Old 02-16-2015, 03:07 AM   #15
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Originally Posted by mrk1 View Post
Looks pretty but whats the goal, mid range torque? top end hp?
The goal was to come up with a unique, completely unlike oem, design that was more efficient throughout the rev range. Truthfully, we don't know much about how this will perform yet besides cylinder distribution when all valves are open (an unrealistic event but it helped us shape the plenums for how air naturally wants to enter). From previous knowledge it points to be a top end, FI geared, intake manifold. However, also from previous knowledge, a more efficient design can improve VE in areas the runners/intake manifold wouldn't typically be thought to. We make no claims until the test unit gets on the car and is thoroughly tested .
eric6 is offline
The Following 6 Users Say Thank You to eric6 For This Useful Post:
*KID* (02-18-2015), Captain Snooze (02-16-2015), flippy (04-02-2015), GT86_PRAGUE (05-06-2015), hmong337 (02-16-2015), Sypher (02-16-2015)
Old 02-16-2015, 03:20 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
So I can check back in 15 minutes to see the results?
On a more serious note (b#) could you give a best case guestimate, based on experience, what might be the increase in power over a rev range for a normally aspirated engine? I appreciate this is not set in stone but I would like to know if I should keep watching this thread or give it up because I wish to remain n/a. 5 hp increase over 3k-4k rpm not worthwhile. 12 hp over 5k-7.6k rpm would be good.
Captain Snooze is offline
Old 02-16-2015, 10:32 AM   #17
eric6
eric6's Avatar
It would be extremely naive of us to put numbers out. It will likely increase hp up top more so then in the mid-range based off runner length. Again, if the system proves to be more efficient then the OEM system, mid-range could gain horsepower as well.
eric6 is offline
The Following 3 Users Say Thank You to eric6 For This Useful Post:
Captain Snooze (02-16-2015), CatDaddysBBQ (04-03-2015), rallysrt (06-13-2015)
Old 02-16-2015, 10:59 AM   #18
Calum
That Guy
Drives: 2013 asphalt FRS MT
What's the volume of the plenums? They look small but I'm looks ng at this on a phone.
What kind if time line are you aiming for?
Calum is offline
Old 02-16-2015, 11:11 AM   #19
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Subbed! Loving what you guys are bringing to the market. I also love seeing all the data with the products. Keep up the great work!
DustinS is offline
Old 02-16-2015, 11:31 AM   #20
Yurgle
Drives: 2015 Toyota GT86 (EU Spec)
Yurgle is offline
Old 02-16-2015, 04:01 PM   #21
eric6
eric6's Avatar
Approximately 2 liters.
Prototype strapped to car and dynoed by end of March.
eric6 is offline
The Following 5 Users Say Thank You to eric6 For This Useful Post:
Calum (02-16-2015), civicdrivr (03-19-2015), hmong337 (02-16-2015), JDKane527 (02-16-2015), kster1 (02-16-2015)
Old 02-16-2015, 04:22 PM   #22
Captain Snooze
Drives: Red Herring
http://www.timeanddate.com/countdown...=0&min=0&sec=0
The Following 6 Users Say Thank You to Captain Snooze For This Useful Post:
civicdrivr (03-19-2015), GhostOp86 (02-16-2015), Hyper4mance2k (02-17-2015), Porcupint (02-18-2015), raven1231 (02-16-2015), wparsons (02-17-2015)
Old 02-16-2015, 06:50 PM   #23
Turdinator
Señor Member
Turdinator's Avatar
2lts per plenum or total?
1974 TA22 Celica
2013 86 GT
Turdinator is offline
Old 02-16-2015, 06:58 PM   #24
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
geez, you guys are cranking it out!
Quit keeping secrets from us! What else have your evil little elves been working on?!?!
continuecrushing is offline
Old 02-16-2015, 07:16 PM   #25
eric6
eric6's Avatar
Per side, not including the tubing.
I wouldn't say cranking them out but we are moving in a forward direction with quite a few projects.
We have a handful of other projects we are working on getting prototyped/finalized. They will remain a mystery until we (FT86SpeedFactory and ourselves) feel they can be released .
eric6 is offline
The Following 9 Users Say Thank You to eric6 For This Useful Post:
ATL BRZ (02-18-2015), Calum (02-16-2015), Captain Snooze (02-16-2015), DustinS (02-19-2015), Lonewolf (02-16-2015), meWant (02-17-2015), Porcupint (02-18-2015), raven1231 (02-17-2015), Turdinator (02-16-2015)
Old 02-16-2015, 07:45 PM   #26
djliquidsteele
Drives: Scion FR-S
So with FI in mind, specifically supercharged, in theory, will something like this allow the engine to keep making power past 7000 rpm. Stock seems to die off and it seems no matter how much air you try to shove in there, it still dies off toward redline.
djliquidsteele is offline
Old 02-16-2015, 08:28 PM   #27
Calum
That Guy
Without testing it's impossible to tell. The choke point could be the intake manifold or the head, or both.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
djliquidsteele (02-18-2015)
Old 02-16-2015, 08:36 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I was about to ask (I think this has already been answered) since both intake runners seem to feed two cylinders at once, wouldn't the piston firing order cause a difference in pressure in the manifold? or is that what the intermediate hose is for?
cdrazic93 is offline
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
