Old 02-19-2015, 10:09 AM   #15
OkieSnuffBox
Drives: '23 BRZ Limited
I'm debating this as well now, I know once tuned there isn't that big a difference between the 3.
I really like the Skunk/Grimmspeed setups, but don't want it to interfere with the oil cooler. I like the Perrin, but it looks like (correct me if I'm wrong) I'll be pulling the bumper 1+ times per year to clean it?
Old 02-19-2015, 12:38 PM   #16
sachu
Drives: rocketship
The three runs were,
1. Installed and basically rolled it on dyno and ran it with Stock tune, engine cold with intake ( keep in mind it only did that one run and settled to 190 range with subsequent two more runs )
2. Then my MAF scaled “hot” . With the skunk2 insert on
3. then back to stock tune with “hot” engine (the last run of last night before rolling it off the dyno)
sachu is offline   Reply With Quote
Old 02-19-2015, 05:40 PM   #17
Turdinator
Señor Member
Turdinator's Avatar
If you are tuned why leave the insert in there?
1974 TA22 Celica
2013 86 GT
Old 02-19-2015, 05:55 PM   #18
sachu
Drives: rocketship
MAF needed to be scaled even with the insert in there.
The car wouldn't start/idle without the insert present. So chose to first test it out with insert in the intake.
Will be taking the car back for more dyno time to tune without the insert in.
By the way, this saturday driving up to Drift offfice to get a baseline done on Bob's dynojet to see if the curves corroborate on the stock tune, which is what I am running right now.
Old 02-19-2015, 06:09 PM   #19
TorqueMan777
TorqueMan777's Avatar
Drives: 13 BRZ, 18 STI
Do you have AFRs for those dyno runs? And what other mods are you running, if any?
Racecar spelled backwards is racecaR, because RacecaR
TorqueMan777 is offline   Reply With Quote
Old 02-19-2015, 06:25 PM   #20
sachu
Drives: rocketship
requested the dyno with AFR readings for final MAF scaled run and the final run on stock tune. Will post up when i have them.
mods besides the Skunk2 powerbox:
Skunk2 EL catless header
Nameless FP/OP catted
Perrin 2.5 inch resonated exhuast
Old 02-21-2015, 06:25 PM   #21
sachu
Drives: rocketship
On drift. Office dyno.
Thanks bob
Main difference is smoothing. Original with smoothing at 5 comes out to 188
Old 02-22-2015, 03:22 AM   #22
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Waiting for RacerX. 8.4hp and 6.5ft/lbs gain without tune so far.
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
