#2507 | |
Once you trust they know where to be and when, they need to learn car control with the nannies off. Ideally give them time on a skidpad to figure it out in a safer place, but that's not always an option. Kinda related... any chance you'll be at the OTA event at Calabogie, hosted by MCO (August 1st/2nd)?
#2508 |
Thanks everyone for the advice. I will probably end up getting insurance just for peace of mind. I am pretty comfortable with the car, and my own limits. I think I'll probably start with everything on, and just start turning things off when I feel more confident with the course. Thunderhill seems pretty forgiving.
I'm still on the fence about camber bolts though. It makes sense how they would be useful, but would it really be necessary for someone who only goes to the track a couple times in a year? I would like to keep my car as stock as possible (aside from pads, fluids, tires, etc.). I also worry about the adjustment process with the bolts. I dont trust myself to make those kinds of changes to the suspension. Would it be beneficial to get an alignment on a stock car, or are they pretty dialed in from the factory? |
#2509 |
Adding bolts is easy, but you will need to get an alignment done if you do add them.
My two cents would be to get an alignment anyway, so adding the bolts at the same time would be easy for the shop to do. |
#2511 | |
This is the wear/chunking I was seeing on my front tires without camber bolts (after a few track days on these tires):
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | funwheeldrive (02-18-2015) |
#2512 |
Drives: 2013 Subaru BRZ
AP Racing Pad Setup
Mike @ CSG..
Thanks very much for this thread, it has provided much help in setting up my car. I'm getting ready to purchase the AP Racing Spring kit... And I need a little help with the Pad setup, before I order. I'll need 2 sets of pads, street pads & track pads.. BRZ My wife and I have been heading out to Sebring about 5 or 6 weekends per year. Car sees about 3.5 hrs/day on the track. We have been running Cobalt XR2 pads, with RBF660 & TFWorks brake ducts, but the brakes are still smoking after a 30 min session. Definitely, time for the brake upgrade. We are both, for the most part Novices. Thanks, Michael |
#2513 |
Drives: 2015 Raven FRS
My experience, I wore out a set of NT01 tires in 5 track days with out them!
#2514 | |
Drives: 2017 BRZ
Have you read this? If not, do so. I think it has the answers and more. C |
| The Following User Says Thank You to cjd For This Useful Post: | afx (02-19-2015) |
#2515 |
Pistons that don't consistently retract when you're pushing them back in. Symptoms will be uneven brake pad wear (compare all the pads). Uneven brake pad wear on ALL the pads indicates you're going beyond the capability of the pads. Single pad or side uneven wear is a sign you may need a rebuild.
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#2516 | |
#2517 | |
Drives: Neptune GR86
The only slightly related oil pan issue I know about is the oil pickup failing on other Subaru's.
#2518 |
Drives: Nuisance BRZ
Any recommendations for a tire with a minimum 220 tread wear rating?
#2519 |
#2520 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
