Old 02-10-2015, 11:23 AM   #2199
engee
Drives: Subaru
Originally Posted by SeanRTR View Post
Many are expecting it to be added later, probably when the tire is actually available.
Gotcha. Thanks for the heads up. I'm guessing you are talking about the 225/45 size that is currently on backorder.
engee is offline   Reply With Quote
Old 02-10-2015, 11:28 AM   #2200
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I just hear everyone saying 'not in stock'. I don't run Hankooks because of the availability issues in general. I drive on the tires daily and constantly hit nails, broken glass, used syringes in downtown Detroit...I can't risk needing a tire that is on galactic back order when a big event is coming up.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 02-10-2015, 11:37 AM   #2201
engee
Drives: Subaru
Haha. I hear ya. I'm currently debating whether to pull the trigger on the Hankooks or try out the new ZII star spec. ZII's have the size that I want but have no data. RS-3's don't have the size I want, but have a proven track record (not saying other tires aren't competitive).
Decisions, decisions....
Old 02-10-2015, 09:59 PM   #2202
bslate3
Drives: 2015 CWP BRZ
Since we are very limited on front camber and the RS3 sidewall is so soft, what's the widest you would go to keep the shoulders from wearing too fast?
I was thinking about going with the 235/45 RS3's but I'm worried the shoulders will wear prematurely.
For that size tire, should I just get Z2SS? 235/40 would be nice but it's so expensive!
bslate3 is offline   Reply With Quote
Old 02-10-2015, 10:51 PM   #2203
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I am thinking of going with the 235/45 RS3's also. They are definitely a bit taller than stock (could be good for gearing on faster courses) but also have a higher load rating. Can anyone on here confirm a correlation between load rating and side wall stiffness? I am going to call Tirerack when I have a chance and see what they say about that. If they do indeed have a stiffer sidewall that might be a good thing, no?
Briankbot is offline   Reply With Quote
Old 02-11-2015, 09:03 AM   #2204
Biggins
Drives: Yes
You guys are overthinking it. The 235/45 Hankooks are fine; I ran them all year with great results because I need the extra gearing for my region's faster course designs. I'd buy them again or 215 or 225 or 245 if they were out of stock because the difference is quite negligible.
I'll get plenty of seat time on the new Star Specs, so I'm curious to see if I'll like them.
I'm waiting until mid-August before I buy tires to see how everyone is doing on all the other brands. I'll let everyone else be the guinea pigs. I just wish my Yokohamas were still eligible, but I'll just run SM until I pick a brand this year.
Biggins is offline   Reply With Quote
Old 02-11-2015, 06:10 PM   #2205
ksconekiller
Drives: Subaru BRZ
The only problem with a plan of buying in August is the possibility that the tire you want will be out of stock then. It happens pretty frequently. Not sure yet which ones I will choose.
On a related note, I am about to look at a local set of used RPF1 wheels, and the seller says they are 17x7, but he isn't 100% sure. To those of you who have these wheels: is the size listed on a decal inside the wheel, or is it molded into the wheel somewhere? Thanks in advance!
ksconekiller is offline   Reply With Quote
Old 02-11-2015, 06:11 PM   #2206
vroom4
Use a tape measure.....
It's stamped on back of hub too
vroom4 is offline   Reply With Quote
Old 02-11-2015, 07:07 PM   #2207
u/Josh
Drives: GBS Limited 6MT
Confirmed, it is molded
u/Josh is offline   Reply With Quote
Old 02-12-2015, 08:04 AM   #2208
bslate3
I think I would rather go with a 225/45 than a 235/45 since I plan to do some track days and SCCA time trials.
I'm afraid a 235/45 RS3 would with hardly any negative camber would get a ton of rollover and premature tire wear.
Old 02-12-2015, 10:14 AM   #2209
ksconekiller
Drives: Subaru BRZ
Perfect, thanks.
Old 02-13-2015, 04:23 PM   #2210
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Okay guys, looking for some advice on datalogging. I know... it has been covered in the past on this thread but actually compiling all of those random posts in the hay stack is a challenge to say the least.
So, I have a budget of about $1k (less would be better). My baseline pick right now would be Solostorm for software because I love what it can do and being able to view and compare videos between runs will be great for me. If I go with Solostorm, I was thinking about just picking up everything Solostorm recommends (http://www.petreldata.com/product/so...repro-package/) because it would be easy, but it is also expensive. Does anyone run other, less expensive, loggers with Solostorm? On top of all of this, I need to buy a wifi GoPro because my current is not wifi.
Thoughts?
DylanFRS is offline   Reply With Quote
Old 02-13-2015, 04:27 PM   #2211
TRev
Edit: Rims have all been spoken for.
TRev is offline   Reply With Quote
The Following User Says Thank You to TRev For This Useful Post:
SeanRTR (02-16-2015)
Old 02-13-2015, 04:40 PM   #2212
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Thoughts?
if I didn't get my AimSolo DL for half off (used) then Solostorm would def be the next thing id purchase. It looks like they have a solid platform and their price is justified by their continuing development of the product.
The Following User Says Thank You to 7thgear For This Useful Post:
DylanFRS (02-13-2015)
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
