Old 02-16-2015, 10:47 PM   #169
Nico TURBO
Drives: 1986 Subaru LEONE TURBO
so decided to improve the handling of the car a bit better and I noticed the 2015 uses rear spherical bearings. I had a machine shop shave them down each side 1.5mm and made a spacer to take up the slack for pressing them in my lower suspension mount in the rear of my coil overs
locally I found a nice set of ES-Tarmac ENKEI wheels 5x100 16x8 et45 14lbs wheels, super light weight compared to my braid wheels
started to build the spare motor, Ej22T stock crank, 10mm oil pump, ACL bearings, Carrillo Rods, Wiseco pistons, cometic head gaskets, ARP Custom Age 625+, V9 STi heads, killer b pick up, and allot of new factory case bolts and plugs gaskets
Nico TURBO is offline   Reply With Quote
The Following User Says Thank You to Nico TURBO For This Useful Post:
AznKirby (02-16-2015)
Old 02-16-2015, 11:41 PM   #170
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Sweet! Updates!!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Nico TURBO (02-18-2015)
Old 02-18-2015, 07:18 PM   #171
Nico TURBO
Originally Posted by AznKirby View Post
Sweet! Updates!!
thank you... started the handling aspect part of the car now, found a sweet place near me that does aerospace machine shop work..
so this is what else I'm working on at the moment along with the lower pillow ball bushing for my coil overs, I decided to get a one piece unit made so I can get rid of the rubber spacers and all that mess..
this is a prototype unit to test on the car then i can get them made up once it fits ok.
black is 80s strut mount, green is coil over mount.. needs a bit more work to be perfect fit
also found the rear garnish in japan for my car, maybe ill put it on. to many holes to drill in a clean car.
Old 02-18-2015, 07:25 PM   #172
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
This is an amazing build!
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following User Says Thank You to Mr.Impreza For This Useful Post:
Nico TURBO (03-09-2015)
Old 02-18-2015, 10:39 PM   #173
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Been too long since the last update, this should hold me off until the next time
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 02-19-2015, 12:04 AM   #174
Kojiro
Drives: 2014 Black BRZ Limited
Were you on RS25 before? Felt like I've seen this build before. Regardless it's still awesome and went through all the posts. Subbed for more!
Kojiro is offline   Reply With Quote
The Following User Says Thank You to Kojiro For This Useful Post:
Old 02-19-2015, 12:36 AM   #175
inertia
inertia's Avatar
Awesome build mate!
inertia is offline   Reply With Quote
The Following User Says Thank You to inertia For This Useful Post:
Old 03-09-2015, 01:21 AM   #176
Nico TURBO
lol ya been working on the wagon version like this... this one is getting the new cnc fancy parts...
next is the cnc control arm
subaru 80's old meets subaru 2012 new moulded into one...
cnc billet aluminium & anodized black, now I can add a pillow ball at the top mount like the front..
next project is cnc billet aluminium front control arms with pillow ball and 1' longer so I can get some larger cv axles to with stand the abuse I am about to put down. cv axles will be new age subaru length.
BigFatFlip (03-09-2015)
Old 03-25-2015, 09:53 PM   #177
Nico TURBO
so this is my rear top hats bolted up with spherical bearings.. the lower cups also have 2015 STi spherical bearings made buy subaru which I needed to make a spacer.
I decide to get serious with my coil-overs to make this car handle like a top notch missile and I got the GR STi Ohlins road & track set.. I have to do two mod's to make them fit perfect which is the lower rear bushing mount will be made new with a STi spherical bearing and drill the front top plates to early subaru size like leone/gc8. my reactions from just holding the ohlins is how light weight they are WOW half the weight of my hsd..
like to thank jake @ ohlins usa for hooking me up with the extend clickers also !.. there on the way.
BigFatFlip (03-26-2015)
Old 03-25-2015, 11:36 PM   #178
AznKirby
Are you 20/20?
AznKirby's Avatar
Going from HSD to Ohlins is one hell of an upgrade!!
2014 FR-S Monogram
IG: @MonKehC
Nico TURBO (04-01-2015)
Old 03-25-2015, 11:56 PM   #179
ryoma
ryoma's Avatar
dude, I love what you have done to the car! nice job man.
The Following User Says Thank You to ryoma For This Useful Post:
Old 03-26-2015, 01:54 PM   #180
BigFatFlip
BigFatFlip's Avatar
I knew your billet top-mounts were destined for something greater. The ohlins are beautiful!
Old 03-26-2015, 02:29 PM   #181
srizzors25
Daedalus Moto
srizzors25's Avatar
Goddamn just flipped through all pages. This build is so awesome. Like so awesome
The Following User Says Thank You to srizzors25 For This Useful Post:
Old 03-26-2015, 02:45 PM   #182
DGM33
DGM33's Avatar
Drives: Lightning Red 2015 BRZ;F150 Limited
[/QUOTE]
Love this whole thread! Nice touch with the Canada Dry vending machine!
DGM33 is offline   Reply With Quote
The Following User Says Thank You to DGM33 For This Useful Post:
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 01:52 PM
My 1986 Toyota corolla!! El Diablito Other Vehicles & General Automotive Discussions 15 07-26-2012 01:34 AM
Fr-s with subaru turbo? Afdad120108 Engine, Exhaust, Transmission 46 05-19-2012 05:10 AM
Assumption: Subaru=Turbo / Scion=NA ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 159 06-20-2011 03:28 PM
