Old 02-06-2015, 09:48 PM   #85
White64Goat
Plugs are supposed to be changed at 75,000 miles if I remember correctly. Save your money and enjoy the trip. $450 will get you a lot of In-N-Out burgers and gasoline and hotels.
The Following User Says Thank You to White64Goat For This Useful Post:
chanomatik (02-10-2015)
Old 02-06-2015, 09:52 PM   #86
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
Practice makes perfect.... I have a guy at work here that'll have both heads off in under an hour. I'm not too worried about the plugs.... not to mention the number of miles I put on the car I wont be doing plugs until 2025 anyway LOL
Haeb is offline   Reply With Quote
Old 02-06-2015, 09:56 PM   #87
Haeb
Haeb's Avatar
Book time on the plugs.... 3.5 hours. And the procedure is a bit of a bitch outside of the shop environment.
Old 02-07-2015, 01:08 AM   #88
gravitylover
60k service at my dealer includes doing the plugs and it's $675. If it needs any replacement coils it's extra for the parts if the car is over 60k so I plan to get it done at ~59 so stuff will still be under warranty. Should be spring '16 or so until I need to worry about it though.
The Following User Says Thank You to gravitylover For This Useful Post:
Old 02-07-2015, 08:19 AM   #89
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It can be done without raising the motor up and everything the shop manual states. It just requires patience, but can be done.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 02-07-2015, 10:46 AM   #90
KevinA
Drives: Toyota GT86
You can change the plugs without lifting engine etc.... Couple of race teams here in the UK have drilled strategic holes ( not chssis damaging ) which allows removal with a long extension bar.
KevinA is offline   Reply With Quote
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 11:21 AM
What do you wish was changed about the brz/frs? GirlyScions BRZ First-Gen (2012+) — General Topics 16 06-04-2012 04:26 AM
