Old 12-07-2014, 01:39 AM   #43
Quanye
Originally Posted by Gunman View Post
@DocWalt Quantity of clips is high, you don't need 30, I just copied from someone else, and they got extras. Still have not purchased these myself.
Part No. Qty MSRP
56411CA000 UNDER COVER R RH 1 $82.45
56411CA010 UNDER COVER R LH 1 $82.45
42045CA020 PROTECTOR TANK RH 1 $18.18
42045CA030 PROTECTOR TANK LH 1 $18.18
909140065 CLIP 2PECE D8 30 $1.14
901000344 BOLT FLG 6X16 3 $1.02
909140007 CLIP BUMPER* 4 $2.47
Just a little question. What kind of bolts and nuts were you using? I found there are only clips in this list.
Quanye is offline   Reply With Quote
Old 12-07-2014, 09:57 AM   #44
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
He probably used this: 901000344 BOLT FLG 6X16 3 $1.02
Which is in the list
Old 12-07-2014, 10:40 AM   #45
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Part No.QtyMSRP
56411CA000UNDER COVER R RH1$82.45
56411CA010UNDER COVER R LH1$82.45
42045CA020PROTECTOR TANK RH1$18.18
42045CA030PROTECTOR TANK LH1$18.18
909140065 CLIP 2PECE D8 30$1.14
901000344 BOLT FLG 6X16 3$1.02
909140007 CLIP BUMPER* 4$2.47
That was must likely my post. The Subaru parts guy and other posts said to not reuse them considering that it's easy to damage the clips
Sent from my OnePlus One
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Gunman (12-07-2014)
Old 12-07-2014, 11:04 AM   #46
wparsons
wparsons's Avatar
Are you running yours through winter? I was going to pick them up, but figure it's just asking for underbody rot.
flickr
Old 12-07-2014, 01:51 PM   #47
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@wparsons I was, but decided to wait until spring to clean under the car and install springs too
Old 02-03-2015, 07:17 PM   #48
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Thanks for this write-up, I'm going to use it tonight to install mine. Got them for $200 shipped from a group buy shipped, and got the clips/bolts at Subaru, who definitely has them available to order with the series.blue now using them. I saw the parts on their computer as I was ordering the clips and bolts.
Can't wait to see how it looks with the Driveway Labs type 2 on.
DoomsdayJesus is offline   Reply With Quote
The Following User Says Thank You to DoomsdayJesus For This Useful Post:
continuecrushing (02-03-2015)
Old 02-03-2015, 07:39 PM   #49
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
awesome deal! FINALLY we get these on our cars over here haha
Old 02-03-2015, 08:05 PM   #50
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The Driveway Labs Type 2 really put the finishing touches on my daughters car, the underbody panels are worth the price
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-04-2015, 12:46 PM   #51
DoomsdayJesus
There are a couple spots I noticed that take bolts, not clips as indicated. I do have a 2015 and I noticed some changes since the 2013, so that may be a factor. I was short the nuts so I didn't install the gas tank panels yet, but the noise level drop on the freeway alone is worth it (WA freeways are just noisy as hell because of how rough they are a year after they're paved).
I did the install by rolling the rear on ramps and jacking up the front with stands, which was really not enough with the stock jack. Should have used my outback's jack.
YouShallKnow (02-06-2015)
Old 02-04-2015, 10:23 PM   #52
DoomsdayJesus
Does anyone know what size the nuts are? I was looking for a flanged M8x1 machine nut just eyeballing it, but couldn't find them at Lowes, and don't feel like driving to the dealership.
Sent from my SCH-I545 using Tapatalk
Old 02-05-2015, 12:32 AM   #53
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Shutter View Post
I dont live somewhere where we have snow/salt, but I think it would do a decent job of protecting the underside.
Since you could remove the panels, it might be beneficial to install for a winter and remove after to see if anything made it on the inside.
Anyone else?
Looking at the design of the panels, I think they might trap a lot of moisture/salt/sand next to the metal. Perhaps I would think differently if I was able to check them out in person. From what I can see from the pictures, I think if I installed them, I would remove them for the winter.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 02-05-2015, 03:03 AM   #54
troek
troek's Avatar
Drives: 2012 Toyota 86
thats a possibility, but they are a pretty tight fit, so youd have to submerge or drive though deep snow i would imagine.
troek is offline   Reply With Quote
Old 02-06-2015, 10:55 PM   #55
DoomsdayJesus
That's pretty much correct. You'd have to be fording to get them soaked. If it really bothers you, drill a couple holes in the rear. Snow wouldn't get in there at all. I was driving through torrential rain all day long for well over 100 miles today in WA, and they're hollow when I knock them. They'd also keep FAR more salt off your undercarriage than stock panels would. It's easy enough to just pop the clips on the outside and shoot a hose in there if you're worried about accumulation, but the bottom of the car is really thoroughly rust-proofed with the foam they sprayed on it.
Keep in mind they straddle the exhaust, which keeps them nice and toasty as well. If you're paranoid about it, you can always use weather stripping or silicone but that would honestly be overkill.
Again, just the noise reduction makes it completely worth it.
Old 03-11-2015, 09:56 PM   #56
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
So I am getting quotes to purchase a BRZ and I want these body panels on it. One dealer has told me that all 2015's have these one them stock from the factory. However, I had thought it was only the Series.Blues that had these from the factory. Can someone chime in and clarify this?
AzureShadow is offline   Reply With Quote
skid plate, underbody, underpanels
SoCal JDM Underpanels Set Groupbuy JDKane527 Southern California 109 10-31-2013 08:29 PM
FS: JDM OEM Underpanels (LI Local Pickup) Perihelion NY / NJ / CT / PA 30 07-26-2013 07:20 AM
SoCal JDM Underpanels Groupbuy Round 2 Trojan_SC Southern California 99 06-21-2013 12:35 AM
FS: JDM OEM Underpanels (LI, NY Local Pickup) Perihelion Exterior Parts (Aero, Lighting, Etc.) 8 05-09-2013 02:45 PM
Interest in JDM underpanels GB? sittinSideways Northwest 3 04-04-2013 12:57 AM
