86 noober
Drives: Asphalt FRS, 90' CRX
Tinting mirrors to reduce nighttime glare
So I have been very interested in buying a set of Prova wide mirrors in a yellow tint for night time driving. These mirrors though, are not a full replacement but simply a mirror you stick on top of the factory one from what I understand.
![]() Would I be able to simply tint my mirrors using yellow Laminx and get the same effect? I'm unsure if there is some sort of special polarization to those mirrors. Has any one done this before? -Thanks |
#2 |
Custom User Title
Drives: Asphalt FR-S MT
"Wide angle" mirrors change the optics to get that "wider" view. Tint alone can not do that. Did they use a special tint? I have no idea.
#3 |
Time Traveller
Tinted mirrors using vinyl would be very blurry. Do not recommend.
I mounted a set of yellow mirrors on my car by removing the old mirrors from their housing. I removed the mirrors with brackets attached from the car (they snap right out). To remove the OEM mirror from the bracket, I used a heat gun to soften the adhesive holding the mirror onto the bracket. Took out the OEM mirror, then reused the adhesive to install the new yellow ones (added LED turn signals underneath). Worked like a charm and has held well for months now. If you want more glue, then use 3m Windo-Weld (you can get it on Amazon). ![]()
#4 |
Drives: 13 GBS BRZ
Rexpeed mirrors are the actual glass replacement. It's what I have and they're amazing. I'd never go back.
These are the ones I have. http://www.ft86speedfactory.com/rexp...ated-1354.html |
#5 | |
Drives: 2014 Scion FR-S
| The Following User Says Thank You to Ammunition For This Useful Post: | Porcupint (02-03-2015) |
#6 |
86 noober
Thanks for the replies. For those that have yellow tinted mirrors, how well do they reduce glare at night?
#7 |
Drives: '15 Brz Series Blue
#8 |
Drives: 13 GBS BRZ
Don't have yellow, but the blue is incredible at reducing glare. I could care less if there's a jacked up truck with HID's behind me now. Previously it would give me a headache and have me cussing, but now it doesn't even make me squint.
#9 |
86 noober
From what I understand blue tints are suppose to improve daytime glare, yellow tint for night. I dunno.
Plus the yellow as an additional asthetic appeal to me and would compliment my yellow fogs! |
#10 |
Drives: FRS
are there yellow tinted mirrors that ARENT wide angle? i dont like convex mirrors and have no need for it really. i just want to reduce the glare
#11 | |
Aloha!
#12 | |
Aloha!
#13 |
Drives: 13 GBS BRZ
LA as in Louisiana
and we've been jumping between mid 20's and 80's the last week lol The heat function seems to take a little longer, but I never timed it to compare to stock. Usually by the time I get the 2 miles down the road to the interstate, they're completely clear. So around 1.5 minutes to go from completely fogged/frozen to clear. |
| The Following User Says Thank You to Porcupint For This Useful Post: | ARTBRZ (02-03-2015) |
#14 |
Time Traveller
| Product To Reduce Dash Glare? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 08-20-2015 06:55 PM |
| Reduce interior sound | KillionsFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-28-2013 05:23 PM |
| WTT: My cf mirrors for your Raven mirrors- PLEASE LOCK | FR-Shadow | Exterior Parts (Aero, Lighting, Etc.) | 3 | 09-25-2013 10:01 AM |
| 1080p Nighttime Test Drive w/ ContourROAM1 | forzajuve | Electronics | Audio | NAV | Infotainment | 0 | 04-30-2013 02:41 PM |
| Nighttime Test Drive w/ ContourROAM1 | forzajuve | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 04-29-2013 09:21 PM |
