Old 02-20-2015, 03:22 PM   #15
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
OK maybe I am crazy...
I am aware of how unreliable Rotary Engines can be (and are).
But when they are running right...they are soooo smooth and sound great.
I Middle School, a man that I use to babysit for, he had a convertible FC RX-7. He would drop the top and pick me up to babysit his 2 year old...and I will never forget how it sounded with the top down.
He always said you had to treat it like a 2-Stroke engine and he would bitch about Apex Seals about every 2-3 years.
His was in great shape...and still had its issues...but when it was working...it was pretty sweet.
Because of this, ALL RX7's make me feel nostalgic.
Atropine is offline   Reply With Quote
The Following User Says Thank You to Atropine For This Useful Post:
radroach (02-20-2015)
Old 02-20-2015, 03:24 PM   #16
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm confused.... are you in love with the rotary? Or are you in love with the man you used to baby sit for?
-Jack Burton
Old 02-20-2015, 03:27 PM   #17
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
So much rotary hate... I miss mine more everyday. Though I see why new ones cannot be made in today's regulations/MPG. I would pay the premium for it though.
I really wish we could have seen their 16X evolve from more than just concept, but oh well.
malave7567 is offline   Reply With Quote
Old 02-20-2015, 03:30 PM   #18
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
We need an FE RX7 so badly. I still love the FD sooo much.
Sideways&Smiling is offline   Reply With Quote
Old 02-20-2015, 03:34 PM   #19
Atropine
The car...maybe you are confused about your sexuality?
Old 02-20-2015, 03:39 PM   #20
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I've always wanted and FD (just never the right time) and I almost bought an RX8 instead of my FRS.
Fuel economy was the concern for me at the time, as well as the overall size of the vehicle (too big).
Some days I wonder what could have been.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 02-20-2015, 05:23 PM   #21
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If I had more money than I knew what to do with, sure Id buy myself a FD or FC and build it.
Old 02-20-2015, 06:12 PM   #22
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
I always described my FC like dating a stripper. It will wreck your house, bang your freinds and steal your money, but every now and then it will bang the shit out of you and you almost forget all that shit it put you through.
All the bullshit of taking care of it was worth it when I was ripping down the highway like a rabid chainsaw.
The whole "rotaries aren't reliable" thing is a specious argument. My engine ran like a Swiss watch. All my problems were caused by the sketchy wiring in the FC. The engine itself, when the car's wiring was working halfway correctly never let me down. That is because, ahem, I KNOW HOW TO FUCKING MAINTAIN THE DAMNED THING!
Fire it up, don't let it flood. Again, not an engine problem, that's a computer problem. Flood out an old Chevy V8 and see how that works for you. Not a "rotary thing."
Warm it up before you start pushing on it. Again, start beating on your piston engine when it's cold; not a "rotary thing."
Run non-synthetic oil because the engine oil is also injected into the combustion chambers to lube your rotor seals. What do you think the oil splashed onto your cylinders is doing for your piston rings? True, you need to check your oil regularly, but do you just assume your oil level in your piston engine is adequate between changes? I don't. I check any engine regularly including my rotary and the consumption is negligible. My truck eats more because of aeration and blowing it out through the PCV. Compression is good, the crank just slaps through standing oil and causes problem. THAT is a BS design, but I'm not here to slam Daihatsu.
Premixing, well, that's a subject of much debate within the rotary community. Some say it's not necessary, some say it's all you should run, I'm in the middle. I kept my OMP and added a shot of Motul to the gas. I'm a big 2 stroke lover too, though, so, again, premixing is not some mysterious thing for me. Here's all it is. I have my bottle of oil and my little 100cc graduated cylinder and spend the grand total of an extra minute measuring oil out and dumping that in before filling it up. Ever dump a bottle of octane boost or injector cleaner into the tank of your piston car? It's that damned difficult.
Don't overheat a rotary. Hey, guess what, don't overheat any engine. Duh.
