Old 02-19-2015, 11:29 AM   #113
Koa
I have realized that without a wideband o2 sensor, I realistically cannot fine tune the MAF scale.
Also, I just noticed that I have a small leak at the axleback portion of my CBE. It's a FT86SF V2 single exit with a Vband clamp that connects the midpipe to the muffler portion. The Vband got crushed apparently on a nasty hit. Got a new clamp on the way and I'll monitor how that changes things
I don't know how that's going to affect the tune. @steve99 , @Shiv@Openflash , does a small leak affect things significantly?
Old 02-19-2015, 12:06 PM   #114
steve99
Drives: FT86
If the leak is way past the 02 sensors it will not effect the 02 sensor reading.
Its generally only leaks at header gaskets or 02 sensors or cracked header that will effect readings or the connection to overpipe. Anything past overpipe is unlikely to effect reading.
The front 02 sensor is good enough for NA boosted you would definitely need wide-band due much richer afr under boost.
The oft tunes have rescaled the front 02 sensor to about 11.3 afr from memory. stock scaling is 12.1 i think.
Koa (02-19-2015)
Old 02-19-2015, 04:18 PM   #115
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Got my answer back from OF: No custom tune for the GS intake is available for stage 2. So, just use the OTS Stage 2 map if you have a header or wait for this custom made one here
Mad1723 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad1723 For This Useful Post:
FrostedFlakes (02-20-2015), Koa (02-19-2015)
Old 02-19-2015, 09:38 PM   #116
Sauce
Drives:
w
If your stage 1 tune its easy to make your own
their are only two tables different between grimspeed stage 1 and original v2xx oft stage1 tune
tables are
PRIMARY OL FUEL TABLE
MAF SCALING
see 700G rom zip file attached, use romraider to compare this one to the oft sage1 700G map and you will see. use the definitions from oft site for V2.xxx tunes.
then just copy and paste those two changed tables into your rom calid map
WARNING: This is only for stage1 oft maps. Stage 2 maps both petrol and E85 have offset maf scaling and different PRIMARY OL FUEL TABLES. You need to do a bit more work to get the grimspeed intake working correctly on stage 2 maps
enjoy your grimspeed intake tune
Will the values be the same regardless of what calid one has? For example I'm on Stage 1 B01D tune, could I take the values from your 700G map and use it without issue, or would I need a B01D map for the GS intake?
Sauce is offline   Reply With Quote
Old 02-19-2015, 09:51 PM   #117
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
It should ballpark you nicely Please do a log after driving around for a bit @ 60F IATs (if possible) so we can compare. I can also help if you never re-scaled your MAF before. @vgi 's program is sooo nice.
http://www.datazap.me/u/trurace/stg2-uel-e85-grim-v1
This is a log after I rescaled off of your maf scale. This was around 80F though, which isn't bad for around here. Days like this are rare in Florida.
TruRace is offline   Reply With Quote
The Following User Says Thank You to TruRace For This Useful Post:
Koa (02-19-2015)
Old 02-19-2015, 10:47 PM   #118
Koa
I'm starting to think my IATs are way too low for good tuning.. because in traffic they climb to 100+, so it skews my trims if I'm in bad enough stop and go. I am exploring methods on zeroing out the iat comp table and going from there, but need more time and attempts to learn about it
Old 02-19-2015, 10:59 PM   #119
steve99
Drives: FT86
The oft maps use same maf scaling in all stage 1 maps
All stage 2 petrol maps have same maf scaling
regardless of calid
but the maf scaling between stage 1 & 2 maps and E85 maps is different.
ie you can take scaling from a stage 1 700G and put it in a stage 1 B01D
Old 02-20-2015, 10:19 AM   #120
FrostedFlakes
Drives: 2013 Raven FRS
Thanks for the update. I was really hoping to see the potential of the Grimm combination with ofh. Especially if all the claim it is one of the better headers out there (I still believe it to be true in terms of bends and flows) I guess we will have to stick to the one size fits all stage 2 for now.
FrostedFlakes is offline   Reply With Quote
Old 02-20-2015, 10:47 AM   #121
Koa
Did you see my post containing a MAF rescale for the G/S Intake + OFH?
This is most of the work that needs to be done to have the v2.06 tune play nicely with the intake and header combo.
A side note, off-the-shelf tunes are often needing a rescale or tweak to get to work with your system, even with identical parts setups. This has many variables to it, but main variables are fuel quality and environmental conditions. Just some food for thought, hope you try it out. Let me know if you need any help
The Following User Says Thank You to Koa For This Useful Post:
FrostedFlakes (02-21-2015)
Old 02-20-2015, 01:11 PM   #122
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
It's been a while since I've flashed with my OFT so can someone refresh my memory?
When I go to install the tunefile for the Grimmspeed CAI, do I need to reflash to stock first and then install the file for the GS CAI, or will the OFT allow me to flash the GS CAI file over the tune I already have installed?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 02-20-2015, 02:00 PM   #123
steve99
Drives: FT86
Just flash the new tune, all flash devices erase the ecu before flashing.
phobos512 (02-20-2015)
Old 02-20-2015, 03:15 PM   #124
phobos512
phobos512's Avatar
Ok awesome thanks!
Old 02-26-2015, 12:51 PM   #125
Koa
fixed the exhaust leak and, this may not be the case, but no more IAM drop in traffic and no FLKC or knock corr. None, not even tip-in. Could the leak have been that significant to throw things off?
I'll take a log tonight but after 3 days with the fix, IAM has not dropped to .88 once. It would do that every day coming home w/ traffic. Mixed weather conditions as well past few days so there's that
Old 02-26-2015, 09:32 PM   #126
steve99
Drives: FT86
yes exhaust leaks at header cause 02 reading to be in correct high fuel trims and incorrect afr results if it gous lean it will cause knock and iam to drop.
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
