Old 02-02-2015, 09:00 PM   #183
kch
Senior Misanthrope
kch's Avatar
Alright, let's try this again.
http://www.datazap.me/u/kch/second?log=0&data=1-2-8-10
So if FLKC and knock correction are what really matter, it looks like i'm good to go?
Old 02-02-2015, 09:06 PM   #184
xero404
Originally Posted by Phantobe View Post
Its definitely an option shiv is great!
However it depends what you want to do, there is plenty of information on this forum to customize the tune yourself. But if you don't want to invest the time, Shiv is the way to go.
I assume the BPB tunes have a tune that account for catless headers (not sure dont have BPB)?
Yeah using the BPB uel beta tune but yeah maybe it worth getting a dyno tune since @Shiv@Openflash is 15 mins away from me. I'm planning on running 86cup this year and it maybe pretty hard on the car and having a custom tune would get rid of potential headaches.
xero404 is offline   Reply With Quote
Old 02-02-2015, 09:17 PM   #185
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Yup everything looks pretty good!
AFR looks good. No knock (FLKC & Knock Correction are zero). The only thing that looks a little bit off are your fuel trims, from what I've read as a rule of thumb is that LTFT & STFT should be in the range of zero (+/-) ten percent.
High LTFT indicates that your adding fuel to account for a lean AFR (to the best of my knowledge).
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-02-2015, 09:19 PM   #186
Phantobe
Phantobe's Avatar
I would post some logs and see how they look, if you're willing to learn members can help you out
But if you plan on tracking a lot, as you've mentioned shiv is a great option.
Old 02-02-2015, 09:37 PM   #187
kch
Senior Misanthrope
kch's Avatar
Could that be due to the winter mix of E85 I'm using which is probably closer to E70?
Old 02-02-2015, 09:54 PM   #188
Phantobe
Phantobe's Avatar
That would be my best guess! Im still learning more about fuel trims, im running about E75 and I've seen LTFT hit 7% at times.
http://www.ft86club.com/forums/showt...t=51660&page=4
Check out some of shiv's posts in that thread. I think the big concern is that your LTFT is stable under load (WOT), which yours seems to be.
Old 02-03-2015, 01:09 AM   #189
steve99
Drives: FT86
first tank of E85 ? if so residual petrol will giv you high trims
is your intake stock ?? filter and tube ok but if cai will throw off fuel trims
Old 02-03-2015, 01:13 PM   #190
kch
Senior Misanthrope
kch's Avatar
No, have several hundred miles on E85. Shouldn't be any petrol left. Although a winter blend of E85 would have more straight petrol in it than usual...
Car is stock except for apexi drop-in. Changing to JDL UEL headers soon, and will flash the 2.063 stg 2 E85 UEL tune.
Old 02-03-2015, 01:14 PM   #191
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
It does look like you're running a bit rich, supposed to see low 12s high 11s mid to high rpm afaik.
What's the safest way to reduce that and level it off
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 02-03-2015, 05:56 PM   #192
steve99
Drives: FT86
if you running the stage2 el e85 map on a stock header its going to run a bit rich, once you change header to catless will run a bit leaner.
it will also run richer\leaner depending on e85 blend ethanol percent.
in australia we have a guaranteed 85% E85 at pump so i was able to rescale maf for that fuel.
Old 02-09-2015, 01:25 AM   #193
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Needs some help here.
If you look at the attached file, is it possible to have neg fine correction (this is retard from knock right), and still have a 1 IAM?
@ steve99
full file:
ProECU-SubaruBRZ-EU BRZ Manual High FD (ZA1JA01G)-07-02-2015 16-28-10_review.csv
GeeTee86 is offline   Reply With Quote
Old 02-09-2015, 01:56 AM   #194
Phantobe
Phantobe's Avatar
@ steve99
full file:
Upload the full log to Datazap.me it's the easiest way to analyze your data logs.
When did you flash to your new tune? If the ecu is still learning its possible for the IAM to stay at 1 even if you're getting knock correction. Give it a few days and if you're still getting knock you'll see your IAM begin to drop.
Old 02-09-2015, 02:08 AM   #195
GeeTee86
86 Nut
GeeTee86's Avatar
Thx for the reply,
Add datazap : http://datazap.me/u/deefluce/review-1?log=0&data=4
It's a friend of mine's, I believe its on since 24 Jan, Ill find out
Old 02-11-2015, 05:52 PM   #196
steve99
Drives: FT86
Thx for the reply,
That log looks pretty good especially if your on 95 octane south africa fuel.
I am not 100% sure of some of those Ecutek log parameters.
Your IAM is one which is good, the ecu will not immediately decrement the IAM value on every instance of knock. There needs to be a certain severity and frequency of knock events to cause the iam to drop. ie you can have some minor knock events occasionally and still have iam=1.
it looks like you are free of FBKC(knock correction) but you have a bit of FLKC (fine learning knock correction) of about -1 degree between 2200 and 2900 rpm if I am reading those paramerters correctly. judging by the kc learned values and the fine correction. Not sure what the coarse correction parameter is it looks like its the "Knock correction Advance max A " value from tables and not the amount of knock correction.
looks like all thats needed is maybe 0.7 degrees removed from Base Timing B table from 2000-3000 rpm engine loads 0.9 to 1.1 these motors tend to be knocky in that range especially on 95ron fuel.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
