Old 02-18-2015, 02:58 PM   #43
Foobar
SLO NO MO
Foobar's Avatar
I've got snows on mine here in NY. I can drive fine in 4 inches, but from a complete stop on an incline? No, the car is too light for that, gotta find an alternate route. Can I drive it with the confidence of summer tires in July? No, it's very easy to gas the tail out on snow.
This is on Blizzak LM60's with a Vortech SC.
The WS Blizzak would perform better I'm sure, but I didn't want to give up too much dry performance.
Old 02-18-2015, 02:59 PM   #44
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
Originally Posted by BRZnut View Post
YIKES!!!!!
But, don't do what I did....
I did not want to have to change tires each season so I tired to take the easy way out and just get all season Michelins. Still sucks in the snow.
Matter of fact, if there is 4 inches of snow on the road and I have all the traction control stuff on, the car refuses to go. I have to turn all the traction stuff off to get moving by having the tires just spin and spin to push me along.
For those with winter tires, do you have this issue?? I really hate my BRZ in the snow!
I've got Xi3's on and have no issues in the snow. The TCS and VSC scare the shit out of me in the snow so I turn them off immediately.
Tgionet is offline   Reply With Quote
The Following 2 Users Say Thank You to Tgionet For This Useful Post:
Dream20b (02-18-2015), Pkush (02-27-2015)
Old 02-18-2015, 03:09 PM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Summer tires are why I drove several hundred miles further in the MR2 when I picked it up in Portland. There was no way in hell I was taking the car onto snow covered roads with summer tires.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-18-2015, 03:30 PM   #46
sledheadguy
Drives: 2014 FRS firestorm red (MT)
bridgestone blizzaks....installed when bought car. Amazing traction with this tire
sledheadguy is offline   Reply With Quote
Old 02-18-2015, 03:32 PM   #47
tomkozski
Drives: 2017 WRB BRZ w/ PP
Even if it's dry outside, the stock tires aren't meant to be driven in temps below 45F. The tire compound isn't designed for those temperatures. In freezing temps, the Primacys (or any summer tire) become rock hard and provide very little grip. Sure, most of us can get the car moving, but the whole point of having good tires is to have good grip in emergency situations - when you need to brake all of a sudden, or swerve to avoid that deer/car/person in the road. If you drive on the Primacys or any summer tire in below freezing temperatures, you're putting yourself and everyone else around you at risk. In some European countries, insurance will not cover you if you crash in the winter and are found to have summer tires on the car, even if the accident is not your fault.
tomkozski is offline   Reply With Quote
The Following 2 Users Say Thank You to tomkozski For This Useful Post:
Lo (02-25-2015), RobertPaulson (02-18-2015)
Old 02-18-2015, 10:16 PM   #48
BRZnut
Drives: BRZ DGM Limited
Ya , I agree. Never sure in the snow what they are doing other than seeming to bog the car down.
On reason I did not get snow tires is that most of the time our roads are dry with no snow in the winter. Not sure how the car would handle with snow tires and dry snowless roads.
Old 02-18-2015, 10:17 PM   #49
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
we run blizzaks in alaska here, try some
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 02-18-2015, 11:44 PM   #50
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Winter tires have more grip on dry pavement than summer tires when the temperature drops below 40 degrees. Then definitely give sloppy handling, but you will stop shorter. The rubber compound used on summer tires simply gets too hard in cold winter weather to offer much grip. Winter tires are super soft, so you get squishy handling but it also means the rubber is still soft at low temperatures, and is therefore able to grip the road.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
HunterGreene (02-19-2015), phrosty (02-19-2015)
Old 02-19-2015, 12:32 AM   #51
phrosty
This. Unless the tires have studs (illegal in many places due to road damage), you're not buying snow tires. You're buying winter tires.
Winter tires do help in snow, but it's not enough to let you gas it or even safely drive at posted speeds if there's any good amount of snow on the ground. Their real benefit is when it's dry. It was 8°F and dry tonight as I drove home from work and my winter tires have more grip than the stock Primacy HPs do in the summer.
phrosty is offline   Reply With Quote
Old 02-19-2015, 11:56 AM   #52
Tgionet
SPACESHIP
Tgionet's Avatar
They (Xi3) have similar grip in the dry <40F to the stocks in optimal conditions with less noise and a better ride.
Old 02-19-2015, 09:31 PM   #53
BRZnut
Good to know...
Old 02-20-2015, 06:20 AM   #54
Itzed
Drives: 2014 BRZ Limited
I have snow tires and concur you need them. However, a friend of mine at work who was looking out for me one snowy day, sent me this link that I thoughtt was pretty cool:
http://www.zipgripgo.com
Itzed is offline   Reply With Quote
Old 02-20-2015, 10:00 AM   #55
Ursam
Drives: 2014 SSM BRZ
We don't usually get much snow here in North Carolina, but we did this week. I kept the BRZ in the garage, and drove the mini-van to work. I'm happy to have that option. Don't like either the snow or the salt for the BRZ.
Ursam is offline   Reply With Quote
Old 02-24-2015, 04:51 PM   #56
sunset_blvd
sunset_blvd's Avatar
Drives: Lava 2014 Scion FRS
Originally Posted by was385 View Post
Snow tires. Get them or leave the car at home when it snows.
This, also put something heavy in your trunk. With the stability control that is standard on this car, you shouldn't have any more issues.
sunset_blvd is offline   Reply With Quote
Brand new FRS, no snow/sport mode?? What the hell?? Sambo FRS Scion FR-S / Toyota 86 GT86 General Forum 54 01-06-2015 12:51 AM
The hell is BMW doing? dem00n Other Vehicles & General Automotive Discussions 39 01-27-2014 11:15 AM
snow....starting to like snow! brzr CANADA 19 01-23-2014 12:10 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
Hell yea!! _F-R-S_ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-23-2012 08:46 PM
