Old 01-26-2015, 01:52 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
KW Variant Spring Rates?
Can anyone tell me what the spring rates are for the KW V1's and V3's? I've tried doing a lot of searches, but keep coming up with conflicting information. Some sources I've read say that the V1 and V3 have the same spring rates while others say the V3 is stiffer. Any useful info on this would be appreciated.
smg1138 is offline   Reply With Quote
Old 01-26-2015, 02:07 PM   #2
Porcupint
Drives: 13 GBS BRZ
CounterSpace Garage has them listed at 230/285 for the V1's and 343/400 for the V3's.
http://counterspacegarage.com/kw-var...-frs-gt86.html
http://counterspacegarage.com/kw-v3-...r-brz-frs.html
Porcupint is offline   Reply With Quote
The Following User Says Thank You to Porcupint For This Useful Post:
CSG Mike (01-26-2015)
Old 01-26-2015, 02:45 PM   #3
smg1138
smg1138's Avatar
That clears things up. Thanks!
The Following User Says Thank You to smg1138 For This Useful Post:
Old 01-26-2015, 02:47 PM   #4
Racecomp Engineering
Those V3 rates should be double checked with KW...I believe they have been switched to the softer rates after an initial run of the firmer 343/400.
- Andy
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
brybot (07-29-2019), CSG Mike (01-26-2015), Porcupint (01-26-2015), SkAsphalt (01-26-2015)
Old 01-26-2015, 03:17 PM   #5
smg1138
smg1138's Avatar
- Andy
Really? Why would they have switched to a softer spring?
***Edit: I just got an email back from KW. It looks like the current spring rate is 230 lbs/ front and 285 lbs/ rear. ***
The Following 2 Users Say Thank You to smg1138 For This Useful Post:
brybot (11-01-2018), CSG Mike (01-26-2015)
Old 01-26-2015, 03:26 PM   #6
Beats me. But the firmer rates are used on their KW Clubsports.
- Andy
Old 01-26-2015, 03:28 PM   #7
Yeah that's what I was 99% sure of and MOST vendors still have the old rates advertised (since that's what they were at first).
The firmer 340/400 rates are on the KW Clubsports which are a good chunk of change more money and without a warranty. But they include topmounts.
Or get RCE T2 Clubsports (built by KW) with a warranty and 400/400 rates.
- Andy
fstlane (01-26-2015)
Old 01-26-2015, 03:56 PM   #8
Wepeel
Drives: '13 BRZ Ltd
Yep, that switch happened over a year ago.
Wepeel is offline   Reply With Quote
Old 01-26-2015, 06:07 PM   #9
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
How do you know which spring rate you have? That'd nice to know which ones I have
Mad1723 is offline   Reply With Quote
Old 01-26-2015, 10:04 PM   #10
OilFieldTrash
Making Oilfield Cash!
OilFieldTrash's Avatar
Drives: 2015 BRZ Limited
^^^ This
OilFieldTrash is offline   Reply With Quote
Old 01-27-2015, 10:55 AM   #11
wparsons
wparsons's Avatar
- Andy
Can someone order T2's with staggered rates? I know you offer different rates, but they're square as far as I can remember.
flickr
Old 01-27-2015, 01:06 PM   #12
Post up the numbers on the side of your springs.
The 340/400 rates should be 60-something front and 70-something rear.
- Andy
Mad1723 (01-28-2015), OilFieldTrash (01-28-2015)
Old 01-27-2015, 01:07 PM   #13
Absolutely!
- Andy
OilFieldTrash (01-27-2015), wparsons (01-28-2015)
Old 01-28-2015, 07:48 AM   #14
Mad1723
Mad1723's Avatar
- Andy
Well, since the car is in storage for winter, I'll look it up in the spring *badumtish*
The Following User Says Thank You to Mad1723 For This Useful Post:
Porcupint (01-28-2015)
Spring Rates - Track / Autocross Dave-ROR Tracking / Autocross / HPDE / Drifting 83 05-16-2023 04:56 PM
2015 FRS spring rates? Ubersuber Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-05-2015 08:27 PM
Help On Deciding Spring Rates Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-18-2014 02:18 PM
Anyone With Custom Spring Rates? Sprinter Tracking / Autocross / HPDE / Drifting 3 05-13-2014 12:12 AM
Spring rates for Super charged FRS jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-21-2013 09:32 PM
