch drop from eibach pro springs. I feel this is a pretty damn decent setup. Only wild card is tires
2013 Series 10 FRS #553
Old 02-23-2015, 02:58 AM   #8
sw20kosh
Drives: 2013 Black FR-S
Don't stagger pad conpound.
Stock radiator is fine for FI too. The stock rads limits has yet to be determined.
Old 02-23-2015, 03:12 AM   #9
juliog
juliog's Avatar
Drives: 86
High grip tires or aero mods will provide a short term benefit but may hinder your progression. They'll increase the limits of the car and mask mistakes that would become obvious with a lower grip setup.
juliog is offline   Reply With Quote
The Following 3 Users Say Thank You to juliog For This Useful Post:
rb6freak (02-25-2015), WillRacer1jz (02-24-2015), wparsons (02-23-2015)
Old 02-23-2015, 03:58 AM   #10
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I have to disagree with "use stock tires " comments, Nitto NT01s are not real R Comp tires..they don't heat cycle out and let go at the limits like the real R comps or slicks, couple laps with the stock tires (or any Summer performance street tires) and they will feel very greasy in other words inconsistent, it's somewhat harder to learn and educate yourself when variables change
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
rice_classic (02-23-2015)
Old 02-23-2015, 10:27 AM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by glamcem View Post
...Nitto NT01s are not real R Comp tires
I disagree. I'm interested to hear why you think they are not considered real r-comps.
Old 02-23-2015, 11:14 AM   #12
wparsons
wparsons's Avatar
Stay away from super sticky street tires or r comps until you're a better/more consistent driver.
As it's been said already, adding more grip just hides driving mistakes, and when you finally get past the limit of the grippier tires you're going much faster and have less time to correct before a little oops becomes a very big one.
Learn car control on less grippy tires at safer speeds, then add grip as you progress.
flickr
BabaYaga (06-22-2015)
Old 02-23-2015, 02:12 PM   #13
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Perhaps a matter of semantics but I think some folks consider an R-Comp something like an RR/R1/R7 where there's no tread blocks for channeling water and they have a better TW rating (Stickier). The NT-01 and RA1 perform better than advertised simply because folks shave them to 4 or 3/32nd's before heading to the track.
The other reason could be that traditionally considered R-Comps have the reputation of letting go quickly or being "snappy". Think of it the slip angle graph being very pointy. Where as performance tires have a broader slip angle curve so as a driver exceeds the maximum grip there's still some grip (just less) that leave the driver some control and time to reign things in, aka; forgiving. So when folks drive a tire that's forgiving they can find themselves dismissing it as a real R-Comp. The problem with this viewpoint is that R-Comp tires, especially those that are DOT approved, have changed so dramatically over the years that their unforgiving characteristic has improved... a lot. R-Comps tires today like the Hoosier R6/7 and Toyo RR are faster than ever and aren't nearly as frightening as Rcomps of the past. However some still are like the Z214 C51.
I'd still call the NT-01/RA1 an R-comp (if it's shaved) but maybe the more accurate term is R-Comp-lite.
But like Glamcem put out there, the NT-01 is a pretty damn friendly tire at the limits and like any driver should know when playing with a proper track tire.. bring it up to temp before really laying on it.
To the OP: Take care of them, rotate them often (the tread doesn't care what direction it's traveling in when dry) and you'll get lots of life out of them.
EDIT: to the OP... Would you attempt to enter combat with an automatic weapon that you know nothing about and have no experience with? Consider that you know nothing about these tires so make sure you do your track days, or at least the first few with a good instructor and specifically talk to him/her about the tires and how to approach them from a novice perspective. Also, warm up to them slowly and pay attention to proper driving and technique and NOT GOING FAST.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
glamcem (02-23-2015)
Old 02-23-2015, 02:57 PM   #14
CSG Mike
CSG Mike's Avatar
Do you want to have a faster car or become a faster driver?
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Pat (02-23-2015), renfield90 (02-23-2015), WillRacer1jz (02-24-2015), wparsons (02-23-2015)
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et SterlingBrz Audio/Visual, Electronics, Infotainment, NAV 2 04-27-2015 11:45 PM
FS: Advan RSII w/Nitto NT01 EXCELLENT CONDITION FRS_GT Wheels and Tires 14 03-08-2015 07:55 PM
Enkei RPF1 rim width/offset for Nitto NT01 235/40-17 tire? dp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-05-2015 02:09 AM
FS (CA) $11k 99 e36 m3 with only 75,000 es (coupe, 5spd, stockish, silver w/dove)mil robot Cars for Sale/Trade 21 08-22-2013 11:05 AM
Advan AD08 - overkill? typericey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-31-2013 05:40 PM
