#2493 | |
Drives: Toyota GT 86
When I got my coilovers and wheels (before the rest of the suspension mods) the shop gave my car a 1.5" drop, and set the alignment to: front camber to -2.6 degrees LH and RH Front caster 5.7 degrees LH and RH Toe 1.5 mm LH, 1.5mm RH Rear Camber: -1.6 LH, -2.7RH (since I didn't have LCAs then this is what the car had) Toe: 0.1 mm LH and -0.2 mm RH But the car was too low so I had it raised 3/4" inch, and I planned on getting it done afterwards but I never got to it because I ordered the LCAs and bumpsteer kit so I'm waiting on that before re-aligning. |
#2494 |
btw, i messed up my parts list. this is the correct list:
My setup is: NA engine (no FI, nor plans to get FI) Yokohama AD08 225/40R18 Tein Street Flex (Damper set at 7/16 front 9/16 back for daily 10 front, 8 back of autox) Sway Bars 19 mm front Sway Bar 16 mm rear. End links (front and back) LCA (rear) Toe Arm (Rear) Rear diff support (Brace) whiteline Bump steer kit I meant endlinks front and back (instead of toe arms), and toe arm rear instead of trailing arm. |
#2495 |
I'm taking my car to Thunderhill for the first time in March. I've done track days in the past with my SRT-4, but this my first time out with a RWD car.
Do you have any tips for a first timer? I'm doing the driving school with NCRC, so I was thinking that I should leave all the nannies on this time around. I heard that you're not supposed to use the p-brake after running the car hard. Any other advice like that? Is there an ideal tire pressure I should shoot for? Is it worth it to fill up on a higher octance than 91? My car is completely stock. Thanks in advance |
#2496 |
Drives: 2017 BRZ
I'd be turning the nannies off and working my speed up as I learn the car. I've found they're good when you're not expecting something as might happen on the same commute every day, mind already at work, forgot you were even driving, but if you're in that frame of mind on a track, ...they can be very intrusive and I'm not sure that is helpful. Just don't drive too fast for your level of familiarity with everything.
Brake, yes. Heat is bad news for the e-brake. There is a great thread of tips somewhere here that covers a lot of this. C |
#2497 | |
I usually mix about 1/2 tank of 100 octane to minimize detonation. With CA 91 octane and no oil cooler, I think you'll definitely want to do this. Try to get camber bolts, brake pads, and fluid before your event if possible.
2022 BRZ Build 2013 FR-S Build |
#2498 |
I understand the pads, and fluids, but what benefit do camber bolts provide with a stock suspension?
I'm nervous that with the nannies off I will oversteer mid turn. The only thing I've played with is having the traction control off, and that's only when I feel like I'm driving in a safe environment. I'm pretty sure my insurance doesn't cover track days, and this car is far from being paid off. |
#2499 | |
Drives: '23 BRZ Limited
Don't worry about driving with the nannies off. Just go slow, listen to the instructors and understand you aren't going to be Ayrton Senna in 3 sessions. Depending on who is running the event, there may be track insurance available(but yes, your normal policy won't cover it). Check with companies like Lockton-Affinity that offer track coverage, although you still typically have to deal with a large deductible (think $5k-ish). |
#2500 |
Drives: '22 BRZ
Camber bolts are so you can dial in a reasonable amount of camber to avoid excessive wear on the outer shoulder of your tires. It's not going to understeer or destroy tires quite like an SRT4 does, but it doesn't hurt to throw the bolts in and dial in a more aggressive alignment.
#2501 | |
The added camber on the front tires will help with increased grip and reduced wear. When you add the bolts you should also get the car aligned, which is also very important for the track. You should be able to get about 1.5* of negative camber up front with the bolts, which is not that aggressive, but much better than stock in terms of handling. |
#2502 | |
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2503 |
#2504 | |
In terms of the nannies, there are two schools of thought about them for beginners. I am fairly strongly in the "start beginners out with them" because it provides a small additional layer of safety and also because it relieves some stress for the driver. Other people say they should be immediately turned off to help the driver feel the car (the traction control coming on can make it alot harder to feel what the car is doing). In the end it is a balance between the two sides that you (and your coach if you have one in car) need to decide between. Also, try and sign up for a coach in car (or try and do an event or two with one of the groups that has coaches for most/all beginners (PCA, BMW, Audi, HOD, etc.)). It does cost some extra but the benefits can be really great in terms of not learning bad habits and improving more rapidly.
| The Following User Says Thank You to ddeflyer For This Useful Post: | juliog (02-18-2015) |
#2505 | |
Drives: FR-S Firestorm 6MT
For completely new track users, I like having them use the nannies for the first session or two. Often, newbies will do stuff you really don't expect and this can save your asses. (I've had a student dive-bomb a corner on lap 3 cause he thought he could go faster). If they progress (some don't and just won't continue), then the nannies should come off as you are trying to get them to "feel" the car, and you can't do that with the car taking over certain functions and adding corrections. |
| The Following User Says Thank You to Slick For This Useful Post: | juliog (02-17-2015) |
#2506 |
Because compromise ®
Drives: Red Herring
What are the signs/symptoms of the Sprint Brake Kit needing an overhaul? Should one give them a regular service before an issue appears?
Ta.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
