Old 01-26-2015, 07:37 PM   #29
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by KoolBRZ View Post
That is why a BRZ has more oversteer than the FR-S,
"while the Scion FR-S is mainly about oversteer and fun. "
http://jalopnik.com/all-the-differen...uba-1250264976
"noting that while the Scion’s is more aggressive and has more oversteer and a sharper turn in while the Subaru BRZ is more balanced and stable."
http://frsbrzperformance.com/tag/fr-s-vs-brz/
"The BRZ isn't just straight up better than the FR-S, however; the BRZ is tuned for a bit of understeer, as Subaru's customers are more likely to be disturbed by oversteer. The Scion, on the other hand, is built with Ken Gushi wannabes in mind. This is a drifter's car."
http://www.complex.com/sports/2012/0...ed_fragment_=#!
"According to Subaru, the FR-S is set up for a firmer ride and an easier transition to oversteer (breaking traction at the back end), while the BRZ is set up to be a little more compliant and a little more neutral. "
http://cars.about.com/od/subaru/fr/2...Brz-Review.htm
"It's easier to wake up the understeer in the BRZ"
Scion FRS (GT86) vs. Subaru BRZ on Track - Everyday Driver
[ame="https://www.youtube.com/watch?v=uf-6rLVeR2o"]Scion FRS (GT86) vs. Subaru BRZ on Track - Everyday Driver - YouTube[/ame]
cdrazic93 (01-26-2015)
Old 01-26-2015, 07:38 PM   #30
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Originally Posted by Shutter View Post
do any of you guys have an issue with your car being becoming fwd if you go in reverse really fast?
Yeah how do you fix that?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 01-26-2015, 07:39 PM   #31
Captain Snooze
Drives: Red Herring
Yeah, I find the rear wheel steering a bit twitchy over 40 km/h.
Old 01-26-2015, 08:35 PM   #32
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I'm talking about the soft setup for street-legal purposes. Oversteer with loss of traction is what your quotes are talking about. I'm talking about a 30MPH turn causing lean and being easier to turn because of the effect of the tracking rods. I'm not talking about drifting, or sliding, or skidding. Stiffer coilovers are better suited for those pursuits. I'm only talking about daily driving on the streets in a street-legal manner. For that use, stiffer suspension is acutely uncomfortable.
KoolBRZ is offline   Reply With Quote
Old 01-26-2015, 09:06 PM   #33
Captain Snooze
Drives: Red Herring
No, not at all. Nowhere in those articles does it support your statement.
Differing slip angles between front and rear is not loss of traction.
Old 01-26-2015, 09:09 PM   #34
Captain Snooze
Drives: Red Herring
You say "stiffer" as though it is either stiff or not. It is not an either/or, black/white argument. One can have higher rate springs and quality damping and still have a more comfortable ride than stock. One can have an uncomfortable ride with any spring rate if the dampers are crap.
Old 01-26-2015, 09:21 PM   #35
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Öhlins, Penske, MCS, JRZ, Moton...can all make your car smooth and still track like a Porsche without grinding your teeth out. @CSG Mike has an S2K with double digit spring rates that he can daily.
Old 01-27-2015, 12:14 AM   #36
Kostamojen
You don't know what you are talking about. Your advise has already been refuted (and personally having run both sets of rear springs, I know for a fact your advice is wrong). And stop saying "tracking rods", nobody calls them that.
The Following User Says Thank You to Kostamojen For This Useful Post:
phobos512 (01-29-2015)
Old 01-27-2015, 12:43 AM   #37
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Awhile back, actually on this forum, I was reprimanded in the nicest way possible (because I didnt come across as an all knowing genius) that stiff =/= uncomfortable, by CSG mike and Andy from RCE. I would also take advantage of the questionaire that's been stickied at the top of this subforum, and worth while to ask them these kind of questions as well, most of these instances have popped up in that very thread.
The Following User Says Thank You to cdrazic93 For This Useful Post:
CSG Mike (01-27-2015)
Old 01-27-2015, 02:44 AM   #38
CSG Mike
CSG Mike's Avatar
badly matched springs and dampers
cdrazic93 (01-27-2015)
Old 01-27-2015, 10:04 PM   #39
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
/thread
evan (01-27-2015)
Old 01-27-2015, 11:21 PM   #40
evan
Drives: fr-s
You have purchased a sports car expecting a limousine ride?
We did it in the rental, Lincoln Continental..
evan is offline   Reply With Quote
Old 01-27-2015, 11:34 PM   #41
Captain Snooze
Drives: Red Herring
Because racecar!
Old 03-10-2015, 09:54 PM   #42
donoman
donoman's Avatar
Drives: '13 FR-S
The FRS rear suspension is VERY stiff for DD. I don't like it much and will be picking up a set of BRZ shocks asap! Thanks for the advice.
BTW cockroach guy before your panties get in a bunch ill throw the first punch and go out to venture that you've never driven a nice sports car like a 911 or a stock M3.
donoman is offline   Reply With Quote
#derpology, #spidermanthread, letthisthreaddieplease
BRZ suspension sucks! KoolBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 12-24-2014 10:54 AM
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
