Old 01-22-2015, 04:21 AM   #2241
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
try connecting oft to pc running latest version of openflash manager 1.15.1 i think and let it update also update template file from the oft downloads site
I just connected to ofm today and still no dice, I'll try updating the template file tomorrow!
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-22-2015, 04:42 AM   #2242
steve99
Drives: FT86
template should fix it if you have just updated oft.
Old 01-22-2015, 07:10 PM   #2243
mid_life_crisis
Drives: FR-S 10 #103 AT
It has been mentioned a couple of times by different people (Shiv one of them) that implementing soft rev limit can mess up the shifting on an A/T. This makes no sense to me and I've been in denial. Just for satisfaction, fully expecting to see no difference, I flashed one of Shiv's roms without altering it.
They're right. The shifts are noticeably better. I don't get it, I can't figure it out, but it's true. No more soft rev auto for me.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-22-2015, 08:01 PM   #2244
steve99
Drives: FT86
it possible the auto tans control unit has the stock rpm limit programeed into it so it gets a bit confused when engine ecu rpm limit is changed.
you could try implementing the soft rpm limit timing reduction but keeping the stock rpm limit .
Old 01-22-2015, 11:11 PM   #2245
Phantobe
Phantobe's Avatar
Updated the template via OFM, I think the most recent update was from October on the open flash website. Did it via the Upgrade tab, and once the template was done loading OFM said Update Complete or something like that. Anyways it didnt' work :/
Any suggestions @steve99
^ How it looked before I updated the template (save and record button not functional)
^ After updating the template
^ Next screen after that above error (save and record still not functional)
Old 01-22-2015, 11:16 PM   #2246
steve99
Drives: FT86
@Phantobe suggest you call oft guys i think they have ommitted to upddate the template file on the downloads site and logging wont work after the update.
Old 01-22-2015, 11:52 PM   #2247
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The new Template File was posted up on the website an hour ago. When you upload it, you will see some new graphics/icons as well as a new selection (Configure Tuning Alerts) in the Diagnostic Selections. I'll be making a video later this week showing how to use this new feature (it's a very powerful feature!).
If you don't upload the new Template File, you will still be able to do everything that you were able to do before. You will just get a message saying to "Please update Template File". You will still be able to flash the ECU, view data, datalog, etc,. You just won't get access to the new Tuning Alert function (to be explained soon!).
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (01-22-2015)
Old 01-22-2015, 11:59 PM   #2248
steve99
Drives: FT86
Cheers,
shiv
thanks shiv.
a couple of guys that got the auto update have said the realtime logging worked to screen but the logging to file did not, hopefully the new template will correct that as well
Old 01-23-2015, 12:02 AM   #2249
Shiv@Openflash
Drives: 2013 FRS
thanks shiv.
In my testing, both logging and saving to csv file should work just fine with the older Template File 4. The only thing that was missing is the icon button for Resetting the tuning alerts. Everything else is there and functional.
Old 01-23-2015, 02:56 AM   #2250
Phantobe
Phantobe's Avatar
Any suggestions for getting my data logging to work?
I can't save/record any of my data to my OFT the record/save button aren't functioning. The only thing I could think of that may be it, is maybe I should calibrate with a stylus but...I mean I can hit every other button ok.
Old 01-23-2015, 04:08 AM   #2251
Shiv@Openflash
Drives: 2013 FRS
Definitely try calibrating the screen with a stylus
Phantobe (01-23-2015)
Old 01-23-2015, 09:36 PM   #2252
Phantobe
Phantobe's Avatar
Yup that fixed it for me!
Thanks @Shiv@Openflash & @steve99
Old 01-24-2015, 01:33 AM   #2253
menikmati
Drives: 2015 BRZ, 2005 STI
Is FFS/LC for D00C's (2015 6MT USDM) in the works?
menikmati is offline   Reply With Quote
Old 01-24-2015, 05:20 PM   #2254
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Have had my OFT for almost a year now. The US6MT stage2 UEL tune has worked well. Finally decided to update to the newer v2.063 stage2 UEL 93 octane tune.
Here's my problem...last year I loaded my first stg2 tune from the OFT as it was out of the box. Those tunes were "B01C" tunes. Now that I've updated the tablet with the latest OFManager (1.15.1) the CAL says ZA1JB00C so I uploaded the Stage 2 UEL B00C tune. After plugging into the car it gives me an error when trying to write to the ECU and says try again. When I cancel out of that and do an "info" the tablet says my ECU is a B01C.
Seems it wants a B01C tune, but the tablet won't let me upload a B01C tune, only the B00C tune. What am I doing wrong? Thanks for any help!
cfordart is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
