Old 01-17-2015, 05:02 PM   #85
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by j_Zer0 View Post
For those of you running OFT/OFH + GS intake on the OFT stg2 UEL tune...what do you think of the combo? What does the GS intake add to the rest? Im running OFT/OFH and will be installing the GS intake this weekend. How are AFRs? Any issues worth mentioning ? Anyone have logs they could share? Any advice or feedback? Still liking it? How's the daily driving experience? Throttle response? Thanks a lot.
I have OFT/JDL UEL + GS intake. I have just reflashed yesterday to load some adjustments to my MAF scaling. I drove about 70km to let the LTFT settle a bit and took some logs of 3rd gear pulls. I still need time for more learning.
http://datazap.me/u/dmmccrea/jan-17?...zoom=1871-3114
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-18-2015, 10:22 PM   #86
j_Zer0
Drives: Asphalt FRS 2014
Thanks for posting the log. Looks like you're running a bit leaner than I am. Your AFR is about half a point over command during your WOT pulls and mine tends to be half a point under command. Of course I have a bit of knock and you don't.
I'm trying to figure out what changes to expect after I install the intake, and after seeing your log I'm thinking I might run a bit leaner afterwards.
I wish I could get 94 octane -- you're lucky.
j_Zer0 is offline   Reply With Quote
Old 01-18-2015, 10:48 PM   #87
steve99
Drives: FT86
if your getting knock you can
run better fuel
run richer unless your already running rearly rich.
reduce timing advance.
generally if your getting knock leaning it out will make it worse on petrol. suggest you pull a bit of timing at the rpm\load area from the base-timing-B table pull a bit over half the knock correction you see and a bit from adjacent cells see knock correction thread below
Old 01-19-2015, 10:50 AM   #88
j_Zer0
run better fuel
For some reason the knock only seems to happen at cruise. I've only seen it 1500 - 3500 RPM. Same behavior on 93 and E85. I'm already running a bit rich in places, so don't think I'd want to run richer. I've got 2 sources available for E85 so I need to try the other to see if it's any better. If it's not, I'd be up for learning how to edit a few tables. It's only mild, transient knock, but still.....I'd rather eliminate it. Thanks for pointing out the knock correction thread. I'll definitely be checking that out.
Old 01-30-2015, 01:56 PM   #89
meWant
Drives: '16 BRZ Limited
Originally Posted by Boofneenee View Post
Can someone tell me if the gains are 7hp over the dyno stage 1 with a high flow filter? I'm assuming no and that the gains are mediocre as are most CAI but would like to believe otherwise.
Sorry to bump, but did anybody every verify if this is the case?
like would the intake + tune gains be the Stage 1 + 7whp?
meWant is offline   Reply With Quote
Old 01-30-2015, 02:31 PM   #90
diBreezy
diBreezy's Avatar
Drives: 2013 Raven FRS
Originally Posted by xxBrun0xx View Post
Can't wait to see dyno results for oft + grimmspeed intake
You took the words right out of my mouth.
diBreezy is offline   Reply With Quote
Old 01-30-2015, 09:07 PM   #91
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
someone who knows anything about tuning can you look at my log? I have a feeling i've got some knock http://datazap.me/u/sypher/13015?log=0&data=1-12
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 01-30-2015, 09:19 PM   #92
steve99
Drives: FT86
yes you have not bad but some their
IAM is 0.88 should be 1
can see evidence on knock in kc learned curve 5000-6000 again not real bad
you rearly need to log
FLKC
Knock Correction FBKC
which are not in your logs
have a read of the ecu logging link and the knock correction links below
try some different fuels
Old 02-02-2015, 12:09 AM   #93
Sypher
Sypher's Avatar
FLKC
Thanks for looking at that for me . I'll read your post about logging and try some different fuel + log the correct info.
Mod List:
Old 02-02-2015, 12:51 PM   #94
Sleepless
Drives: 2016 FR-S
An updates on an official OFH "Stage 2" tune?
Sleepless is offline   Reply With Quote
Old 02-02-2015, 07:27 PM   #95
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
I contacted them yesterday concerning getting a tune for this particular setup for my car. Should get an answer soon hopefully In my case it's not urgent, so I don't fret about it. I'll update when I get more news
Mad1723 is offline   Reply With Quote
Old 02-13-2015, 12:32 AM   #96
Koa
FOR THOSE WITH OFH AND THIS INTAKE!
I am wrapping up a MAF scale that will make this setup shine. Will post it on the morrow if trims look good. So far I've gotten LTFTs down from peak 9's to 0.78 or 0.00
Love this setup. Very healthy, very fast.
-- EDIT
Here's the MAF Scale and instructions for altering your tune! You need RomRaider ECU Editor (www.romraider.com)
Grimmspeed Intake + OFH MAF Scale - 91 OCT - v1.03
http://www52.zippyshare.com/v/Vt4grbCP/file.html
Old 02-16-2015, 02:13 PM   #97
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
-- EDIT
60 mile commute this morning.. trims look great. No FLKC and low LTFTs. Really need a wideband O2, but this should ballpark people nicely that are running catless UEL, this intake, and 2.06 map. One more re-scale and it will be gtg. Expect it this weekend
How is the MAF scale coming along? I'd like to try it out if your still willing to share
TruRace is offline   Reply With Quote
Old 02-16-2015, 02:31 PM   #98
Koa
Sorry for the lack of update! Valentine's day put a wrench (or prevented me from doing so, lol) in my final logs and tweaks. I will put out my baseline D00C bin file and MAF Scale in an excel file tonight.
It will need further refining to suit one's exact exhaust setup and to account for the variance in engines/drivetrain... but it's damn close and pulls hard!
Stay tuned
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
