Old 02-18-2015, 06:26 PM   #43
s30series
Drives: 2015 BRZ Series.Blue
Only thing keeping me from buying it the nano-second it comes out is the fact that it will render my mishimoto catch can useless :-(
s30series is offline
The Following User Says Thank You to s30series For This Useful Post:
quicksilver30 (02-18-2015)
Old 02-18-2015, 08:10 PM   #44
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why is that?
Calum is offline
Old 02-18-2015, 08:23 PM   #45
zooki
Drives: waiting on a 2021...
Not too up on current manifold design, but having a plenum twice the displacement of the entire motor over each side wouldn't cause a lag in response? Especially with those short runners into the heads? Most of the intakes I've seen use smaller plenums for quicker response, and larger plenums for more high RPM power. Unless it's FI, then you just crank the wastegate shut... LOL
Anyway, can't wait to see the testing. 👍
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline
Old 02-18-2015, 09:14 PM   #46
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Anyway, can't wait to see the testing. ��
Looking at the design images, each cylinder gets it's own velocity stack. So I would think that such a large volume would serve two purposes.
First, at higher RPMs it would likely minimize the interference between the two cylinders, allowing the velocity stack tuning to be more effective.
Second, the large volume would shift the intake's natural resonance towards the low end, giving some low-end help where the velocity stacks would be less efficient.
But this is pure armchair engineering with just enough knowledge backing it up to be dangerous. So I'm likely way off base. This intake looks fantastic. My only regret is that the supercharger I've got replaces the intake. Ah well. Can't wait to see these in the wild.
Draco-REX is offline
Old 02-19-2015, 03:01 AM   #47
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
*raises hand*
Ok, I don't know sh*t about this sort of stuff but I thought that in this case the plenum was there to give the velocity stack a relatively clean volume of air. That is, the plenum emulates being free to atmosphere like in the pic.
Captain Snooze is offline
Old 02-19-2015, 09:34 PM   #48
Draco-REX
Corner Junkie
Draco-REX's Avatar
*raises hand*
Attachment 102970
That's the first point I made. The large volume would let higher frequency pulses disperse and help the two stacks be more independent.
The Following User Says Thank You to Draco-REX For This Useful Post:
Captain Snooze (02-19-2015)
Old 02-19-2015, 10:21 PM   #49
Captain Snooze
Drives: Red Herring
Ahhh... my apologies. I read that but didn't understand.
Old 02-20-2015, 09:35 AM   #50
s30series
Originally Posted by Calum View Post
Why is that?
Well, i should say the kit somewhat useless. Doesn't look like there is a PCV vent in the factory location, thus making the mishimoto supplied hose useless.....
Actually I dont see a PCV connection at all?
Old 02-20-2015, 09:39 AM   #51
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
All connections are on the bottom side of the two plenums.
eric6 is offline
The Following User Says Thank You to eric6 For This Useful Post:
Calum (02-20-2015)
Old 02-20-2015, 09:54 AM   #52
Calum
That Guy
Would you get more even flow from a vacuum source nearer the throttle body? I'm guessing the map sensor and the evap system would have a fit from pulsating vacuum...?
Calum is offline
Old 02-20-2015, 09:58 AM   #53
Porcupint
Drives: 13 GBS BRZ
But at least you recognize and admit it unlike a lot of people.
Porcupint is offline
Old 02-20-2015, 10:09 AM   #54
eric6
eric6's Avatar
Possibly. The map sensor and ports are on the plenum floor, which is over an inch below the smallest bellhorn height. I do not think they will see much pulsating. They are also extremely close to the crossover tube which should help harmonize things between the two plenums.
eric6 is offline
Calum (02-20-2015)
Old 02-20-2015, 08:08 PM   #55
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Okay... So sick of waiting... I'm going to ask the only important question in this thread: has my order shipped yet?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
Calum (02-20-2015), Decay107 (02-20-2015)
Old 02-20-2015, 08:36 PM   #56
2much
I wanna go fast
Drives: 2013 FR-S 6MT
has final production even started?
2much is offline
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
