Old 01-26-2015, 03:12 PM   #15
8R6
8R6's Avatar
Drives: FRS
Originally Posted by DJCarbine View Post
Best case would have been to pull over once the alt/bat light came on
that's the best case for the car... not so good case for the driver if he stopped in that area. LOL.
110/105 interchange area is straight hood. thats where you see all them stupid ass donuts and skid marks on the freeways from their stupid ass "crenshaw takeover" bs.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Tcoat (01-26-2015)
Old 01-26-2015, 03:29 PM   #16
Had a flat just outside downtown Detroit one time.
Needless to say I destroyed a tire and rim!
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
8R6 (01-26-2015), Dallen (02-08-2015), IDFWU 420 (01-31-2015), Koa (01-27-2015), Loetke (01-26-2015), mit_peid (01-27-2015), raven1231 (04-04-2015), Thorpedo (04-07-2015)
Old 01-26-2015, 03:35 PM   #17
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
LOL, I feel for you when your in a bad area and don't want to stop... but you drive with the needle pegged in H your going to have a bigger problem (ie cylinder head warpage) more times than not.
Another option for next time is call the police and say your car broke down and your blocking traffic you need a tow truck and assistance immediately.
JesseE is offline   Reply With Quote
Old 01-26-2015, 03:37 PM   #18
JesseE
JesseE's Avatar
I got stuck in a ditch with my 240sx one time in the mountains, and the tow truck guys for that area were really lazy and didn't want to come, Cop came out and he called it in and told them they better get their ass up their in 20 minutes or he would fine them... sure enough 15 minutes later they showed up LOL.
Old 01-26-2015, 03:59 PM   #19
Dezoris
Dezoris's Avatar
Did you boil the coolant from the overheat? If so you could have easily warped the heads.
Old 01-26-2015, 04:18 PM   #20
DJCarbine
Thupercharged
DJCarbine's Avatar
I always pictured California to be one big episode of Full House, that sounds rough.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 3 Users Say Thank You to DJCarbine For This Useful Post:
Loetke (01-26-2015), PStaff716 (02-08-2015), Rbmonroe (02-08-2015)
Old 01-31-2015, 04:31 PM   #21
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I bought another belt (Gates - non-racing) but decided to just slip the OEM one back on since I didn't notice any real damage to it. Also, it is a bit of a pain in the ass to replace the accessory belt because I'd have to remove the Kraftwerks /Rotrex blower assembly to get at and remove/replace the belt. I was careful to ensure the belt was seated properly before cranking. But unfortunately immediately after cranking the engine back up, the accessory belt fell off again. Must be a pulley seizing or misalignment issue. Any further thoughts?
mit_peid is offline   Reply With Quote
Old 01-31-2015, 05:17 PM   #22
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Did the tensioner feel weird?
post_break is offline   Reply With Quote
Old 01-31-2015, 05:21 PM   #23
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Originally Posted by mit_peid View Post
...unfortunately immediately after cranking the engine back up, the accessory belt fell off again. Must be a pulley seizing or misalignment issue. Any further thoughts?
Yes. Time to stop guessing and get out the wrenches. That's the only way you're going to get this fixed.
FlamingRectumSyndrome is offline   Reply With Quote
Old 01-31-2015, 05:31 PM   #24
mit_peid
Boosted Noob
mit_peid's Avatar
Found the problem. It wasn't the tensioner. It was this OEM idler pulley. The right most idler pulley in the figure below.
The Following User Says Thank You to mit_peid For This Useful Post:
wheelhaus (01-31-2015)
Old 01-31-2015, 06:11 PM   #25
wheelhaus
wheelhaus's Avatar
Looks crooked.. Bearing failure? Cross threaded?
Old 01-31-2015, 06:44 PM   #26
mit_peid
Boosted Noob
mit_peid's Avatar
Bad night for the boosted FRS last night...
Yeah it is crooked. I'm guessing it is bearing failure because of the torque/stress from being adjacent to the crank/supercharger adapter. I don't think it'd be a cross threading issue because I was really careful installing the Kraftwerks bracket onto the engine mount (or in this case is also one of the idler pulley holes).
Old 02-08-2015, 02:09 AM   #27
SPCorBUST
SPCorBUST's Avatar
i can believe its the adapter and/or engine movement.
if its only the adapter, then the problem could be something that just happens over time with added stress from the kit/adapter.
if its a combination, cusco/perrin/etc. engine mounts might alleviate some of the stress, and maybe it won't happen again.
hopefully it doesn't go out again, but if it does, it probably won't be for a while. either way if it does happen again, and is more frequent than bearing failure on non-SC twins, it might be a useful consideration for other owners in terms of additional maintenance.
out of curiosity, how many miles/how long have you had your kit?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-08-2015, 02:57 AM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Wait, how could it be engine movement? Isn't every pulley directly attached to the engine block in some fashion? The engine could do a summersault in the engine bay without putting stress on the belts.
Edit: Motor mounts are a fine upgrade, but no use spending money for the wrong reasons.
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
stugray (04-07-2015), Tcoat (02-08-2015)
TSD night rally thru Westchester, this Sat night, starts in Mt Kisco TurboMike NY / NJ / CT / PA 0 11-19-2014 06:22 PM
FRS/BRZ Night in the GTA GYNXxx CANADA 15 06-20-2014 04:33 PM
DRL at night? arleewa BRZ First-Gen (2012+) — General Topics 17 11-26-2013 01:21 AM
Mike Vu from MVDesignz will be at Tuesday Night Irvine FR-S/BRZ Meet tomorrow night! DNAPoPo Southern California 1 03-11-2013 07:12 PM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 07:15 PM
