Old 01-20-2015, 08:05 AM   #43
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
As stated, the BRZ changed a lot last year, biggest updates were the built engine with the help of a HKS stroker kit, and Vcams, we also fitted HKS injectors, and V2 supercharger kit.
For those not familiar with the HKS stroker kit, it is composed of Forged pistons, forged rods, forged crankshaft, everything works together to increase the stroke of the engine, therefor pushing the capacity to 2.1L. The engine is also fitted with HKS Vcams to accommodate the new stroke, and offer a better output as well. We also used HKS 1mm head gasket to lower a litle bit the CR. Aside from that, every single moving part in the engine has been changed. New srpings, valves have been treated, new oil pump assembly, and tweak of the pump to insure a stronger pressure. It was a lot of work, but it was totally worth it !
Here are the HKS parts:
The monstruous Crankshaft
The intake and exhaust Vcams
The Pistons
And rods (they are actualy fractured on the pictures gives you and idea of the quality)
https://lh3.googleusercontent.com/-H..._Drag_0001.jpg
Here is the build process
The different elements on the bench
Opening and pre-fitement of the rods on the crank
The pistons in place:
Heads with new springs
And short block closed:
The process took a month and a half, we had to wait some time to recieve all the new parts, oil pump assembly was the hardest to get.
Then everything went back in the shell, and they started to upgrade my V1 HKS superchager with the new pipes, inter-cooler, and we got rid of the restrictor.
As we moved everything out, I decided to upgrade all the bushings and mounts (engine, transmition, diff, subframe , rear-subframe) with STi parts
After being properly broken-in, we putted the car on the dyno for the final settings, and after more than 30 pulls
To explain the results, Dynapack is well known to read low, my car didn't have cancer stock, its just the way it is, what is important is the delta, the progression, and mind you it is just insane.
The car is now 366 whp , considering it was dynoed 145 whp stock, and 27 lb/ft (40 kg/m) of torque at the wheels. It is a monster, the chassis mods made it even more focused and precise ... I just adore it, its monstrously good. Sadly, being winter here, I can't really go bonkers, but as soon as the weather will be a litle more forgiving, trust me i'll upload some videos.
I really want to thank Chiba-san the boss of SCREEN here in Japan, for the patience, passion, advises he offers me through the development of my car
HaDDeS is offline   Reply With Quote
The Following 31 Users Say Thank You to HaDDeS For This Useful Post:
10Stars (02-13-2015), 636 (03-26-2015), 93Targa (02-14-2015), akahenry (02-19-2015), botbs (02-23-2015), CAMBAM_6 (05-15-2015), CxG (08-29-2015), DarkSunrise (05-28-2015), Defuser (01-21-2015), DocWalt (01-21-2015), Efferalgan (01-21-2015), GT86_PRAGUE (01-20-2015), JOMO422 (06-15-2015), JS + BRZ (05-09-2015), M-17 (01-23-2015), Metabrz (04-24-2015), new2subaru (01-18-2016), NLSP (01-20-2015), NyC Zn6 (02-19-2015), pcuerpo (11-12-2015), R2RO (01-22-2015), RedReplicant (09-10-2021), SamCruz33 (06-23-2015), Scottemad123 (01-20-2015), Slipstream (01-20-2015), spdfreak (03-26-2015), stoked_on_spool (07-19-2016), TM (01-20-2015), Turbowned (02-13-2015), Turdinator (02-09-2015), whataboutbob (09-01-2024)
Old 01-20-2015, 08:16 AM   #44
HaDDeS
Touge worship
HaDDeS's Avatar
Here is the updated part list of the BRZ:
INTERIOR
Prova Steering Wheel
Defi CR type Gages for Oil temp, Oil pressure, Boost pressure
