Old 02-15-2015, 07:08 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread
We have been working on several projects with Velox and will be unveiling them over the next few weeks. First up we have a new LCA that is in development and soon undergoing testing on a couple time attack cars.
There are a lot of options out there when it comes to Lower Control Arms for the twins. You have simple units like the SPC arms all the way up to full CNC Aluminum ones as we'll see below.
The factory lower control arm as I am sure you all know lacks any sort of camber adjustment. This does not work very well for those of us who decide to lower the vehicle or do any sort of motorsports with the car. Working with Velox it was decided to completely redesign the LCA to reduce the most amount of unsprung weight possible, give racers a lightweight and durable solution.
To get started we got 3D models of the OEM unit.
So how can this be improved upon?
1. Weight: Lighter than the OEM and other aftermarket units. This helped us determine which material to use.
2. Packaging: We wanted our LCA to retain OEM mounting points. This allows the LCA to be used on a stock suspension set-up , as well as coilovers, and not lower the rear of the vehicle like other units geared more towards stance. This is what ruled out the above design.
3. Manufacturing: We decided early on that we wanted a machined component. With a cut, bent, and welded steel unit, tolerances are looser and heavily dependent on the shop doing the work. On the other hand, a modern CNC machine can hit tolerances tighter than 0.005″ without breaking a sweat.
4. Strength: We knew we wanted a LCA that was ready to hit the track. From daily drivers, to enthusiasts, to all out time attack cars, this LCA had to be handle the punishment.
Several ideas were constructed but weight was still a tad high.
A finial design was settled upon once more weight savings was created.
Everything has been created via 3D models from OEM supplied 3D data. It doesn't get any more precise then this guys.
The stock LCA overlaid on ours.
Stay tuned as we test tension, deflection, and overall strength.
FT-86 SpeedFactory is offline
The Following 19 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
8R6 (02-15-2015), akyp (02-16-2015), Black Tire (02-15-2015), DAEMANO (02-17-2015), D_Thissen (02-15-2015), flippy (07-21-2015), FutureFT86 (08-28-2016), GT86_PRAGUE (09-28-2015), Guff (03-15-2015), JonAvalon (02-15-2015), JS + BRZ (03-24-2015), kask2_6.0 (02-15-2015), KR-S (12-05-2015), kster1 (02-16-2015), Lawnik (03-17-2015), themajesticone (02-16-2015), WallsAndFoundations (03-21-2015), was385 (02-15-2015), WillRacer1jz (08-21-2015)
Old 02-15-2015, 07:15 PM   #2
was385
Drives: MT WRB BRZ Limited, 2007 911s
Will this be available with poly bushings for us autox guys? Any idea on price range or guess on when they'll be available? Looks good.
was385 is offline
The Following User Says Thank You to was385 For This Useful Post:
JohnJuan (02-17-2015)
Old 02-15-2015, 07:30 PM   #3
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
No toe adjustment out of the box like the SPC?
Mad1723 is offline
Old 02-15-2015, 07:50 PM   #4
FT-86 SpeedFactory
Toe is controlled by a completely different arm. SPC provides a bushing you have to have pressed out of the factory toe arm and then press in their bushing in order to get toe adjustment. SPC is also stamped steal arm that uses a bolt for camber adjustment that can slip under heavy load.
Factory toe adjustment we have found to be plenty for our racing applications.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Mad1723 (02-15-2015)
Old 02-15-2015, 08:23 PM   #5
Mad1723
Mad1723's Avatar
Good to know. I'll keep an eye on this
Mad1723 is offline
Old 02-15-2015, 08:34 PM   #6
D_Thissen
D_Thissen's Avatar
Looks awesome guys. Any idea of a price range or release date?
D_Thissen is offline
Old 02-15-2015, 09:53 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
cdrazic93 is offline
Old 02-15-2015, 10:02 PM   #8
s2d4
s2d4's Avatar
Can this be adjusted on the car or will it be like the Cusco ones?
s2d4 is offline
Old 02-16-2015, 01:17 AM   #9
akyp
Drives: 2012 86
Mounting hole for the sensor of self-leveling headlamps on GT86?
akyp is offline
The Following User Says Thank You to akyp For This Useful Post:
Captain Snooze (02-16-2015)
Old 02-16-2015, 02:45 AM   #10
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
They are designed to be adjusted on car. If significant adjustment is needed, it will be suggested to thread the adjuster out and thread the rod end in. This is to ensure that the threads won't get stripped out. The instructions will have further information on this subject.
Not currently, but something we can definitely discuss.
eric6 is offline
Old 02-16-2015, 02:49 AM   #11
eric6
eric6's Avatar
I'll let @FT-86 SpeedFactory answer those questions with numerical answers. I can comment on the pricing... it will be competitive with what's on the market now.
eric6 is offline
The Following User Says Thank You to eric6 For This Useful Post:
D_Thissen (02-16-2015)
Old 02-16-2015, 03:17 AM   #12
swarb
6061? 7075? heat treated?
Looks good!
swarb is offline
Old 02-16-2015, 09:19 AM   #13
was385
Will this also have an option for rubber or poly bushings to keep STX legality for autox?
was385 is offline
The Following 2 Users Say Thank You to was385 For This Useful Post:
D_Thissen (02-16-2015), wparsons (02-16-2015)
Old 02-16-2015, 10:20 AM   #14
eric6
eric6's Avatar
Looks good!
The materials is roughly 25% stronger then 6061-T6 but weaker then 7075. 7075 would put us out of price range for most customers. We have thought about running a few sets from 7075 for the time attack guys pushing 2+ G in turns, just as an added safety margin.
Currently, it will not. Another thing we can discuss before the production run.
eric6 is offline
The Following 2 Users Say Thank You to eric6 For This Useful Post:
JohnJuan (02-17-2015), swarb (02-16-2015)
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 04:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 10:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-19-2017 11:07 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
