Old 02-17-2015, 12:51 PM   #1569
M23
Drives: 86
2nd question:
Say if I already had the JRSC CARB kit (and everything else on the car was stock), and I really wanted to use an uncatted EL header. Exactly how can I do so and what are my options?
Is the only way to make it work, and the only option, and is necessary, is to get a new tune?
M23 is offline   Reply With Quote
Old 02-17-2015, 12:53 PM   #1570
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Originally Posted by M23 View Post
2nd question:
You would need to get a new tune. It wont run right on the CARB tune.
ApolloSki is offline   Reply With Quote
Old 02-17-2015, 12:55 PM   #1571
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Option 2 would sound better, option 1 would give more power.
ScionOfHorus is offline   Reply With Quote
Old 02-17-2015, 12:55 PM   #1572
M23
Drives: 86
Last question ( @Jackson Racing ):
Are there upcoming mild/medium upgrades (ie: no need for an engine rebuild) coming to the JRSC kit?
If so, what's coming? ...pulleys, diff tunes, diff parts/electronics, injectors/pumps, etc?
What's the current pulley's boost? 6-7psi correct?
If you guys are releasing a new pulley, what's the new pulley's psi and also what's the max psi the stock engine can safely handle with stock internals with a good safe tune? 10-14psi?
Old 02-17-2015, 12:57 PM   #1573
Xuningshen
Drives: Subaru BRZ
2nd question:
I think you're getting ahead of yourself. You've posted a lot in here, asked a ton of questions and should have all that information. I understand being so excited and it being on your mind 24/7, but its time you now go out and buy the JRSC kit and then go from there.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 02-17-2015, 01:10 PM   #1574
M23
Drives: 86
^^^ haha
Old 02-17-2015, 01:19 PM   #1575
ScionOfHorus
There is a higher boost pulley already, but it has issues unless you are running 93+ or e85 so they don't advertise it. Contact CSG for details on it.
Old 02-17-2015, 01:27 PM   #1576
sw20kosh
Drives: 2013 Black FR-S
This is pretty insane if you think about it - stock exhaust, quiet as a mouse, but with 277 mustang dyno whp!
No. The stock cat back sounds like ASS when you increase the power of the motor (AKA JRSC) and have no cats. The stock muffler is not designed to work with the extra sound amplitude. CSG has tested this extensively and is in the process of looking for a cat back that doesn't sound like ass.
@CSG Mike @CSG David
Old 02-17-2015, 01:45 PM   #1577
CSG Mike
CSG Mike's Avatar
I'm almost tempted to borrow a Tomei for when I come up to Norcal 86CUP... except I'd go deaf on the trip up.
CSG Mike is online now   Reply With Quote
Old 02-17-2015, 01:50 PM   #1578
mkivsoopra
Maybe someone here would be willing to lend you his Tomei, since he's using his stock catback for now :p *coughjeffcough*
mkivsoopra is offline   Reply With Quote
Old 02-17-2015, 01:56 PM   #1579
sw20kosh
Oh yah, and he wont even be here for the March Norcal 86cup weekend...
Old 02-17-2015, 04:04 PM   #1580
MidnightRunner
MidnightRunner's Avatar
I have a couple good questions....
Say if I already had the JRSC CARB kit (and everything else on the car was stock) ..which would be the better route if I had an extra $1k to spend:
1. DT FlexFuel Hardware Kit + Flash&Go Tune w/ FlexFuel Upgrade
or
2. An uncatted EL header + a Tune (so that the header can work; since I assume it wont with the CARB tune)
If I would guess, option 1, would be the better choice, correct? Since with e85, it would be around a 70whp gain (on mustang).
And, option 2, I think would probably only net 10-20whp from a header. Nowhere as close to the e85 gains.
Forget the header. It will void your CARB certification and there's a good chance it won't even give you 10 more hp.
Buy the Jackson CARB kit and enjoy it for a few months. If it gets old, then go for flex fuel.
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 02-17-2015, 05:05 PM   #1581
M23
Drives: 86
Stock header for smog days obviously. Not hard at all to swap out.
Old 02-17-2015, 05:06 PM   #1582
M23
Drives: 86
"No" ...I wasn't even asking a question. Your comment and opinion is purely subjective. But, sounds like you're jus trying to talk sht anyways.
I think overly bassy exhausts sound like "ass." Like they're trying too hard to sound cool.
Diff strokes.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
