Old 01-16-2015, 01:01 PM   #57
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Originally Posted by bdanisi View Post
Dammit man I was amped on this until the carb issue was brought. It's OK I'm only crying a little bit.
Sent from my SM-G900V using Tapatalk
If you want a Turbo kit that could possibly get a CARB exemption, works kit or the STS turbo kit.
Anything with a turbo manifold will not get a CARB exemption.
-Jack Burton
tahdizzle is offline
Old 01-16-2015, 01:11 PM   #58
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
It looks exactly like a Full Blown clone that uses BW EFR turbos. Not that there is anything wrong with that. I saw the manifold and thought to myself, I didn't think they made a V band EFR turbo. Interesting decision to use that straight pipe between the 4 bolt flange and the V band. I would think that any B1 frame turbo from EFR should work with this kit. Have you considered test fitting and offering all the B1 frame turbos as options?
This is definitely not a clone. We designed this from the ground up with out any other kits in mind. Lots of different aspects of ours than others currently on the market.
Any B1 frame turbo will fit this kit.
Originally Posted by kbye View Post
Silicone connectors are in different areas, MAF sensor in different area, IC pipe near the windshield fluid tank is completely different, turbo placement is different, no slim fans, by your definition I would not call it a clone. Functionally they are all in the same relative places but the design is not the same at all.
To me a clone is SBD -> GReddy.
Thank you.
FT-86 SpeedFactory is offline
Old 01-16-2015, 01:11 PM   #59
FT-86 SpeedFactory
[ame="https://www.youtube.com/watch?v=qGxTHm7cQXU"]FT86SpeedFactory - FRS/BRZ Turbo Kit Sneak Peak - YouTube[/ame]
Old 01-16-2015, 01:45 PM   #60
MidnightRunner
MidnightRunner's Avatar
Originally Posted by FT-86 SpeedFactory View Post
You guys definitely have the sickest intro out there.
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline
Old 01-16-2015, 01:53 PM   #61
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Looks yummy!
Cockatoo is offline
Old 01-16-2015, 06:30 PM   #62
noah9797
Drives: Dark Grey Metallic '13 Subaru BRZ
Any idea of what us midwest guys could make on 93?
noah9797 is offline
Old 02-01-2015, 11:13 PM   #63
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Bump for pre-tax-return-season
*hint hint*
PandaSPUR is offline
Old 02-02-2015, 12:34 AM   #64
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'll have a guess at price: BW EFR turbo's aren't cheap, and that looks like quality TIG welding there with some nice options. I wouldn't put it past @FT-86 SpeedFactory to charge somewhere between 4,900 and 5,500.
as for power, I'm sure others can chime in; the 6258 is rated for 225-400hp. the 6758 is rated for 275-450hp and the 7163 is rated for 400-600hp. These ratings are off treadstone's website. 7163 is the largest B1 framed turbo you can go before getting into the B2 frames, starting at the 7064.
cdrazic93 is offline
Old 02-02-2015, 12:40 AM   #65
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
In for pics of the welding. I'm a CWI.
xkalelx is offline
Old 02-02-2015, 12:52 AM   #66
DFW-FRS
Drives: 2013 Asphalt FR-S
Originally Posted by Rabbit of Caerbonnog View Post
Any chance that this turbo kit will have AT support?
Automatic transmission here. I'm curious about this as well.
DFW-FRS is offline
Old 02-02-2015, 12:52 AM   #67
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
they're on the front page.
Old 02-02-2015, 02:20 AM   #68
xkalelx
xkalelx's Avatar
Lol. Can't see any welding detail from those images. I was hinting at requesting some up close shots to evaluate fusion.
xkalelx is offline
Old 02-02-2015, 03:54 AM   #69
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I mean more pictures won't hurt anyone...
Old 02-02-2015, 08:21 AM   #70
PandaSPUR
PandaSPUR's Avatar
I think you could be right. And this would put this kit pretty much in direct competition with the FBM Stage 1 kit.
Looking forward to seeing how this goes..
PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 Events@Ptuning Tracking / Autocross / HPDE / Drifting 12 01-13-2014 10:22 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
FA20CLUB Turbo Kit 10 PSI Preliminary Testing FA20Club.com Forced Induction 161 07-27-2013 02:31 PM
N1 Concepts/Exotic Air - Turbo Development LSV8 Forced Induction 24 04-10-2013 09:48 PM