Defi Advance control Unit
Blitz Gage Side panel
SCREEN shifter knob
HKS OBD link Type FA20
ENGINE
----- HKS 2.1 stroker kit ----
HKS Forged Pistons
HKS Forged Rods
HKS Forged Crank Shaft
HKS Vcams set
HKS 1mm Metalic Headgasket
Nismo RB26 rod bearings
Coated Valves
HKS high volume fuel injectors
HKS rev2 Supercharger Kit -unrestricted-
HKS compressor independant oil cooling system
HKS upgraded intercooler
HKS oil cooler S type
SCREEN Oil catch tank
HKS L.A Clutch
HKS Flywheel
HKS Spark Plugs
TWOSYSTEM's custom made baffled Oil pan
SCREEN dyno tune with ECUTek RaceRom
EXHAUST
HKS Spec R EL manifold
TOMEI 70mm Over pipe
BLITZ 70mm straight pipe
HKS High Power Spec L muffler
CHASSIS / WHEELS / BRAKES
D2 racing spec brakes , 356mm slotted rotors front and rear, 8 pistons front, 4 pistons rear
HKS Hypermax SP coilovers -35mm front and rear
STi engine bushings
STi Steering bushings
STi gearbox bushings
STi rear subframe mounts
STi Differential mounts, and bushings
STi control arms and links
TWS T-66F Forged wheels, 18*9 front and rear
Hankook Ventus RS3-V2 tyres 255/35 R18 front and rear
EXTERIOR
TOM's LED Tail light
The Following 11 Users Say Thank You to HaDDeS For This Useful Post:
aruxe (01-31-2015), craigpitts7 (03-09-2015), Efferalgan (04-01-2015), FRSCanuck (01-20-2015), Guillaume (01-20-2015), JS + BRZ (05-09-2015), M-17 (01-23-2015), NLSP (01-20-2015), pcuerpo (11-12-2015), Turbowned (02-13-2015), Vic (03-26-2015)
Old 01-20-2015, 08:26 AM   #45
GT86_PRAGUE
Drives: GT86
Oh, that HKS internals are sexy
How much are they?
GT86_PRAGUE is offline   Reply With Quote
Old 01-20-2015, 08:34 AM   #46
HaDDeS
Touge worship
HaDDeS's Avatar
Well, I am not really sure of the price in the USA sorry but with the Vcams probably around $4.500 ...
The Following User Says Thank You to HaDDeS For This Useful Post:
Old 01-20-2015, 08:53 AM   #47
FRSCanuck
Drives: Scion FRS
I'm planning on getting the HKS V2 as well, how did you like it with the stock engine? any recommended supporting mods?
great build! one of my favorite cars on here.
FRSCanuck is offline   Reply With Quote
Old 01-20-2015, 09:24 AM   #48
TM
TM's Avatar
Drives: DGM BRZ 6MT
Your BRZ is a MONSTER!
Amazing build.
TM is offline   Reply With Quote
Old 01-20-2015, 10:01 AM   #49
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Not knocking on the shops that we have here in North America by any means but I just love the culture of passion and workmanship available at tuning garages in Japan.
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Old 01-20-2015, 07:57 PM   #50
HaDDeS
Touge worship
HaDDeS's Avatar
The HKS V2 is a monster of kit, able to produce a lot of power, torque, and keeping the native character of the car, it is awesome.
That said, you have to be careful on stock internals, the stock oil is way to thin to maintain a proper lubrication at high revs / temperatures, and some parts will suffer fast, rod bearings for example. We had a very bad surprise when we opened the block, two of my bearings were ... dead basically, so it was about time.
If you go for the HKS kit, don't boost too much (7-8psi max), and you have to install a oil pressure, temp, and boost gauge.
If you have the possibility, I would strongly recommend a full build, with forged internals, and revising of the oil pump, baffled pan ... to make sure the engine won't suffer of any form of oil starvation / lack of efficient lubrication. Once boosted, HKS recommends 10w50 grade oil ... anything lower won't be enough. But obviously this way over stock spec of the engine ... on stock internals.
