Old 01-18-2015, 10:38 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by jflogerzi View Post
@CSG Mike
Is this true? So if i were to run all carbotech or winmax pads, bedding them is not needed?
Bedding is still needed, but the transfer layers are compatible (aka you probably wont notice except the first time you brake or so).
Old 01-19-2015, 06:55 PM   #16
jflogerzi
jflogerzi's Avatar
Okay that being said, What set of pads would you recomend for the street and a dedicated track pad then?
Old 01-19-2015, 09:21 PM   #17
CSG David
CSG David's Avatar
W1 or W2 for the street. W5 or W6 for the track.
Old 01-19-2015, 09:35 PM   #18
renfield90
The Stig's German cousin
A few points I feel need clarification:
1. Don't confuse "bedding in the pads" with "getting rotors turned." The former prepares a new brake pad for use, the latter removes whatever existing transfer film is on the rotor.
2. Nearly always you need to bed in new pads. Running them in your first session until you experience green fade is sufficient; you don't need to follow the manufacturer's steps exactly.
3. Certain manufacturers do not use transfer films that are compatible across the whole of their brake pad line. Call and ask before you pad slap and wad the car. That said you can pad slap if you are very careful, understand the risks, and are willing to drive gingerly until you've worn away the old transfer film.
4. There are other benefits to having a dedicated track-only set of rotors...like not prematurely lunching the rotors that get you to work. To the OP, yes you can swap fronts only - just realize that brake balance is going to be affected if you are running a proper track pad up front and a compromise pad in the rear. That's strictly a driving style issue unless you are competing.
The Following User Says Thank You to renfield90 For This Useful Post:
CSG Mike (01-20-2015)
Old 01-20-2015, 12:00 AM   #19
jflogerzi
jflogerzi's Avatar
Thanks for the info. My plan would be to swap pads on both front and back from street to trackpad, just not rotors in the back.
Old 01-20-2015, 12:39 AM   #20
CSG Mike
CSG Mike's Avatar
turning/resurfacing the rotor is shaving off a thin layer to get yourself a flat bedding/mating surface for new pads. This also happens to remove the bedding layer, but that is a byproduct of turning/resurfacing the rotor, not the primary reason a rotor is turned/resurfaced.
Old 01-20-2015, 01:14 AM   #21
Dezoris
Dezoris's Avatar
Just pick a brand as mentioned reduces bedding concerns. i finally stuck with Carbotech 1521s for street and silent on street even in cold. And for track used XP10. Back and forth was no issue on same rotors. Even when I went from 1521s the layer was so thin that when I used extreme pads like PMU999 that layer was wasted in one lap.
Whatever you choose stick with same brand for street and track and your material transfer issues are basically a non issue.
The Following User Says Thank You to Dezoris For This Useful Post:
jflogerzi (01-20-2015)
Old 01-20-2015, 10:17 AM   #22
renfield90
Gotcha. Yeah that's fine, just make sure both pads you pick for the rear have compatible transfer films.
Old 01-20-2015, 12:07 PM   #23
jflogerzi
jflogerzi's Avatar
I have already had my stock rotors re surfaced once so i am not sure its doable again. Our rotors are pretty thin
2013 Series 10 FRS #553
FS: Stock FR-S Seats (fronts)- SOLD ft86chick Interior Parts (Incl. Lighting) 3 01-21-2015 12:44 PM
Hawk Hp plus Fronts only? feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-30-2014 03:31 PM
Non-FI with 18x9.5 fronts? Namuna Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-06-2014 10:56 PM
Hawk HP Plus Fronts Sheldon Brakes, Suspension, Chassis 2 04-05-2013 09:32 AM
New 86.. 5 days of ownership, From Monday to Friday, 5 days of mods :D [pics!] WTF Member's Car Journals 53 07-16-2012 03:18 PM
