Old 02-13-2015, 11:15 AM   #43
350matt
Drives: toyota mr2/ Toyota GT86
Originally Posted by Freeman View Post
I havent really looked, but is this kit upgradeable? I.e. smaller pulley, or swap to a bigger blower.
according the blurb then yes, the max continuous rated speed of the charger is 20K rpm and its currently spinning at 15-16K rpm
so you could go to a smaller pulley and pick up some more boost, the current setup is what they've done all the endurance testing on so they know the engine is fine at this power level
I think Cosworth said they've run these TVS units up to 26,000 rpm as well with no issues......
350matt is offline   Reply With Quote
Old 02-13-2015, 11:26 AM   #44
350matt
Originally Posted by JerryIII View Post
Here is a video of my cosworth stage 2.0
cool
got any power figures?
Old 02-14-2015, 10:32 AM   #45
JerryIII
Drives: Subaru BRZ
their is a dyno chart on the cosworth Facebook page
JerryIII is offline   Reply With Quote
Old 02-17-2015, 03:17 PM   #46
350matt
So Ernie
got it all running yet?
Old 02-17-2015, 03:33 PM   #47
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
those numbers are almost always conservative. 03 cobra guys were afraid to run anything more than a 2.76 upper pully and now they are running that plus a huge 6 or 8lb lower and making over 500 easily with an oem M112 roots blower. If you can keep the charge temps down and you dont have huge amounts of rotor wear then keep spinning the blower.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-17-2015, 03:44 PM   #48
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
So Ernie
Did what I could do ..installed cooling system..getting ready to put the headers on... waiting on the mail from Cosworth.
up date : Crazy man in a USPS rhd jeep brought me what I was looking for from Cosworth USA...thanks a bunch Cosworth Chris.
Also much thanks to Rally sport direct customer service ,WORKS Harry, 350Matt and others I can't think of at the moment.
My first full day off is Sunday ..so I will install the Cosworth header and thermostat. By Monday it should be completed.
♠♠♠88
Ernie L is offline   Reply With Quote
Old 02-22-2015, 05:42 PM   #49
Ernie L
Ernie L's Avatar
Today I am installing a front pipe,over pipe, and headers. Hint..in order to remove the factory over pipe you need to first pull the engine and or transmission...your choice...
laying on my back on a cold concrete floor....this is the last damn time..
♠♠♠88
Old 02-22-2015, 07:17 PM   #50
Uplink
Uplink's Avatar
Drives: anything you let me
Awesome video. Just a question though, what is different between this kit and the Innovate kit that this one doesn't have the high strung whine? I'm loving the fact that this one doesn't have it.
Uplink is offline   Reply With Quote
Old 02-22-2015, 09:00 PM   #51
Ernie L
Ernie L's Avatar
You might want to contact JerryIII directly ..that was his video
♠♠♠88
Old 02-22-2015, 09:21 PM   #52
jflogerzi
jflogerzi's Avatar
Umm when I replaced my stock header and overpipe, I did neither...
Old 02-22-2015, 09:51 PM   #53
Ernie L
Ernie L's Avatar
I would hope not....I was exaggerating the difficulty to express my frustration .
♠♠♠88
Old 02-23-2015, 12:52 AM   #54
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Having owned another Positive-Displacement supercharged car (2005 Mini Cooper S) and seeing the difference it makes in sound when you change out the pulleys and "overspin" the supercharger, I've seen how much louder the whine gets when you actually push the supercharger closer to its design limits. The stock Cooper S S/C whine is barely audible, but overdrive it 17/19% and it's a screamer.
My tuner (Sharif at Forged Performance) has spent quite a bit of time talking with Cosworth about their FRS/BRZ Cosworth S/C kit. (They are actually having a meeting at his shop this Tuesday to discuss sales and future product.) They made it quite clear that their S/C has been over-designed and dialed back to about half of it's mechanical potential. I'm pretty certain that's the reason this one is rather quiet. If you want to push the S/C harder, all you have to do is change out the pulleys, but you better have your engine built and ready for the extra pressure.
killboy is offline   Reply With Quote
Old 02-23-2015, 02:55 AM   #55
350matt
Hello Ernie
to get the overpipe in you have to undo the passenger side engine mount and lift the engine on that side, there's enough flexibility in the mount ot allow th engine to be raised up
doing it on a garage floor will be hard as you need a fair bit of room underneath to swing the cosworth pipe down and up
Old 02-23-2015, 10:20 PM   #56
Uplink
Uplink's Avatar
So Ernie, here's an interesting question... once the kit is installed, are you going to keep the Cosworth tune or see if there's more power to be had with their setup by having the ECU massaged a little more?
If they only supply a canned tune that guarantees that power level to everyone that installs the kit, I'm sure individual cars could benefit from some fine tuning.
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
Cosworth BRZ/GT86 Vyk Mid-Atlantic 2 05-25-2014 01:49 AM
