Old 02-12-2015, 12:12 AM   #15
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
Originally Posted by xero404 View Post
Ran 255/35/18 on 18x9.5 +40 no issues even on track (see pic). 235/45/18 is a bit too tall and i'm hitting the Fender liner in the front at full lock inwards and have a bit of rub in the rear and might roll fenders. Attachment 102332
You think 245/40 18 would make the cut?
WhiteChocolate is offline   Reply With Quote
Old 02-12-2015, 01:06 AM   #16
xero404
Need That Tire Advice
Its def shorter and I'd probably try that size next time. Heres a pic of the 235/45 Name:  ImageUploadedByTapatalk1423721207.018105.jpg
Size:  202.5 KBName:  ImageUploadedByTapatalk1423721226.334699.jpg
xero404 is offline   Reply With Quote
Old 02-12-2015, 09:38 AM   #17
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I'm running 245/35's and have been for almost two years now. Very slight stretch on 18X9.5. Next round I'll probably do 255/35, but I was also considering 255/40 for a little more sidewall? 255 won't strech, but I think a 40 sidewall should clear okay. I'm about 1.4" dropped on KW V3's.
http://www.tirerack.com/tires/tires....S&autoModClar=
or
Currently running DW's and they have great traction and don't seem to wear quickly. I know the PSS are top of the line though.
2016 Camaro SS is offline   Reply With Quote
Old 02-12-2015, 05:30 PM   #18
Pete156
I like to eat!
Here's your 18x9.5 +38s with 255/35s square (PSS)
No fender roll, no rubbing, no spacers, ~1.5 drop on coils
Pete156 is offline   Reply With Quote
Old 02-12-2015, 06:39 PM   #19
eguzman6
eguzman6's Avatar
Drives: FRS 10 Series
I had the same question as op, and decided to order 255/35/18 for wheels that are 18x9.5 45 or 40 offset don't recall top of my head. I'm waiting for spring to out them on. But from the research I did 255/35 will not screw with the mph on the dash. And I asked on fb page and people said 255/35 shouldn't cause any problems. I will see in a few months
eguzman6 is offline   Reply With Quote
The Following User Says Thank You to eguzman6 For This Useful Post:
WhiteChocolate (02-14-2015)
Tire size advice Lost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-28-2016 06:42 PM
Tire advice dtrop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 12-03-2014 05:36 PM
tire advice kosoku Tracking / Autocross / HPDE / Drifting 24 12-17-2013 11:51 AM
Need daily driver tire advice bear89103 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-26-2013 01:15 PM
Wheel/Tire Advice mrjester Tracking / Autocross / HPDE / Drifting 1 05-18-2013 11:48 PM
