Old 01-20-2015, 08:51 AM   #239
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
Extra-S is a pretty well regarded GL5 gear oil, I wouldn't go so far as to call it "re-labelled generic stuff" you can "pickup at 7-11", but then again, I guess I'm not trying to hawk motul and amsoil products.
That said, it's not the best stuff to be running in the stock manual trans, or the rear diff either really. Works great in Subaru transaxles though.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 01-20-2015, 08:59 AM   #240
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Actually if you read what I said above, and I will clarify...
Subaru ExtraS is VERY good and we use it all the time.
Subaru ExtraS is NOT what was mentioned above, I will quote it:
"Well, I ordered the Subaru Extra - S fluid from Amazon but instead the 'High Performance Gear Oil' arrived."
My 7-11 comment was referring to the "Subaru High Performance Gear Oil" which is NOT EXTRAS!
Please read before accusing me of "hawking" products. I've been in this community for 12+ years helping more subaru owners over the years with information. I don't do it for the money, I do it for the love of Subarus!
-mike
AZP Installs is offline   Reply With Quote
Old 01-20-2015, 09:12 AM   #241
SomeoneWhoIsntMe
Ah, my mistake. I guess he should probably notify amazon and get it exchanged. The cool thing about amazon is the service you get with orders fulfilled by them, returning that stuff is no big deal.
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
AZP Installs (01-20-2015)
Old 01-20-2015, 09:15 AM   #242
AZP Installs
All good in the hood.
Yeah I've had Amazon replace stuff they've messed up on me, but as a small retailer who has real customer service and knowledge, I make every attempt to support the small businesses when I can. Once you push out the small businesses, the knowledgebase and any form of customer service will quickly evaporate from the Etailers and Big Box stores.
-mike
Old 01-20-2015, 09:24 AM   #243
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
-mike
Yes, I'm probably going to return it and look into something else. Personally, I am happy with the shifting on my BRZ and thus wanted to find something as close to OE fluid as possible. Previously I had a 350Z, I chose to change to Redline and thus was not happy with the change. That is why I wanted to stay as close to OE fluid as possible but since Toyota and Subaru both wouldn't sell me the fluid at the dealer, this was my other option. I will most likely go with Motul in the future.
Regards,
n8dog11914 is offline   Reply With Quote
The Following User Says Thank You to n8dog11914 For This Useful Post:
Old 01-22-2015, 07:08 PM   #244
radroach
Drives: car
An update on my results with Motul Gear 300, it shifts wonderfully and warms up quickly, but for me when cold during the first few minutes it will get stuck in 1st, 2nd, R during the first 3-4 shifts, still making double clutching or grannying into 3rd necessary, or otherwise then I t'll grind pretty harshly. After that though, very easy and smooth, especially made the reach into 5th gear much quicker.
Old 01-22-2015, 10:04 PM   #245
billyk
billyk's Avatar
Drives: 2014 Argento FR-S
Originally Posted by billyk View Post
I was part of the "my FRS won't go into 2nd when cold" camp. This led me to investigating changing tranny oil to fix the problem. It seems that some folks that change tranny oil experience shifting nirvana, and others say that it really didn't do much. In some cases, people report that some oil choices make getting into 2nd when cold actually worse.
I'll apologize in advance if you've already tried the technique of just remaining in 1st gear for a longer period of time to spin up the syncro when cold, but it works almost every time for me.
My previous experience was that when I leave for work in the AM in Winter weather, it's not that 2nd gear is "tough", it's actually impossible. It's like 2nd gear is totally locked-out. Dont' even mention double-clutching - that just doesn't work. I've got to skip to 3rd and try to avoid the lug. Once the tranny is warm, 2nd is great.
But I found that instead of zipping up my street in the AM spending maybe 1-2 seconds in 1st gear then struggling with 2nd, I intentionally go up the street slower, remaining in 1st, slowly accelerating without shifting and then holding it at 3k or so for a couple of seconds prior to shifting to 2nd. This seems to allow that cold syncro to spin-up, which it doesn't want to do at all when cold. With temps in the single digits, with the stock gear oil, that ice cold shift into 2nd is almost always perfect - smooth as silk. As I improve my technique, my success is increasing to nearly 100%.
Discovering this has made it so I have a lot less interest in changing my gear oil asap.
Update:
I'd say I've got my technique up to 100% now. For those first couple of shifts from 1st on a Winter morning...
Accelerate slowly and stay in 1st for 4-5 seconds.
For me, works every single time. Getting into 2nd is like butta. Stock gear oil.
billyk is offline   Reply With Quote
Old 02-04-2015, 01:28 PM   #246
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
There was someone doing a groupbuy on an all motul fluids change over a while ago, I can't seem to find it anymore. Does anyone have any info on this?
FyeaFRS is offline   Reply With Quote
Old 02-04-2015, 01:34 PM   #247
AZP Installs
We charge $85 shipped for 4 liters of Motul gear 300.
Mike
Old 05-25-2015, 08:50 PM   #248
zooki
Drives: waiting on a 2021...
Just to add to the thread, I bought the Motul from AZP(4 liters, $85) and changed both trans & rearend today. I have a lift so it made things easier. Didn't have new crush washers so I used Permatex anaerobic sealer on the washers and threads instead. Works like a champ. Previously had Pentosin in the trans. Feels about the same as the Pentosin when it was new. I try to change out the fluid every 20-25,000 miles.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 08-07-2015, 11:17 AM   #249
MoonieGT
MoonieGT's Avatar
Drives: '17 BRZ
One more happy Motul user here. Just replaced the transmission and diff fluid last night. The difference is night and day. It's really ridiculous that Toyobaru uses a fluid that holds the transmission back so much. It's such a nice gearbox with the Motul in it.
MoonieGT is offline   Reply With Quote
Old 08-07-2015, 07:08 PM   #250
dirtbike250x
dirtbike250x's Avatar
Drives: '13 FR-S Ultramarine
I can say that I too am a believer in the transmission oil change with the Motul 300 stuff. It really does make a noticeable difference, and I think it should have came from the factory with a similar fluid.
2013 FR-S Ultramarine
-TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ
dirtbike250x is offline   Reply With Quote
Old 08-09-2015, 06:17 PM   #251
sato
sato's Avatar
Drives: Dodge Patitas
I just replaced mine at ~22k miles at the dealer. World of a difference
sato is offline   Reply With Quote
Old 08-10-2015, 10:21 AM   #252
stevesnj
stevesnj's Avatar
I have not even 1500 miles on the car, sounds like Motul would be a good choice. I might as well do the rear diff while im all greasy.
Did everyone use the 100% synthetic or the Synthetic blend?
My 2016 Build thread
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 11:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