Also, under high boost (15 psi and over) , stock rods have a "tendency" to bend, but they were not designed for that ...
My BRZ is now getting 15psi of boost at max, and the supercharger is unrestricted.
The Following 7 Users Say Thank You to HaDDeS For This Useful Post:
CAMBAM_6 (05-15-2015), CxG (08-05-2015), Efferalgan (01-21-2015), Flasher (02-01-2015), FRSCanuck (01-21-2015), GT86_PRAGUE (01-21-2015), MVLSCROWNZ (01-22-2015)
Old 01-21-2015, 08:10 AM   #51
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Amazing build! I have a V2 SC with the Delicious tune (still not final) with stock internals though and HKS injectors and 43 mm restrictor. Max boost is 11 psi. Now thinking what oil to use. 10w50 seems a bit too extreme given the stock recommendation 0w20. So I'm choosing between Motul 5w30 and 5w40...
Even now with 0w20 oil I don't see critical oil pressure drop (Defi gauges installed). However, it's winter now with tempratures below zero, so I can't push the car really hard - not enough grip + I have an oil cooler.
Efferalgan is offline   Reply With Quote
Old 01-21-2015, 08:22 AM   #52
HaDDeS
Touge worship
HaDDeS's Avatar
Thanks my friend, and the choice of oil is indeed very complicated. In your case, specifically in winter 10w50 would do more bad than good, the car would be very hard to start in the morning and the initial lubrication wouldn't be ideal at all, the stock internals need thin oil to start the engine without trouble. Then at high temp its an other story ... so maybe you should check everything once the weather gets warmer for sure ! Drive the car hard on a hot day (over 25°C ) for more than 20mins you will see the pressure drops.
Still, this HKS SC is a wonderfull solution, and if you have a chance I can just really encourage you to go for the Stroker kit + cams, its mental.
The Following 3 Users Say Thank You to HaDDeS For This Useful Post:
Efferalgan (01-21-2015), Flasher (02-01-2015), GT86_PRAGUE (01-22-2015)
Old 01-21-2015, 01:06 PM   #53
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Sub'd for a totally unique build! Awesome job
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 01-22-2015, 01:39 AM   #54
HaDDeS
Touge worship
HaDDeS's Avatar
In my case, it is function over form, anytime, yet I like to have a bit of style ... that's what i tried to achieve here. Not saying its a sleeper, but its certainly not outrageous ... yes yes i know it has yellow calipers, and white wheels
I like the fact it doesn't look at all, as mean as it sounds and goes ...
Old 01-22-2015, 02:18 AM   #55
86Tony
Drives: 2015 AOZORA EDITION
Awsome build!!!! what do you do in japan anyways?
86Tony is offline   Reply With Quote
Old 01-23-2015, 03:00 AM   #56
HaDDeS
Touge worship
HaDDeS's Avatar
Here is a nice feature of the BRZ from my friends at 9tro
http://www.9tro.com/features/tuned-c...he-blue-rocket
The Following 6 Users Say Thank You to HaDDeS For This Useful Post:
93Targa (02-14-2015), CAMBAM_6 (05-15-2015), GT86_PRAGUE (01-23-2015), Metabrz (04-24-2015), new2subaru (01-18-2016), SuperDave (04-10-2015)
Japan members....anyone else out there? Chokonen888 ASIA 137 12-01-2022 03:07 AM
need help from Japan... alexmotrix Other Vehicles & General Automotive Discussions 4 05-19-2012 02:52 PM
guy tearing it up in japan in his new 86 :D carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 25 05-07-2012 09:16 AM
Some stuffs I've got in Japan yajin BRZ First-Gen (2012+) — General Topics 16 04-12-2012 08:51 AM
So I was in Japan...(PIC HEAVY) solidsnake4119 Scion FR-S / Toyota 86 GT86 General Forum 40 04-03-2012 03:28 PM
