Old 02-03-2015, 01:54 PM   #1
NickDC88
NickDC88's Avatar
GT86 Headlight Bulb Size
My brother is in Japan and is gonna bring me home a pair of GT86 headlights. I just put HID in my OEM lights and from the looks of it, I don't think they are the same bulb as the GT86. Does anyone know what size the 86 uses? Also I know there was a guy on here that made the 6 pin to 8 pin harness, but I can't get a hold of him. Does anyone else know where I could get a pair of those?
NickDC88 is offline   Reply With Quote
Old 02-03-2015, 02:26 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It should be D4S.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
NickDC88 (02-03-2015)
Old 02-03-2015, 02:44 PM   #3
ARTBRZ
Aloha!
ARTBRZ's Avatar
From what I read its a d4s. If your installing that you're going to need the wiring and relay to fully convert.
ARTBRZ is offline   Reply With Quote
The Following User Says Thank You to ARTBRZ For This Useful Post:
Old 02-03-2015, 02:53 PM   #4
NickDC88
NickDC88's Avatar
Relay? I've read through a few DIYs and no relay was mentioned. Maybe I missed something!
Old 02-03-2015, 03:40 PM   #5
ARTBRZ
Aloha!
ARTBRZ's Avatar
I read that a couple of years ago when I thought I was buying an frs. Since I went with the brz I didn't bother to save the site. I tried to look for it but I could not find the site. Sorry. I may be wrong since the stock frs has relays for the DRL and headlights already. I know for sure that you're going to repin the harness since it's different. Here's a pick of the JDM and stock frs harness.
Old 02-03-2015, 04:17 PM   #6
NickDC88
NickDC88's Avatar
Yea I saved the DIY and I've been going through other pages as well and ran into a post about someone who had made harnesses that are plug and play. Repinning it doesn't sound too hard, but being able to just plug a harness in would be a lot easier. Still haven't seen anything about a relay.
Old 02-03-2015, 04:59 PM   #7
ARTBRZ
Aloha!
ARTBRZ's Avatar
Good luck with that and post pics when your done.
Old 02-04-2015, 11:18 PM   #8
KI_ZN6
KI_ZN6's Avatar
The Japan GT86 OEM Xenon headlamps uses D4S as factory HID bulbs. Our customer chose to upgrade to the 5000k and 6000k D4 HID bulbs to get rid of the slight yellow tint found on the 4300k factory HID bulbs.
KI_ZN6 is offline   Reply With Quote
Fog light bulb size? huma Cosmetic Modification (Interior/Exterior/Lighting) 19 01-22-2015 05:57 PM
hid bulb size for 2015 rs 1.0 Mr_YUzU_FRS Scion FR-S / Toyota 86 GT86 General Forum 10 12-25-2014 12:33 PM
hid light bulb size on 2015 rs 1.0? Mr_YUzU_FRS Electronics | Audio | NAV | Infotainment 0 12-14-2014 08:41 PM
OEM Bulb size sticky? mit_peid Cosmetic Modification (Interior/Exterior/Lighting) 2 02-27-2013 12:08 AM
bulb size for frs brichard0625 Exterior Parts - The Rest 4 07-23-2012 03:33 PM