Don't lean out a rotary. It blows seals. Detonation kills any motor. You know what a blown apex seal is, a broken piston ring. No motor will live forever if you are denying it the correct mixture and timing for the boost you are running.
Rotaries use a lot of fuel, true, oh so true. That's a legit deal breaker for a lot of people.
Rotaries are a different animal than a piston engine and require a person to start at zero and learn a new concept. That is also a legit deal breaker for a lot of people.
In the end, though, it's a machine and it works until you don't do what you are supposed to do then it breaks. It's not the machine's fault if the knucklehead operator abuses it.
Mazda didn't win LeMans in 91 because their car was the fastest, it wasn't. They won because the faster cars broke, the piston cars broke. Now, it was silly things that broke, but using rotary hater "logic" the fact that they broke is all that matters, they broke, they had piston engines so piston engines are unreliable.
I don't actually believe that. I only use it to illustrate the silliness of the bandwagon misinformed hater.
How can a rotary fan be mad when our main detractors are guys like this?
[ame="https://www.youtube.com/watch?v=r3peVDKV6OE"]Parody: Rotary vs Piston Engine Explained for Dummies - YouTube[/ame]
It's more like this, guy.
[ame="https://www.youtube.com/watch?v=DOw_3wUmljg"]750hp 3 Rotor RX7 vs GT-R vs Blown Camaro - YouTube[/ame]
Oh, and by the way. How many Japanese manufacturers have won LeMans? Yeah.
[ame="http://en.wikipedia.org/wiki/List_of_24_Hours_of_Le_Mans_winners"]List of 24 Hours of Le Mans winners - Wikipedia, the free encyclopedia[/ame]
The Following 6 Users Say Thank You to themadscientist For This Useful Post:
acro (02-20-2015), Atropine (02-20-2015), FT911 (02-27-2015), Koa (02-21-2015), reni (02-20-2015), Ultramaroon (02-21-2015)
Old 02-20-2015, 06:34 PM   #23
tahdizzle
So elite I'm 1338
Your entire position on "how to properly operate a Rotary Engine" and the comparisons to a carburated v8 is apples and oranges.
-Jack Burton
Old 02-20-2015, 06:36 PM   #24
themadscientist
Hotlink Terrorist
That you disagree only adds weight. Have you met you?
Old 02-20-2015, 06:41 PM   #25
tahdizzle
So elite I'm 1338
You are a fanboi. Get over it.
I never said you were incorrect. Anything properly maintained and operated will do exactly what its supposed to do.
I said your comparison is apples and oranges.
The fact that you get so defensive when anyone disagrees with you or you THINK they disagree with you proves that you have self esteem problems and are compensating for something.
I've met Hundreds of guys just like you when I served my country. You're nothing to waste time on.
-Jack Burton
Old 02-20-2015, 06:46 PM   #26
themadscientist
Hotlink Terrorist
No, just you, You've earned it. Not sure what your serving your country reference is all about, but I'm sure in your mind it's relevant.
Old 02-20-2015, 06:47 PM   #27
tahdizzle
So elite I'm 1338
Listen, you can take you're thread wherever you want. But Rotary is dead, let it die, move on.
-Jack Burton
Old 02-20-2015, 06:51 PM   #28
themadscientist
Hotlink Terrorist
Rotary is, pretty much, dead. Then again, so is the Skyline as far as I'm concerned and cars that just do what you tell them to do.
Eric's BRZ - A motorsports engineers perspective eric6 Member's Car Journals 223 07-14-2015 11:15 AM
For you engineers out there... cdrazic93 Off-Topic Lounge [WARNING: NO POLITICS] 32 02-05-2015 01:16 PM
Engineers Certificate needed for turbo kit? happytimetom Forced Induction 18 02-23-2014 05:47 PM
Rumor: Mazda Engineers pushing for more RWD models Allch Chcar Other Vehicles & General Automotive Discussions 32 10-15-2013 03:57 PM
Software and electrical engineers look here jonbonazza Engine, Exhaust, Transmission 6 09-15-2013 11:06 PM
