Old 01-24-2015, 06:10 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
1) I would check all the clamps, gaskets and the pipes themselves on the exhaust system first maybe have blown something out of there
2) Have someone else listen to your car so if its loud for them or multiple people its probably just sensory adaptation
Old 01-24-2015, 07:19 PM   #16
AZ_Racer_1
Drives: 2013 Scion FR-S Asphalt
I took off the muffler and ran it straight out the stock front pipe needless to say it was stupid loud but it all sounded good (did not remove axleback). So I reinstalled the muffler and it lost all rumble and was very quiet and my buddy said it sounded a lot quieter then it used to as well. My brother said the same thing.
AZ_Racer_1 is offline   Reply With Quote
Old 01-24-2015, 09:05 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by gravitylover View Post
Someone stuffed a potato in your tailpipe?
Banana.
[ame="https://www.youtube.com/watch?v=HktV2yGtLv8"]Banana in the tailpipe! - YouTube[/ame]
-alex
Black Tire (01-25-2015)
Old 01-25-2015, 01:26 PM   #18
Paewrblue
Drives: BRZ WR Blue, E85, Fully modified.
Just lift the car up to and rev the engine around 2500RPM to check for leaking exhaust. I've had my Borla UEL on for a year and it did not lose its loudness at all before I changed to Tomei EL.
Paewrblue is offline   Reply With Quote
Old 01-25-2015, 03:50 PM   #19
Teseo
Drives: frs
OP get used of the "loudness"?
Old 01-25-2015, 05:58 PM   #20
extrashaky
Drives: 2014 BRZ Limited
An exhaust leak would not make the car more quiet.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (01-25-2015)
Old 01-25-2015, 06:52 PM   #21
evan
Drives: fr-s
I love the part where you end it with "Please help".
evan is offline   Reply With Quote
Old 01-25-2015, 07:12 PM   #22
Sure it would! All the decibel fairies would get away!
Old 01-25-2015, 10:20 PM   #23
Ashikabi
Ashikabi's Avatar
My vote is for something stuck in the muffler. If something was stuffed inside you would be able to see it with a flashlight right?
Old 01-25-2015, 10:29 PM   #24
If the exhaust was blocked so much that is makes the car quieter it would be throwing CELs like crazy by now or stopped running completely.
Exhaust has to get out as badly as air needs to get in.
Old 01-25-2015, 10:31 PM   #25
Ashikabi
Ashikabi's Avatar
Now I don't know a lot about exhaust but doesn't the muffler have done kind of "packing" inside? Could that have settled or come loose?
Old 01-25-2015, 10:36 PM   #26
Usually that will make it louder. Or if it blocks the flow too much start throwing codes.
Not an impossibility though.
Old 01-25-2015, 10:37 PM   #27
Ashikabi
Ashikabi's Avatar
So... magic?
Old 04-17-2023, 09:26 AM   #28
Dyniek
Dyniek's Avatar
Drives: Toyota GT86 TRD '19
Did you find a solution? I’m experiencing similar issue, and don’t even know where to start
Dyniek is offline   Reply With Quote
Prices DROPPED: OEM Redded Tail Lights, Wheels, Exhaust VakaGT Exterior Parts (Aero, Lighting, Etc.) 17 10-13-2014 10:40 PM
So UPS dropped this off today xwd Forced Induction 48 08-12-2014 11:06 PM
6/23/14 - Could the Subaru BRZ Be Dropped Entirely? 468Power Scion FR-S / Toyota 86 GT86 General Forum 33 06-25-2014 11:14 AM
Dropped TheseColorsDontRun Mid-Atlantic 0 02-28-2014 09:23 PM
Overpipe, does it increase loudness? SliverBrz Engine, Exhaust, Transmission 5 10-23-2013 10:02 PM
