#15 | |
Aloha!
| The Following User Says Thank You to ARTBRZ For This Useful Post: | Porcupint (02-03-2015) |
#16 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
I think a lot of people are confusing the tinting for being responsible for reducing glare, when it's really the convex shape more than anything. The wider angle makes things look farther away, so that light source is less focused on your eyeball because it is now smaller...same as if it was farther away then got closer....dim...bright. Making the light reflected blue or yellow or any other color doesn't magically "reduce glare", that's just marketing hype.
#17 |
Drives: 2014 Scion FR-S
I don't have a BRZ, so I don't have heated mirrors, but they're just a replacement for the existing mirror with the glass just being different, so I don't think it would be an issue, nor have I heard anyone ever complain about it.
| The Following User Says Thank You to Ammunition For This Useful Post: | ARTBRZ (02-03-2015) |
#18 | |
Drives: 13 GBS BRZ
Agreed on the color not doing much if anything for the glare though. |
| The Following User Says Thank You to Porcupint For This Useful Post: | killboy (02-03-2015) |
#19 |
Polarizing I can see as making a difference, although I'm curious how that all works since polarizing is intended to eliminate reflections, and a mirror is intended to reflect.
#20 |
Drives: 13 GBS BRZ
I was and still am curious on that one too. But from what I can see it takes a crash course in the physics behind light waves and how they react to mirrors vs reflective objects (Hood of car, water, etc..) to understand most of what google showed me.
| The Following User Says Thank You to Porcupint For This Useful Post: | killboy (02-04-2015) |
#21 | |
Drives:
#22 |
Drives: WRB Subaru BRZ
Are http://www.rexpeed.net/2012/en/produ...php?serial=335 the same as the ones from SpeedFactory?
I'm just curious because they're a little cheaper. |
#23 |
Drives: ‘16 4Runner, ‘19 Corolla HB
I used to be driven crazy by glare on my 2001 Impreza 2.5RS. It was because my mirrors were badly adjusted. Once I adjusted the side mirrors to look at the lanes to my left and right instead of catching the cars behind me, the glare went away. I also don't regularly drive in congested areas like Seattle, though.
#24 |
Drives: Neptune GR86
For cars without factory heated mirrors, anyone know if attaching two wires with spade connectors on the mirror and connecting to a switch with power/run inline with the defroster button work?
Or is it more complicated than that?
#25 | ||
Drives: 13 GBS BRZ
You'd have to run the wires through the door and what not which is a bitch to do in and of itself. And I'm not guaranteeing it would work but I don't see why it wouldn't if done right. I wonder if the wiring diagram in my service manual shows that info. |
#27 |
Drives: 1966 Mustang, 2013 FR-S
Has anyone ever tried the Speedline mirrors?
http://www.phasteksport.com/FR-S-BRZ...rz-mirrors.htm I am planning to upgrade to these for their turn signal and defroster, but I have not heard any reviews. Is the tinting blurry? Are they good or crap? |
#28 |
Drives: 2015 Series Blue
How difficult are they to install???
| Product To Reduce Dash Glare? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 08-20-2015 06:55 PM |
| Reduce interior sound | KillionsFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-28-2013 05:23 PM |
| WTT: My cf mirrors for your Raven mirrors- PLEASE LOCK | FR-Shadow | Exterior Parts (Aero, Lighting, Etc.) | 3 | 09-25-2013 10:01 AM |
| 1080p Nighttime Test Drive w/ ContourROAM1 | forzajuve | Electronics | Audio | NAV | Infotainment | 0 | 04-30-2013 02:41 PM |
| Nighttime Test Drive w/ ContourROAM1 | forzajuve | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 04-29-2013 09:21 PM |
