#939 |
It was a pretty common issue at first so there shouldn't be a problem. If they give you a hard time just holler and I can get the number from my dealer (we are on very good terms)
#940 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
#941 | |
http://www.ft86club.com/forums/attac...2&d=1352490977
#942 | |
#943 |
They must figure the Subaru techs are a little smarter and don't need their hand held through each step.
The parts list at the top shows that whole new housings are required and give the new part number.
#944 |
Drives: Asphalt 2013 FR-S
Just went to a toyota dealer because I am having this issue on my '13 FR-S that I bought last weekend, from what I can gather, they said they were going to replace the gasket and the lens. Is this correct? Isn't the whole assembly supposed to be replaced?
#945 |
Drives: 2015 FRS Asphalt
washed n detailed my car this evening....saw some small amount of condensation on the drivers side tail light....geez, my car is only 3 months old WTF!
#946 |
Be one of the very, very rare occurrences for anything beyond the early 13s!
#947 | |
Drives: 2023 Toyota GR86 Premium
As someone who makes and sells aftermarket gaskets, I'll say that's not true. While my customer base is MORE 2013, it's not an overwhelming majority. Still lots of 2014 and 2015 models. Until the design of the trunk channel and tail light housing is changed, water will continuously assault the gasket. Depending on your area's weather or how you store your car makes you varyingly susceptible. If you're buying a newer model year, or have an older one and haven't had any condensation yet, your best bet to prevent it is to put waterproof tape over the gap between the trunk channel and the housing so the water flows over/past it instead of down into the gap and directly onto the gasket.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
#948 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
My 2014 Monogram that is almost one year old has started to get condensation in the passenger side tail light. Is this just a basic warranty repair that I can just ask them to replace the tail light assembly? I had the same problem on my 2003 Celica within 3 months of purchase and I had them replace tail lights and headlights due to condensation. I might just wait to the driver's side starts to fog as well and get them replaced at the same time. I assume I would just ask them to replace.
#949 | ||
#950 | |
Drives: BRZ DGM Limited
Good suggestion. I did this with my '13 but used black caulk. Since the car is DGM, can't even notice. |
#951 | |
#952 |
Thanks for buying them. If they failed for you, shoot me a PM and I'll get it worked out for you.
| Red tail light photoshops | OwenK | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 68 | 02-06-2013 03:48 PM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
