Old 02-02-2015, 08:48 PM   #1
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Noises from passenger side door/window
I hear a noise coming from what sounds like the passenger side door or window. I hear it when driving over certain bumps on the passenger side. It's hard to explain but it sounds kind of like a squeaking/creaking/groaning. Almost like the window or door is not totally secure and rubbing against something. I don't ever hear this noise coming from the driver side door/window.
I know noises are extremely hard to diagnose without hearing them but I was wondering if anyone else hears anything similar. I looked through the forum and couldn't find anything that sounded like my issue. It might not be the door or window but I'm pretty sure that is where the noises are coming from.
FatFree is offline   Reply With Quote
Old 02-02-2015, 09:02 PM   #2
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I get the same thing, even though my car is RHD I get the noises you described coming from the left hand side of the car.
At first I thought it was the loose seatbelt moving around and knocking on plastic but it isn't this.
Wise is offline   Reply With Quote
Old 02-02-2015, 09:07 PM   #3
FatFree
FatFree's Avatar
Yeah, it's not coming from the seat belt for sure. It's like the door is flexing due to the stress of driving over the bump. Have you modified your suspension at all? I have H&R Super Sports installed.
Old 02-02-2015, 09:09 PM   #4
Wise
Circle Work Clerk
I have Eibach Prokit springs on mine.
Old 02-02-2015, 09:12 PM   #5
I had that sort of noise (best guess from a description) when it got really cold. Turned out my door latch moved a hair. A quick adjustment and noise was gone. May have to adjust again when warm but that will be a while.
Old 02-03-2015, 04:57 AM   #6
ET86
Perfectionist
ET86's Avatar
Drives: 2014 Scion FRS
I had the same thing. I took it to Toyota and they fixed it. I believe they said it was a TSB
ET86 is offline   Reply With Quote
Old 02-05-2015, 08:31 PM   #7
FatFree
FatFree's Avatar
I have noticed that the door does not line up evenly where it meets the front of the car. You can tell that the door and the panel are not flush with each other. And this is on the same side of the car where I am hearing the noise.
I know it's a bit difficult to see because the car is so dirty but you can tell that the driver side looks much more flush than the passenger side. And in person it is much more evident.
Perhaps the noise is related to this. Either way I would like to get it fixed because it's a bit of an eyesore even if I'm the only one who really notices it. Does anyone think the dealer can/will fix this? My car is still under warranty.
Old 02-05-2015, 08:41 PM   #8
They should fix it no problem. Pretty easy to do yourself as well though.
http://www.ft86club.com/forums/showp...5&postcount=68
Not likely the cause of your noise but worth a shot.
Old 02-05-2015, 08:43 PM   #9
FatFree
FatFree's Avatar
Cool, thanks for that link.
Rattling sound on passenger side window G8mou BRZ First-Gen (2012+) — General Topics 7 10-17-2014 12:28 PM
Passenger Side Window Doesn't Work JNovo79 Issues | Warranty | Recalls / TSB 5 02-18-2014 03:14 PM
Looking for FR-S whiteout RH (passenger side) door $650 Etomatoeman Exterior Parts (Aero, Lighting, Etc.) 0 12-04-2013 03:57 PM
Passenger side window issue. I've searched and tried everything but no fix skygt19 Issues | Warranty | Recalls / TSB 14 11-09-2013 03:22 PM
Passenger side window auto-up less sensitive? l0aded Scion FR-S / Toyota 86 GT86 General Forum 8 09-17-2013 03:01 PM
