Old 01-27-2015, 03:40 PM   #2395
STV3
Señor Member
STV3's Avatar
Originally Posted by Re~Mix View Post
Anyone else still getting P0420 codes with the OFT Stg 1 Tune? I have cleared a few in the past 5,000 miles, beginning to wonder if I should inspect underneath the car further for cracks.
No complaints otherwise, didn't want to tweak the Stg 1 to ignore any CEL codes
Been a few weeks for me on the stage 1 and still no CEL. Without the tune it would be back every 2-3 days
STV3 is offline
The Following User Says Thank You to STV3 For This Useful Post:
Re~Mix (01-27-2015)
Old 01-27-2015, 03:51 PM   #2396
chas3wba0
chas3wba0's Avatar
Drives: Yes
I'm guessing you'd be getting codes other than P0420 if you had a crack/leak, based on the 2 cases that have happened thus far:
1st case - didn't mention any codes
2nd case - P0171 and P01170
I was getting P0420 more and more consistently with Stage 1, and was getting sick of resetting my pedal response every time to clear the code, so I just turned off the code in RomRaider.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
The Following 2 Users Say Thank You to chas3wba0 For This Useful Post:
NissanGuy (02-23-2015), Re~Mix (01-27-2015)
Old 01-27-2015, 04:41 PM   #2397
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Great to hear. I think I'll need to turn things off in RomRaider. Is there a quick tutorial for that located on the forums?
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 01-27-2015, 04:59 PM   #2398
chas3wba0
chas3wba0's Avatar
Drives: Yes
I looked around a few places to figure out the procedure. It's fairly straightforward, here's a rough breakdown:
1. Go here: http://www.openflashtablet.com/Autom...ads/index.html
2. Download RomRaider tuning software
3. Download the RomRaider XML definition files for your OTS tune version (should be included in the .zip file containing your tunes)
4. Run RomRaider, import the XML definition files
5. Open your Stage 1 tune in RomRaider
6. Find the field on the left column for P0420 code, double-click or whatever to bring it up in the right-side GUI
7. Should be set to "On", change to "Off"
8. Save tune to a new file name
9. Upload to your OFT, flash new ROM to your car
**Wrote this from memory, so feel free to correct any inaccuracies**
Re~Mix (01-27-2015), STV3 (01-27-2015)
Old 01-27-2015, 06:22 PM   #2399
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
What over pipe and catted front pipe combo work best or are preferred with these headers? Or if anyone can point me in the right direction and help me figure it out that would be great too.
Thanks,
Carlos
Carlos_M is offline
Old 01-27-2015, 07:45 PM   #2400
kodyo
Drives: Scion FR-S
Thanks,
Carlos
I'm running the Motiv over pipe and catted front pipe on mine.
kodyo is offline
The Following User Says Thank You to kodyo For This Useful Post:
Carlos_M (01-28-2015)
Old 01-28-2015, 08:01 AM   #2401
Carlos_M
Carlos_M's Avatar
Thank you for the input, @kodoyo. That is the setup I was eyeing, how is the fit with the rest of your exhaust?
-Carlos
Carlos_M is offline
Old 01-28-2015, 08:32 AM   #2402
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
Probably already been asked, but the thread is massive.
How is the sound level after upgrading to this particular header? I know its different per setup, but would you say the car is a lot louder/same as stock after adding this header (assuming you had your other parts installed previously).
Bonus points if someone has my current setup is Invidia overpipe, invidia catted frontpipe, invidia Q300 and can give me some insight.
Noise levels is a major concern for me since I park in an underground lot, and everytime I start my car I'll wake up a few car alarms. (I ended up changing from an N1 to Q300, to stop pissing off neighbors)
Has anyone had their cars emissions tested after having upgraded to this header?
OnionTou is offline
Old 01-28-2015, 09:09 AM   #2403
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
with a Q300 and a catted FP, you don't have to worry about that... with the catted header noise level barely increases at all...
if you go with the catless version, noise will increase, but will still be rather tame and quiet with the Q300.
Here's how it sounds with full exhaust setup.
[ame]http://youtu.be/6RMwFg52Cq8[/ame]
Cartman is offline
The Following 2 Users Say Thank You to Cartman For This Useful Post:
kodyo (01-28-2015), Mr.Impreza (08-18-2015)
Old 01-28-2015, 09:56 AM   #2404
kodyo
Drives: Scion FR-S
-Carlos
Had no issues at all with fitment. The whole system lined up perfectly.
Only issue was getting OEM overpipe out. To put the aftermarket one in, I went from the front side before installing the header.
kodyo is offline
Old 01-28-2015, 10:21 AM   #2405
OnionTou
OnionTou's Avatar
I've seen the vids, but as usual it's sometimes hard to tell. The N1 didn't seem so bad, til I had it on my car. lol.
OnionTou is offline
Old 01-28-2015, 10:27 AM   #2406
kodyo
Drives: Scion FR-S
I have a similar setup:
Ft86SF header, motiv overpipe, carted motiv front pipe, and Greddy SP Elite axle back.
A little more rumble at higher loads, a little more rumble on cold starts, and just a little bit louder overall. I've never felt like it was too loud. You have a pretty conservative setup, so I'd be surprised if you thought the noise was too much.
kodyo is offline
Old 01-28-2015, 11:18 AM   #2407
STV3
Señor Member
STV3's Avatar
Should sound similar to my set up
FT86SF Header
Motiv Catted Fp
Greddy Supreme Sp Cat-back
FRS Greddy Supreme Sp cat-back:
[ame]http://youtu.be/9_QCk_kURcI[/ame]
STV3 is offline
Mr.Impreza (02-11-2016)
Old 01-30-2015, 02:12 PM   #2408
nunonuna
nunonuna's Avatar
Even with catless front pipe, Q300 manage to keep it quiet. It is even quieter than N1 as only exhaust mod. Im currently running catless after the header + q300. It is still very quiet.
nunonuna is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
