#57 |
Drives: Firestorm FR-S
I want that kit on my car ! The price is really good but idk how long the turbo will last .
| The Following User Says Thank You to j0hnnybk01 For This Useful Post: | hmong337 (12-05-2014) |
#58 | |
The CX turbos are fine in general, and the FRS/BRZ kit comes with one of their better ball bearing turbos. I know people with 20k+ hard miles at 18-20psi on the same unit. It will last
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | hmong337 (12-06-2014) |
#59 |
Nice ! if that's the case i might bite the bullet on the kit early next year . how is the boost response ? What rpm is full boost ?
#60 |
Drives: FR-S 10 series
@Amir Ghadiri i just picked up some rpf1's 18x9.5 squared.. and was contemplating on tire size. I was going to run 245/35/18 (on ST coils). Then I saw your build with 265/35/18 (sex). But what I want to know is, did you need any fender work or cutting to make that fit? Do you rub on dips?
#61 |
Hey, sorry I never noticed this post! Boost response is actually really good, I'll be at full boost 10psi by 2.7-3k. I've had the kit on the car for a while now and I'm still very happy with it!
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | pward08 (03-25-2018) |
#62 | |
With stock tie rods front, you won't rub on the inside. With extended tie rods, you will rub on the inside. I'm personally running 15mm spacers on the front so I'm good either way. |
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | mmmcambelsoup (02-20-2015) |
#63 |
So the car has been smoking ALOT out of the FBM Catch can lately, so I already knew we had problems. I removed all turbo components to have them ceramic coated, and while I had the engine bay clear I lifted the motor to check compression. Upon testing I found compression at 140,170,160,150 PSI. Oh no!
![]() Time for a rebuild! These parts will be going in then we'll tune for 18PSI pump. JE Pistons 10.5:1 Brian Crower Connecting Rods - I-Beam Extreme w/ARP Custom Age 625+ GSC Power-Division Beehive Spring Kit ARP Head Studs DeatschWerks 900cc Injectors DeatschWerks DW65C Fuel Pump Stay tuned! Last edited by Amir Ghadiri; 03-04-2015 at 08:30 PM. |
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | R2RO (02-21-2015) |
#64 |
Also, I just picked up this Porsche 944 (1985.5 w/ 112K miles) this past Sunday. I'm going to build this as a cheap, bare bones AutoX/time attack car. Plans are as follow:
Stripped interior Aluminum Dash Kirkey Aluminum Bucket Seats AC delete New suspension Stay tuned for updates on this as well, I'll update it on this thread. |
#65 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
How much power were you running till you started losing compression? It just seems like these motors can't take much boost for very long. Do you run the car hard on track days or is it primarily a street car being blasted here and there?
#66 | |
All good, lol I ended up w/ 245/35/18 already. Def doing 265 next time around to make it more comfortable of a ride and flush. I appreciate the knowledge drop
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
#67 | |
Lowered. Boosted. Jdm. Its so shiny it hurts my eyes
38 offset right? Depending on how close to 0 camber you want to be you may want to go with a 255 instead of a 265. If you're running stock control arms anyways then stick with the 265 as you'll have no camber adjustments and be stuck with some negative rear camber.
#68 | |
300 WHP on 10 PSI boost. Also, I had a boost spike once a few months ago (27psi) and that is when I started to lose compression. That combined with very hard track (drift) use with very high temperatures contributed to the failure. At the time, the car had a FBM Radiator, FBM aluminum fan shroud, and slim fans. Now it also has an engine oil cooler, but the damage has already been done.
| The Following User Says Thank You to Amir Ghadiri For This Useful Post: | hmong337 (02-20-2015) |
#69 | |
You hit the nail on the head, stock camber arms.. For now I dont mind the natural negative camber, so 265's it is. My rpf1's are the same exact specs as yours in SBC. Do you know if the wider tire 265>245 makes for a smoother ride?
IG: @Lucky_FatPat
#70 | |
I've never had 245's on my car so I can't say for certain, however I'm almost positive the answer is yes. If you're running the same suspension on both tire sizes, I would assume that you having a larger contact patch would contribute to a smoother ride. I doubt it would be that noticeable though. On a side note, my friend German has the same wheels as us and he went from 245 to 265 and is definitely happier with the 265's.
| How Shiny Are the Work Kiwami GTS Silver | bobsacamenoh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 11-01-2014 08:34 PM |
| how to make polyurethane shiny | DarkestBuddha | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 05-04-2014 01:26 AM |
| FR-S? BRZ? Premium? Limited? 10 Series? My brain hurts! | oldpueblo | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 01-02-2014 10:14 PM |
| Winter hurts. | Superhatch | BRZ First-Gen (2012+) — General Topics | 33 | 02-07-2013 08:29 PM |
| shiny wheels | jarviz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 08-21-2012 03:23 PM |
