Old 01-21-2015, 11:35 AM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Toyota John View Post
For the normal performance minded car owner the OFT is a great product.
The next OFT update (due out next week) is going to offer programmer tuning alerts that will add a level of comfort for novices as well as provide for advanced tuning alarm for experienced self-tuners. I've been testing it for the last 3 weeks and it has made my job of monitoring and evaluating tunes much easier
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
YMAA (01-21-2015)
Old 01-21-2015, 11:45 AM   #16
OkieSnuffBox
Drives: '23 BRZ Limited
Now come out with a flex fuel kit so I don't have to bother with map changes.
Old 01-21-2015, 12:02 PM   #17
rlpaul
Drives: point A to point C. Screw point B!
This is the primary reason why I'm considering Ecutek over OFT. OFT appeals to me for many many reasons, but a flex fuel kit is on my short list. If OFT supported flex fuel, decision would be easy
rlpaul is offline   Reply With Quote
Old 01-21-2015, 12:14 PM   #18
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Shiv what are you charging for Custom OFT etunes?
Toyota John is offline   Reply With Quote
Old 01-21-2015, 12:21 PM   #19
Koa
@shiv +1, would like to purchase your services
OFH + Grimmspeed intake
Old 01-21-2015, 02:15 PM   #20
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
The customer service I have recieved from the OFT guys has been fantastic. I will tell you that I've not received a response back from Shiv to a message a sent him a few days ago, but the most likely reason is because his damn inbox is so fucking full so god damn always. This is what happens when you put customer service at the top of a priority list though.
It's not that easy. remember that even with the ECUtek you're changing maps entirely. You just aren't reflashing. I'm sure they are working on it, we just have to be patient.
As stated above, it's actually pretty rough to design, test, and apply a flex fuel system. I am sure OFT is working on it though.
When I can afford it... I am doing this. Hands down.
Old 01-21-2015, 02:47 PM   #21
rlpaul
Understood its not an easy implementation. It requires several maps to be loaded based upon ethanol content, to put it simply. If memory serves, OFT only supports a single map to be loaded in the current version.
Its just on my wishlist, as I'd personally prefer to use OFT over EcuTek if I'm going to stick with the stock ECU.
Old 01-21-2015, 03:07 PM   #22
OkieSnuffBox
Yes, but once you have the sensor and the Flex Fuel map, the sensor automatically scales the fuel/ignition tables based on the Ethanol content.
So you don't have to worry about going back and forth between maps/tunes, etc. You just put your favorite flavor in and go.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Circuit Motorsports (01-21-2015)
Old 01-21-2015, 03:37 PM   #23
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
This is not correct. With an EcuTek flex-fuel tune and an ethanol content sensor installed, one tune will handle any mix of E85 and Gas, any amount of ethanol in the system, from, e0 to e98 (haven't see anyone run e100 yet). It's a true flex-fuel setup that dynamically optimizes based on ethanol content without worrying about the mix of gas and E85 in the tank. No reflashing or changing maps required for different ethanol mixes. This has been available on this platform for well over a year.
If you are referring to an E85 tune, requiring separate tunes to run E85 and gasoline without an ethanol content sensor installed, using EcuTek, One tune can handle both fuels with two maps within one tune, and you switch maps with your cruise control stalk. No laptop, no tablet, no flashing required. Takes about 2 seconds to switch maps. Very easy and convenient! The EcuTek system supports up to 4 separate maps on the 86 platform.
Not really....EcuTek-based flex-fuel solutions have been available for this platform for well over a year now.
- Bob
Circuit Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
Celadrielas (01-21-2015), Strife26 (11-25-2017)
Old 01-21-2015, 03:45 PM   #24
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
I have had great experiences with Bill @ Delicious tuning. Can't say about the others you mentioned.
JesseE is offline   Reply With Quote
Old 01-21-2015, 03:47 PM   #25
Celadrielas
If you are referring to an E85 tune, requiring separate tunes to run E85 and gasoline without an ethanol content sensor installed, using EcuTek, One tune can handle both fuels with a two maps within one tune, and you switch maps with your cruise control stalk. No laptop, no tablet, no flashing required. Very easy and convenient! The EcuTek system supports up to 4 separate maps on the 86 platform.
Not really....EcuTek-based flex-fuel systems has been available for this platform for well over a year now.
- Bob
Thank you for the correction to my information. The last exposure I had to the ECUtek system was through a local member. Every time they get in the vehicle, they have to select the appropriate map they want to run and go from there. So, if running E85, for example, they would select that map and then start driving. Every time they enter the vehicle.
Sorry for the misinformation, as it was not my intent.
The Following User Says Thank You to Celadrielas For This Useful Post:
Circuit Motorsports (01-23-2015)
Old 01-21-2015, 09:21 PM   #26
themajesticone
themajesticone's Avatar
Drives: '13 UM86
@Toyota GT 86 I would go with Delicious between the two, HOWEVER, I would suggest HRI Tuning above all else for an e-tune. E-tune NA = $300 & E-tune FI = $400 @ HRI (https://www.facebook.com/hrituning)
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 01-21-2015, 09:33 PM   #27
Shiv@Openflash
Drives: 2013 FRS
We charge $195 for custom tuning to our OFT customers. And I've been doing a lot of custom tuning work lately.
Sure.. just shoot an email to sales@openflashperformance.com and request a custom tune. The sales guys will pass the request along to me and I'll start the process with you soon thereafter.
Cheers
shiv
Old 01-22-2015, 09:48 AM   #28
Koa
Cheers
shiv
before we do that, I assume we'll have to get my IAM and MAFV to read out correctly? (I'm the one who emailed you about it a few weeks ago)
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 04:39 PM
Pad decision Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-01-2014 11:19 AM
The best decision? Vex Forced Induction 29 05-19-2014 02:36 PM
Coilover decision help. StormMcCloud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-23-2014 08:18 PM
MR2 to FR-S?? Help with decision serge627 Mid-Atlantic 8 09-28-2013 06:08 PM
