Old 01-27-2015, 07:40 PM   #15
RBbugBITme
Drives: S60R/Corvette
Just a confidence inspiring feeling as a driver that the vehicle is stable in all conditions.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following User Says Thank You to RBbugBITme For This Useful Post:
Calum (01-28-2015)
Old 01-29-2015, 02:40 PM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by RBbugBITme View Post
Is the above BRZ dyno from a 2014 or 2015 shock? I'm told the spring rate and shock curves were changed.
This is a comparison graph between a MY14 and MY15 gt86/brz front and rear suspension:
Red is the new improved suspension and green is the old one.
Can someone explain what is the improvement? What I can understand is that there is an improved compression damping and an almost similar rebound damping.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
NissanGuy (02-24-2016), solidONE (12-02-2015)
Old 01-29-2015, 03:11 PM   #17
RBbugBITme
Impossible to say for me. Many OEMs invert the graph so rebound could be on top or bottom and there is no y-axis scale to compare. I don't know Japanese either.
Ryan M.
Strange Engineering
Old 01-29-2015, 03:29 PM   #18
Racecomp Engineering
Yeah my guess is rebound is on top there. It'd be nice to know Japanese and have a y-axis scale. Are you sure red is new?
- Andy
Old 01-29-2015, 03:46 PM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
- Andy
Yes, I used a translation tool.
改良接 -> improved
Here is the other text:
操安性 :操舵応筈か向上し、 □一ル感、 軽快感か向上 ->
Stability: enhanced Steering response should do, □ deprived sense, lightness increase
乗り心地:フラツ卜感向上、 微振動憧減 ->
Riding comfort: fix feeling improvement flats, micro vibration primary reduction
Racecomp Engineering (01-29-2015), solidONE (12-02-2015)
Old 01-29-2015, 03:49 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
OEM BRZ/FRS shocks
This thread qualifies for sticky because of this single post. Too often do I find "have the OEM shocks been dyno'ed yet?" *grumble*
Yay physics
Old 01-29-2015, 03:53 PM   #21
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
when you stumble across a shock dyno chart in the wild.
A wild shock dyno appeared?
86er fan throws hondafan boy at it!
Its not very effective...
86er fan throws Racecomp Engineering at it!
Critical hit!!
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 01-29-2015, 04:13 PM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
- Andy
I believe you are right. The graph is inverted and rebound is on top.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 02-06-2015, 10:38 AM   #23
I keep forgetting to post our T2 and T0 plots in here. I'll do it tonight, I promise.
- Andy
Old 02-06-2015, 09:23 PM   #24
T2s and T0s
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
Calum (02-06-2015), fstlane (02-06-2015), GSpeed (07-29-2015), redlined600 (02-06-2015), solidONE (12-02-2015), wparsons (02-24-2016)
Old 12-02-2015, 03:41 PM   #25
Bump. I'll be writing the next chapter soon.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Calum (12-02-2015), solidONE (12-02-2015), wparsons (02-24-2016)
Old 12-02-2015, 03:51 PM   #26
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
They have it backwards. the upper trace is the rebound damping, not compression. "confidential" it says. Nice find! Looks to be slightly less compression damping, with little more low speed compression in the front and more rebound. Explains why the new sachs damper feel more compliant than the old showas.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
nikitopo (12-03-2015)
Old 12-06-2015, 12:20 AM   #27
cookiesowns
Drives: WRB BRZ Series.Blue
- Andy
Any chance of T3 plots?
cookiesowns is offline   Reply With Quote
Old 12-08-2015, 01:56 PM   #28
Yes, brb.
- Andrew
The 2nd Official Shock Dyno Thread Shankenstein Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 04-09-2020 09:44 PM
Shock dyno? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-30-2014 03:43 PM
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 10:04 PM
Forced Induction Dyno Chart Listing! Supermassive Forced Induction 24 02-18-2013 10:51 PM
