#2297 |
Drives: FT86
#2298 |
Drives: 2014 Fr-S Monogram
#2299 |
Drives: FT86
#2300 | |
Drives: FT86
IAM=0.8 you have some knock the FLKC looks weird are you on a D00C or D00D rom ie the 2015 rom looks like the logging not working correctly would email shiv that log. I think the logging on your rom not working properly would trust that log. |
#2301 | |
Drives: 2013 Asphalt Fr-S
On my A001C, 2013 FRS, I am getting a IAM = .92 - .96 (Flux as temps do) with a wideband AFR of ~13.6:1 (Rather than the 14.7:1 I was taught we wanted back in the Hondata days of self tuning) while using the V 2.063 US 91 Oct tune I'm still learning how to upload to DATAZAP though once I figure that out, I'll post a link to it for analysis, but I don't have access to 93 octane and can't afford the extra for the racing fuel (100 oct) that I have near me. Any ideas off hand?
#2302 | |
Drives: FT86
You can pull a bit of timing out of the base timing B map. few guys in california have done that try @JB86'd he might be able to send you map or at least the changes to the timing table. or you can do it yourself if you read the knock correction links below |
#2303 | |
Lastly, I forgot to mention my "List of mods" which is actually small. An AEM intake (which has the sensor in the box to prevenet CEL pop on factory tune), A cut factory snorkle (Making for a lumpy ass top end and really crazy turbulence in the air) and a Manzo Overpipe ($40 and I was going to buy a header too, but haven't gotten around to it since getting the OFT)
#2304 | |
Drives: FT86
#2305 | |
Drives: FT86
#2306 | |
If not, this is something I may take into consideration and try on the V2.063 OTS straight off MAF. I am betting you're right.
#2307 | |
Drives: FT86
However the FLKC knock values still look weird look like a problem with logging on hour oft. Send the log to shiv@openflashperformance.com ro contact the openflash guys on the phone |
#2308 | |
Drives: FT86
#2309 |
Drives: '13 SSM BRZ Limited 6MT
I'm close to getting an uel header for the primary purpose of getting rid of the 4k vvt noise, would it be safe to load the uel e85 tune whole I'm still on stock header and e85 for about 2 minutes and Rev past 4k to see if the noise is gone or minimized at least. Then I'll flash back to the correct tune for my setup.
I've read reports of the uel tune getting rid of the sound but I just want to make sure before I drop $800 for a header. |
#2310 | |
If changing your tune, then let the engine remap / relearn the new composition of E% and then go from there. (It was recommended every tank you let it relearn before WOT) Happy driving.
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
